程序问题,帮下忙,谢谢
2009|0
 楼主| zhl100 发表于 2010-7-26 12:57 | 显示全部楼层 |阅读模式
mx, ST, TE, AD, ge
”identifier "sbit" is undefined“
“ expression must have a constant value”
程序错误帮忙看看怎么回事(我用stm32控制这个芯片的),底层函数就有这个问题。
谢谢!
typedef   unsigned char  uchar ;
typedef  unsigned int uint ;
/*  cmx868 Register Address Definitions  */
#define  CMXGENRESET   0x01
  //General Reset Command (No data)
#define  CMXGENCTRL_ADDR  0xE0
     //General Control Register
#define  CMXTXMODE_ADDR  0xE1
  //Transmit Mode Register
#define  CMXRXMODE_ADDR  0xE2
  //Receive Mode Register
#define  CMXTXDATA_ADDR  0xE3
  //Tx Data Register
#define  CMXTXDATAV14_ADDR 0xE4
        //Tx in V.14 Mode Register
#define  CMXRXDATA_ADDR  0xE5
  //Rx Data Register
#define  CMXSTAT_ADDR  0xE6
  //Status Register
#define  CMXPROG_ADDR  0xE8
/* CNM2400 cmx868 Shadow Registers */
uint   cmxgenctrl;  // 16 Bit General Control Reg
uint   cmxrxmode;  // 16 Bit Rx Mode Reg
uint   cmxstat;  // 16 Bit Status Reg
uint   cmxtxmode;  // 16 Bit Tx Mode Reg
uchar  cmxtxdata;  // 8 Bit Tx Data Reg
uchar  cmxrxdata;  // 8 Bit Rx Data Reg
uint   cmxprog ;  // 16 Bit Programming Reg(reserved)
//uchar data cmxtxdatav14; // 8 Bit V14 Tx Data Reg (reserved)
uchar  cmx_int_func; // cmx_commic interrupt require function
/*  cmx868 Register Bits  */
// General Control Register
sbit  IRQNOP_EN = cmxgenctrl ^ 14;
sbit RESET   = cmxgenctrl ^ 15;
sbit PWRUP   = cmxgenctrl ^ 0;
sbit RLYDRV_ON = cmxgenctrl ^ 1;
sbit FIX_EQU   = cmxgenctrl ^ 2;
sbit  LOOPBACK_EN=cmxgenctrl ^ 3;
sbit XTAL   = cmxgenctrl ^ 4;
// Rx Mode Register
sbit AUTO_EQU  = cmxrxmode ^ 0;
sbit RXUSART   = cmxrxmode ^ 13;
// Status Register
sbit FSKOUT = cmxstat ^ 8;   //FSK frequency demodulator output
sbit  RXEVENPAR=cmxstat ^ 11;  //Set to 1 on even Rx parity
sbit RXFERR = cmxstat ^ 12;  //Set to 1 on Rx framing error
sbit RXOF = cmxstat ^ 13;  //Set to 1 on Rx data overflow
sbit    DTMFDET = cmxstat ^ 13;  //1 when DTMF code is detected
sbit RXRDY = cmxstat ^ 14;  //Set to 1 on Rx data ready.
sbit ANS2225DET=cmxstat^ 14;  //1 when 2225Hz answer tone
sbit    T1DET = cmxstat ^ 14;  //the first programmable tone is detected
sbit ANS2100DET=cmxstat^ 15;  //1 when 2100Hz answer tone
sbit T2DET = cmxstat ^ 15;  //the second programmable tone is detected
sbit CONTA = cmxstat ^ 15;  //1 when continuous 1’s pattern detected in FSK modes
sbit  CONTB = cmxstat ^ 0;
sbit  HOOKDET = cmxstat ^ 0;  // Set to 1 on Hook Detect(cmx868 inside)
sbit  FSK0101 = cmxstat ^ 1;
sbit  S1DET = cmxstat ^ 1;
sbit  RXENERGYDET=cmxstat^2;
sbit  CPENERGYDET=cmxstat^2;
sbit T1T2DET = cmxstat ^ 2;
sbit TXUF = cmxstat ^ 3;
sbit  TXRDY = cmxstat ^ 4;
sbit PROGFLAG= cmxstat ^ 5;
sbit  CRD     = cmxstat ^ 6;
sbit IRQ  = cmxstat ^ 7;
void spi_write_8bit(uchar value)
//Write a byte into cmx868 rigister through SPI_BUS ,  bit7 is firstly writen
//entry:value to input
uchar data i;
//Locked into the chip on the risingedge of the serial CLOCK.
