boost电路讨论,有详图 ...
2699|8
 楼主| playlinus 发表于 2009-1-2 10:23 | 显示全部楼层 |阅读模式
<br />具体推导内容:While&nbsp;the&nbsp;transistor&nbsp;is&nbsp;ON&nbsp;Vx&nbsp;=Vin,&nbsp;and&nbsp;the&nbsp;OFF&nbsp;state&nbsp;the&nbsp;inductor&nbsp;current&nbsp;flows&nbsp;through&nbsp;the&nbsp;<br />diode&nbsp;giving&nbsp;Vx&nbsp;=Vo.&nbsp;For&nbsp;this&nbsp;analysis&nbsp;it&nbsp;is&nbsp;assumed&nbsp;that&nbsp;the&nbsp;inductor&nbsp;current&nbsp;always&nbsp;remains&nbsp;flowing&nbsp;<br />(continuous&nbsp;conduction).&nbsp;The&nbsp;voltage&nbsp;across&nbsp;the&nbsp;inductor&nbsp;is&nbsp;shown&nbsp;in&nbsp;Fig.&nbsp;7(第二张波形图)&nbsp;and&nbsp;the&nbsp;average&nbsp;must&nbsp;be&nbsp;zero&nbsp;for&nbsp;<br />the&nbsp;average&nbsp;current&nbsp;to&nbsp;remain&nbsp;in&nbsp;steady&nbsp;state&nbsp;<br />由此得出公式:&nbsp;Vin*Ton&nbsp;+&nbsp;(Vin&nbsp;-&nbsp;Vo)*Toff&nbsp;=&nbsp;0<br /><br />这个公式用到的是什么定理(电压和时间的乘积),不太明白,请DX们赐教这段推导过程,谢谢!<br />
 楼主| playlinus 发表于 2009-1-2 10:24 | 显示全部楼层
电路图在这里...
如题
computer00 发表于 2009-1-2 12:05 | 显示全部楼层
找个开关电源的书看一下吧,这个是一个基本公式,一般都
 楼主| playlinus 发表于 2009-1-2 13:43 | 显示全部楼层
隔行如隔山,还在同行呢,只适用的少,哎,难啊
 楼主| playlinus 发表于 2009-1-2 15:59 | 显示全部楼层
象这个不加负反馈环路是否可以做到恒定电压输出?
lvnanll 发表于 2009-2-16 17:49 | 显示全部楼层
123
dian&nbsp;liu&nbsp;chong&nbsp;liang&nbsp;xiang&nbsp;deng
HWM 发表于 2009-2-17 09:48 | 显示全部楼层
电压乘时间(实为积分)自然会想到电感和电流,只是电感
icefall 发表于 2009-2-18 17:31 | 显示全部楼层
伏秒平衡
L*dI=V*dt
雁过留痕 发表于 2009-2-19 18:29 | 显示全部楼层
00
不加回环控制`难做到输出稳定`
