DSP2812读写SST39VF800A之C++程序源码
669|0
Violin11|  楼主 | 2017-8-10 13:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本演示程序在Study-2812增强版上通过运行测试
#include "flash.h"
FlashObj::FlashObj(void)
   Init();
   Test();
void FlashObj::Init(void)
   Active = false;
   Busy = false;
   MakerId = 0;
   DeviceId = 0;
   FlashReset();
   ReadId();
   Test();
void FlashObj::FlashReset(void)
   Busy = true;
   FLASH[0x5555] = 0xaa;
   FLASH[0x2AAA] = 0x55;
   FLASH[0x5555] = 0xf0;
   Wait(FLASH[0x5555]);
   Busy = false;
void FlashObj::ReadId(void)
   Busy = true;
   FLASH[0x5555] = 0x90;
   MakerId = FLASH[0x0000] & 0xff;
   DeviceId = FLASH[0x0001] & 0xff;
//SST39VF800A MakerId=0xBF DeviceId=0x81
  Active = (MakerId == 0xBF) && (DeviceId == 0x81);
   FlashReset();
   Busy = false;
void FlashObj::ChipErase(void)
   Busy = true;
   FLASH[0x5555] = 0x80;
   FLASH[0x5555] = 0x10;
   Busy = false;
void FlashObj::SectorErase(unsigned int SectorNum)
   Busy = true;
   FLASH[SectorSize * SectorNum] = 0x30;
   Busy = false;
void FlashObj::BlockErase(unsigned int BlockNum)
   Busy = true;
   FLASH[BlockSize * BlockNum] = 0x50;
   Busy = false;
void FlashObj::Write(unsigned int & address, unsigned int val)
   Busy = true;
   FLASH[0x5555] = 0xa0;
   address = val;
   Wait(address);
   Busy = false;
void FlashObj::Wait(unsigned int & address)
unsigned int temp, val;
   Busy = true;
   do
     _delay_loop_(1);
     val = address;
     _delay_loop_(1);
     temp = address;
   while(((val ^ temp) & BIT6) != 0);
   Busy = false;
void FlashObj::Test(void)
   Busy = true;
   if (Active)//SST39VF800A测试正常
     FlashReset();
     ChipErase();
    FlashReset();
     Write(FLASH[0x0000], 0x1234);
     Write(FLASH[0x5555], 0x1234);
     Write(FLASH[0x2aaa], 0xabcd);
     FlashReset();
     SectorErase(0);
     FlashReset();
     Write(FLASH[0x0000], 0x8888);
     FlashReset();
     BlockErase(0);
     Write(FLASH[0x0000], 0x6666);
     FlashReset();
   Busy = false;
