[STM8] STM8 IIC 一直进中断
3020|8
 楼主| wsl_5631 发表于 2017-6-6 10:41 | 显示全部楼层 |阅读模式
INTERRUPT_HANDLER(I2C_IRQHandler, 19)
  /* In order to detect unexpected events during development,
     it is recommended to set a breakpoint on the following instruction.
  if(I2C->SR2)
      I2C->SR2 = 0;
  if(I2C_GetITStatus(I2C_ITPENDINGBIT_STARTDETECTION))
      I2C_ClearITPendingBit(I2C_ITPENDINGBIT_STARTDETECTION);
      IIC_Receive_event = 1;        //START
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_STOPDETECTION))
      ////I2C_ClearITPendingBit(I2C_ITPENDINGBIT_STOPDETECTION);
      IIC_Receive_event = 3;        //STOP
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_RXNOTEMPTY))
     //// I2C_ClearITPendingBit(I2C_ITPENDINGBIT_RXNOTEMPTY);
      IIC_Receive_data = I2C_ReceiveData();
      IIC_Receive_event = 2;        //接收到数据
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_TXEMPTY))
      ////I2C_ClearITPendingBit(I2C_ITPENDINGBIT_TXEMPTY);
      IIC_Receive_event = 4;        //发送寄存器空
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_TRANSFERFINISHED))  //发送完成
      I2C_ClearITPendingBit(I2C_ITPENDINGBIT_TRANSFERFINISHED);
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_HEADERSENT))  //发送完成
      I2C_ClearITPendingBit(I2C_ITPENDINGBIT_HEADERSENT);   //10-bit Header sent
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_ADDRESSSENTMATCHED))  //地址发送完成/匹配
      I2C_ClearITPendingBit(I2C_ITPENDINGBIT_ADDRESSSENTMATCHED);
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_WAKEUPFROMHALT))  //唤醒
      I2C_ClearITPendingBit(I2C_ITPENDINGBIT_WAKEUPFROMHALT);
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_OVERRUNUNDERRUN))  //Overrun/Underrun
      I2C_ClearITPendingBit(I2C_ITPENDINGBIT_OVERRUNUNDERRUN);
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_ACKNOWLEDGEFAILURE))  //确认失败
      I2C_ClearITPendingBit(I2C_ITPENDINGBIT_ACKNOWLEDGEFAILURE);
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_ARBITRATIONLOSS))  //!< Arbitration Loss
      I2C_ClearITPendingBit(I2C_ITPENDINGBIT_ARBITRATIONLOSS);
  else if(I2C_GetITStatus(I2C_ITPENDINGBIT_BUSERROR))  //Misplaced Start or Stop condition
      I2C_ClearITPendingBit(I2C_ITPENDINGBIT_BUSERROR);
  else
      nop();
我所有的中断事件都列举出来了,还是会一直进入中断,nop()这个位置。 出来后又进,崩溃了。
初始化如下
I2C_ITConfig((I2C_IT_TypeDef)(I2C_IT_ERR |I2C_IT_EVT|I2C_IT_BUF),ENABLE);
  I2C_Init(100000,0X51,I2C_DUTYCYCLE_2,I2C_ACK_CURR,I2C_ADDMODE_7BIT,CLK_GetClockFreq());
  I2C_Cmd(ENABLE);
请指点,谢谢大家
mmuuss586 发表于 2017-6-6 12:14 | 显示全部楼层
那程序里,把所有的中断标志位都清下看看
airwill 发表于 2017-6-6 12:33 | 显示全部楼层
估计是中断标志没有清除引起的.
最好借助仿真器看一下外设寄存器.
 楼主| wsl_5631 发表于 2017-6-6 13:22 | 显示全部楼层
I2C->SR1  I2C->SR2  I2C->SR3全部清也不行。 示波器观察一下,发现我主机的IIC_SCL是没上拉的(这个不能更改,原来是挂的24C02,主机模拟IIC,SCL不需要上拉),上电复位前是低的,然后来了个高电平。相当于产生一个STOP,STM8作为从机就不正常了。不正常时SCL被STM8 一直拉低了
 楼主| wsl_5631 发表于 2017-6-6 14:05 | 显示全部楼层
明明 SR1 = 0X10 为什么就是不进这个分支,就是判断不到这个标志
看不清的天空 发表于 2017-6-9 16:53 | 显示全部楼层
来看看,我也不懂
LRP103981836 发表于 2017-9-20 11:02 | 显示全部楼层
看不懂
kingkits 发表于 2017-9-20 11:18 | 显示全部楼层
通常你只需要读一次状态,再读就不对了。
IICeeprom 发表于 2017-9-21 11:12 | 显示全部楼层
如果你没有仿真器,建议你在中断里把各个状态位都用串口打印出来,这样虽然会让你的程序发生一些莫名其妙的问题,但是这样能让你知道你的程序究竟是在哪里,以前我就是这样调的
