| void init_clock(void) {
 P7SEL |= BIT0 + BIT1;                       // IO口设置为外部晶振
 UCSCTL1 = DCORSEL_5;                        // 选择DCO的范围
 UCSCTL2 = 374;                              // 设置DCO频率为16M
 // 设置MCLK = DCOC,MCLK =DCO,ACLK=XT1
 UCSCTL4 = SELM_3 + SELA_0 + SELS_3
 void main(void)
 WDTCTL=WDTPW+WDTHOLD;
 init_clock();                             //初始化系统时钟
 light=3;
 PCDIR=0xffff;
 PCSEL=0x0000;
 P10SEL = 0x30;                       //选择P10.4 P10.5串口功能
 UCA3CTL1 |= UCSWRST;                // USCI Software Reset */
 UCA3CTL1 |= UCSSEL_2;               // USCI 0 Clock Source: 2  -->  SMCLK
 UCA3BR0 = 0x6d;                      //设置波特率9600
 UCA3BR1 = 0;                        //设置波特率
 UCA3MCTL |= UCBRS_1 + UCBRF_0;      // USCI A0 Modulation Control = USCI Second Stage Modulation: 1 + USCI First Stage Modulation: 0
 UCA3CTL1 &= ~UCSWRST;               //复位状态机
 UCA3IE |= UCRXIE;                   //USCI Receive Interrupt Enable
 _EINT();
 //计数时钟选择STMLK=8MHz,1/8分频后为1MHz
 TA0CTL |= TASSEL_2 + ID_3;
 LcdReset();
 s[0]=light/10+0x30;
 s[1]=light%10+0x30;
 Disp1Char(8,0,s[0]);
 Disp1Char(9,0,s[1]);
 DispStr(2,0,"light");
 DispStr(3,1,"I Love You");
 while(1)
 PCOUT=light;
 s[0]=light/10+0x30;
 s[1]=light%10+0x30;
 __delay_cycles(100000);
 /*******************中断服务函数***********************/
 #pragma vector=USCI_A3_VECTOR
 __interrupt void USCI_A3_ISR(void)                //串口0中断
 switch(__even_in_range(UCA3IV,4))   //判断 USCI A0 Interrupt Vector Register Value
 case 0:break;                     // Vector 0 - no interrupt
 case 2:                           // Vector 2 - RXIFG
 while (!(UCA3IFG&UCTXIFG));
 UCA3TXBUF = UCA3RXBUF;
 light=UCA3RXBUF;
 break;
 case 4:break;                     // Vector 4 - TXIFG
 default: break;
 为什么在初始化系统时钟后串口中断接收发送功能就无法运用?
