[嵌入式linux] 请问这句是啥意思呢?
2254|3
 楼主| 大众牌BF 发表于 2010-5-11 11:18 | 显示全部楼层 |阅读模式
IO, se, AD, pi, gp
这句:
addr = (volatile unsigned int *)(GPIO_ADDR_BASE + GPIO_PORT_ADD * minor);
还有这句:
addr[GPIO_SET_OFFSET] = 1 << arg;
int gpio_ioctl(struct inode * inode,struct file * filp,unsigned int cmd,unsigned long arg)
    volatile unsigned int * addr;
    int minor = MINOR(inode->i_rdev);
    int err = -1;
//    printk(KERN_ALERT "ioctl called\n");
    if(minor > MAX_PORTS)
        return -ENODEV;
    //check magicnum
    if(_IOC_TYPE(cmd) != MAGIC_NUM)
        return -ENOTTY;
    if(_IOC_NR(cmd) > MAX_CMDS)
        return -ENOTTY;
    check read or write cmd,if 1 ,check the user buf
    if(_IOC_DIR(cmd) & _IOC_READ){
        err = !access_ok(VERIFY_READ,(void __user*)arg,_IOC_SIZE(cmd));
        if(err) return -EFAULT;
    else if(_IOC_DIR(cmd) & _IOC_WRITE){
        err = !access_ok(VERIFY_WRITE,(void __user*)arg,_IOC_SIZE(cmd));
    switch(cmd){
    case GPIO_SET_PIN:
        if(arg < 32)
        break;
    case GPIO_CLR_PIN:
        if(arg < 32)
            addr[GPIO_CLR_OFFSET] = 1 << arg;
        break;
    case GPIO_SET_PINS:
        addr[GPIO_SET_OFFSET] = arg;
        break;
    case GPIO_CLR_PINS:
        addr[GPIO_CLR_OFFSET] = arg;
        break;
    case GPIO_DIR_IN:
        if(arg < 32)
            addr[GPIO_DIR_OFFSET] &= ~(1 << arg);
        break;
    case GPIO_DIR_OUT:
        if(arg < 32)
            addr[GPIO_DIR_OFFSET] |= 1 << arg;
        break;
    case GPIO_READ_PIN:
        break;
    case GPIO_READ_PINS:
        break;
    case GPIO_WRITE_PIN:
        break;
    case GPIO_WRITE_PINS:
        break;
    return 0;
ghostvip 发表于 2010-5-12 15:15 | 显示全部楼层
这句应该是获取要操作的IO口所在的寄存器组基地址(注:一组IO由一组寄存器来操作的)
这句修改IO对应的数据寄存器,即将对应的IO口拉高
walnutcy 发表于 2010-6-5 15:14 | 显示全部楼层
基本的C语言地址计算及附值操作,
驱动中较常见。 注意volatile不能丢。
sinanjj 发表于 2010-6-7 12:39 | 显示全部楼层
基本的C语言地址计算及附值操作,
volatile是硬件自己可改动。
其余不解释