for(i=0;i<8;i++)
  if((value&0x80)!=0)
   CDATA=1;
  else
   CDATA=0;
  SPICLK=1;
  value=value<<1;
  SPICLK=0;
void SPI_WRITE_16(uchar address)
//Write into cmx868 a 16-bits data through SPI_BUS ,the data is in the correspond shadow register
//entry:the data address to writing
SPICLK=0;
CDATA=1;
mcsn_enable;
spi_write_8bit(address);
switch(address)
   case CMXGENRESET:  //only address
  break;
   case CMXGENCTRL_ADDR: //16 bit data
    spi_write_8bit(cmxgenctrl>>8);
    spi_write_8bit(cmxgenctrl);
    break;
   case CMXTXMODE_ADDR:
    spi_write_8bit(cmxtxmode>>8);
    spi_write_8bit(cmxtxmode);
    break;
   case CMXRXMODE_ADDR:
    spi_write_8bit(cmxrxmode>>8);
    spi_write_8bit(cmxrxmode);
    break;
   case CMXPROG_ADDR:
  spi_write_8bit(cmxprog>>8);
    spi_write_8bit(cmxprog);
    break;
   case CMXTXDATA_ADDR:           //8 bit data
   case CMXTXDATAV14_ADDR:
  spi_write_8bit(cmxtxdata);
  break;
mcsn_disable;
SPICLK=1;
CDATA=1;
uchar spi_read_8bit(void)
//Read a byte from the SPI_BUS , bit7 is firstly writen
//entry:none
//export:the reading data from SPI_BUS
uchar data i;
uchar data j;
//Replay data send from cmx868 to the UC is valid when the CLOCK is high.
RDATA=1;
j=0;
SPICLK=0;
for(i=0;i<8;i++)
  SPICLK=1;
  j=j<<1;
  if(RDATA==1)
  j^=0x01;
  SPICLK=0;
return(j);
void SPI_READ_16(uchar address)
//Read a 16-bits data from cmx868 by SPI_BUS ,and save into the correspond shadow register
//entry:the  register's address in cmx868 , that is RX_DATA and STATUS_REG
//export: cmxstat in shadow register
//       cmxrxdata in shadow register
uchar i;
SPICLK=0;
mcsn_enable;
i=address;
spi_write_8bit(address); // special the register address to reading
if(i==CMXSTAT_ADDR) //16-bit register
  cmxstat=spi_read_8bit();
  cmxstat=(cmxstat<<8)+spi_read_8bit();
else if(i==CMXRXDATA_ADDR)
  cmxrxdata=spi_read_8bit();
mcsn_disable;
SPICLK=1;
RDATA=1;
void cmx_pwrup()
XTAL = 1;
// Ensure correct cmx868 Xtal is selected (S[24] Bit 0)
PWRUP = 1;    // Power Up cmx868
RESET = 1;    // Initially hold internal circuitry in reset condition
SPI_WRITE_16(CMXGENCTRL_ADDR); // Update CBUS register
DelayMs(20);    // 20ms Delay for Power Up
RESET = 0;  // Normal Operation
cmxtxmode = 0X1A00;
SPI_WRITE_16(CMXTXMODE_ADDR);
cmxrxmode = 0X1A00;
SPI_WRITE_16(CMXRXMODE_ADDR);
void cmx_reset()
  SPI_WRITE_16(CMXGENRESET);   // Load general reset byte,reset interal circuit
          // and on_hook when relay driver is the IC PIN
cmxgenctrl = 0x1180;
cmxgenctrl =0X1100;            // CML COMM_IC come into powersave mode
cmxtxmode = 0;
cmxrxmode = 0;
cmxtxdata = 0;
cmxtxdatav14 = 0;
cmxrxdata=0;
cmxstat=0;
cmxprog = 0;
void hook(uchar state)    // Done by cmx868 relay_drive outpin
cmx_pwrup();                    // wake up CML COMM_IC from powersave mode
if (state == 0)
  RLYDRV_ON=0;    // On-Hook
else
  RLYDRV_ON=1;    // Off-Hook
