External Bus Interface
2527|0
 楼主| yoyowodeai 发表于 2010-8-9 22:42 | 显示全部楼层 |阅读模式
我在init.S 中增加 EXT0CON EXT1CON EXT2CON 如下
; Load in the target values into the control registers
       ADRL    r0, remap_SystemInitData
       ;LDR    r0, =remap_SystemInitData
     LDMIA   r0, {r1-r9}
     LDR    r0, =EBI_Ctrl
; Now run critical jump code
     STMIA   r0, {r1-r9}
     MOV    pc, lr
remap_EndSysMapJump
     ; Default sdram configuration
    DCD    0x000530C1                    ; EBICON : not need to change.
    DCD    0x40050084                    ; 8M
    ;DCD    0x000090CC                ; SDCONF0(SDRAM) -  2M (1Mx16):0x00009041
                                    ;                -  8M (2Mx32):0x000090E3
                                    ;                  16M (4Mx32):0x000090E4
                                    ;                - 16M (8x16M):0x000090CC
                                    ;                - 32M (32Mx8):0x000090B5
                                    ;                - 64M (16Mx16x2):0x000090EE
    ;DCD    0x020090CC                ; SDCONF1 - The same as SDCONF0 with proper base address
    DCD    0x000090CD                  ; 32M
    DCD    0x020090CD                  ; 32M
    DCD    0x0000015B                    ; SDTIME0 - not need to change
    DCD    0x0000015B                    ; SDTIME1 - not need to change
    DCD 0x60004491                    ; address 0x30000000
    DCD 0x80004491                    ; address 0x40000000
    DCD 0xA0004491                    ; address 0x50000000
    DCB "@SYSTEM_INIT_CFG"            ; A key word for future useage
    ALIGN
重新編譯之後 燒到板子上
但是我dump
0xB000_1018 (EXT0CON)
0xB000_101C (EXT1CON)
0xB000_1020 (EXT2CON)
卻都還是0X0
請問是哪裡還需要修改呢?
