求助、、、、、、、、、、、ARM管脚定义?
3670|1
 楼主| hanfei08131106 发表于 2010-7-19 21:26 | 显示全部楼层 |阅读模式
用整个D端口的8个引脚  来控制1602的数据端,现在需要给D端口赋值:0xa0   。请高人指点怎么来设置语句、、、LM3S811、、我用的板子芯片、、
 楼主| hanfei08131106 发表于 2010-7-19 21:28 | 显示全部楼层
有错误,高人帮改?谢谢、、、、
#include "hw_ints.h"
#include "hw_memmap.h"
#include "hw_types.h"
#include "gpio.h"
#include "sysctl.h"
#include "cpu.h"
#include "interrupt.h"
#define uint unsigned int
#define uchar unsigned char
#define     YJ_PERIPH            SYSCTL_PERIPH_GPIOB                                     //LED外围   B端口作为通用输入/输出  宏定义
#define     YJ_PORT                   GPIO_PORTB_BASE        //(GPIO通用输入/输出_PORTBB端口_BASE基准)
#define     RS                        GPIO_PIN_0                                   //  PB5控制D1      B端口的2脚
#define     RW                    GPIO_PIN_1                                   //  PB5控制D1      B端口的4脚
#define     EN                    GPIO_PIN_2                                   //  PB5控制D1      B端口的6脚
#define     YJBUS_PERIPH            SYSCTL_PERIPH_GPIOD                                     //LED外围   B端口作为通用输入/输出  宏定义
#define     YJBUS_PORT                   GPIO_PORTD_BASE        //(GPIO通用输入/输出_PORTBB端口_BASE基准)
//#define         aa       GPIOPinWrite(YJ_PORT ,0xff);
#define         RS_L       GPIOPinWrite(YJ_PORT,RS ,0x00);                //ser管脚为低
#define         RW_L       GPIOPinWrite(YJ_PORT,RW ,0x00);                //SRCLK1管脚为低
#define         EN_L       GPIOPinWrite(YJ_PORT,EN ,0x00);                //SRCLK1管脚为低
#define         RS_H       GPIOPinWrite(YJ_PORT,RS ,0xff);                //ser管脚为高
#define         RW_H       GPIOPinWrite(YJ_PORT,RW ,0xff);                //SRCLK1管脚为高
#define         EN_H       GPIOPinWrite(YJ_PORT,EN ,0xff);                //SRCLK1管脚为高
uchar LCDDISPLAY_ROW1[]={"   08131106    "};
uchar LCDDISPLAY_ROW2[]={" hapyy!!!!!!!  "};
uchar   LED[ ]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xfe,0xbf};   //共阳极段码表说明
uint    i,j,k,n=0;                                                              //说明整数变量
uchar   aa,bb[]={2,0,1,0,0,6,1,1},cc=0xc0,dd;                                   // 8个数码管显示的数数组
void Delay(uint t)
  while(t)t--;
void lcd_delay(unsigned int delaytime)
  while(delaytime)delaytime--;
void write_lcd_command(uchar write_command)
  lcd_delay(40);
  RS_L;
  RW_L;
  GPIOPinWrite(YJBUS_PERIPH,YJBUS_PORT,write_command);
  EN_H;
  EN_L;
void write_lcd_data(unsigned char write_data)
  lcd_delay(40);
  RS_H;
  RW_L;
  GPIOPinWrite(YJBUS_PERIPH,YJBUS_PORT,write_data);
  EN_H;
  EN_L;
void initize_lcd(void)
  uchar i;
  EN_L;
  for(i=200;i>0;i--)lcd_delay(248);
  write_lcd_command(0x3f);
  for(i=4;i>0;i--)lcd_delay(248);
  write_lcd_command(0x0f);
  write_lcd_command(0x01);
  write_lcd_command(0x06);
void lcd_displaystr(uchar x,uchar y,uchar *str)
  switch(x)
      case 0:
            write_lcd_command(0x80+y);
            break;
          case 1:
            write_lcd_command(0xc0+y);
            break;
  while(*str)
          write_lcd_data(*str);
          str++;
int main(void)
    SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_6MHZ);        //SysCtlClockSet函数()系统时钟设置  采用主振荡器  外接6MHz晶振  不分频
    SysCtlPeripheralEnable(YJ_PERIPH);        //sysctl的周边启用
        SysCtlPeripheralEnable(YJBUS_PERIPH);
    GPIOPinTypeGPIOOutput(YJ_PORT, RS);        //GPIO输出型的  (GPIO输出引脚:GPIO_PIN_2)
        GPIOPinTypeGPIOOutput(YJ_PORT, RW);        //GPIO输出型的  (GPIO输出引脚:GPIO_PIN_4)
        GPIOPinTypeGPIOOutput(YJ_PORT, EN);        //GPIO输出型的  (GPIO输出引脚:GPIO_PIN_6)
    GPIOPadConfigSet(YJ_PORT, RS, GPIO_STRENGTH_8MA_SC,                                          //GPIO_STRENGTH_8MA:GPIO输出强度8毫安
                     GPIO_PIN_TYPE_STD_WPU);
           GPIOPadConfigSet(YJ_PORT, RW, GPIO_STRENGTH_8MA_SC,                                  //GPIO_STRENGTH_8MA:GPIO输出强度8毫安
        GPIOPadConfigSet(YJ_PORT, EN, GPIO_STRENGTH_8MA_SC,                                  //GPIO_STRENGTH_8MA:GPIO输出强度8毫安
  initize_lcd();
  write_lcd_command(0x80);
  uchar i;
  for(i=0;i<16;i++)
      write_lcd_data(i+'A');
      Delay(60000);
      Delay(60000);
  write_lcd_command(0xC0);
  for(i=0;i<16;i++)
      write_lcd_data(i+'a');
      Delay(60000);
      Delay(60000);
  lcd_displaystr(0,0,LCDDISPLAY_ROW1);
  Delay(60000);
  Delay(60000);
  lcd_displaystr(1,0,LCDDISPLAY_ROW2);
  while(1);
个人签名:适应环境,不要让环境去适应你、、
