[matlab] 范例:opencore组织RISCMCU IP Core全套最新代码 _riscmcu
2297|0
 楼主| wangjun88 发表于 2010-8-30 11:00 | 显示全部楼层 |阅读模式
---- WISHBONE RISCMCU IP Core       ----
---- This file is part of the RISCMCU project     ----
---- http://www.opencores.org/projects/riscmcu/    ----
---- Description        ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s):        ----
----  - Yap Zi He, yapzihe@hotmail.com     ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG    ----
---- This source file may be used and distributed without   ----
---- restriction provided that this copyright statement is not   ----
---- removed from the file and that any derivative work contains  ----
---- the original copyright notice and the associated disclaimer.  ----
---- This source file is free software; you can redistribute it  ----
---- and/or modify it under the terms of the GNU Lesser General  ----
---- Public License as published by the Free Software Foundation;  ----
---- either version 2.1 of the License, or (at your option) any  ----
---- later version.        ----
---- This source is distributed in the hope that it will be   ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied  ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR   ----
---- PURPOSE. See the GNU Lesser General Public License for more  ----
---- details.         ----
---- You should have received a copy of the GNU Lesser General   ----
---- Public License along with this source; if not, download it  ----
---- from http://www.opencores.org/lgpl.shtml     ----
library ieee;
use ieee.std_logic_1164.all;
entity v_riscmcu is
port (
  clock : in STD_LOGIC;
  reset : in STD_LOGIC;
  pinb : inout STD_LOGIC_VECTOR(7 downto 0);
  pinc : inout STD_LOGIC_VECTOR(7 downto 0);
  pind : inout STD_LOGIC_VECTOR(7 downto 0)
end v_riscmcu;
architecture riscmcu of v_riscmcu is
signal ext_irq_pin, ext_timer_clk_pin : std_logic;
signal clk, clrn, div2, div4, div8, div16 : std_logic;
signal sr, reg_rd, reg_rr, c, addrbus: std_logic_vector(7 downto 0);
signal pc, offset : std_logic_vector(8 downto 0);
signal instruction, ir : std_logic_vector(15 downto 0);
signal skip, en, wr_reg : std_logic;
signal sren : std_logic_vector (6 downto 0);
signal c2a, c2b, add, subcp, logic, right, dir, pass_a : std_logic;
signal wcarry : std_logic;
signal logicsel : integer range 0 to 3;
signal rightsel : integer range 0 to 2;
signal dirsel : integer range 0 to 1;
signal addoffset, push, pull, cpse, skiptest : std_logic;
signal bclr,bset, bld, cbisbi : std_logic;
signal dest, rr, rd : integer range 0 to 15;
signal srsel : integer range 0 to 7;
signal imm_value : std_logic_vector(7 downto 0);
signal tosr : std_logic_vector (6 downto 0);
signal vec2, vec4, clr_i, set_i, clr_tov0, clr_intf, timerirq, extirq : std_logic;
signal rd_sreg,wr_sreg,rd_gimsk,wr_gimsk,rd_timsk, wr_timsk, rd_tifr,wr_tifr : std_logic;
signal rd_mcucr,wr_mcucr, rd_tccr0, wr_tccr0, rd_tcnt0,wr_tcnt0 : std_logic;
signal rd_portb,wr_portb,rd_ddrb,wr_ddrb,rd_pinb : std_logic;
signal rd_portc,wr_portc,rd_ddrc,wr_ddrc,rd_pinc : std_logic;
signal rd_portd,wr_portd,rd_ddrd,wr_ddrd,rd_pind : std_logic;
signal t_flag, c_flag : std_logic;
signal vcc, gnd : std_logic;
signal rd_ram, wr_ram, ld_mar, ld_mbr, inc_zp, dec_zp :std_logic;
signal bitsel : integer range 0 to 7;
signal set : std_logic;
signal asel : integer range 0 to 1;
signal bsel : integer range 0 to 3;
-- Frequency Divider - Divide clock by 2(div2), 4(div4), 8(div8) and 16(div16)
component v_freqdiv
port ( clock : in std_logic;
  div2, div4, div8, div16 : buffer std_logic
end component;
-- Program Counter (9 bit wide)
component v_pc
port ( offset : in std_logic_vector(8 downto 0);
  en, addoffset, push, pull, vec2, vec4 : in std_logic;
  clk, clrn : in std_logic;
  pc : buffer std_logic_vector(8 downto 0)
end component;
-- Program ROM (512 words)
component v_rom
port ( pc : in std_logic_vector(8 downto 0);
  instruction : out std_logic_vector(15 downto 0)
end component;
-- Instruction Register (16 bit wide)
component v_ir
port ( instruction : in std_logic_vector(15 downto 0);
  en, clk, clrn : in std_logic;
  ir : buffer std_logic_vector(15 downto 0);
  imm_value : out std_logic_vector(7 downto 0);
  rd, rr : out integer range 0 to 15
end component;
-- Control Unit (with IO address decoder module inside)
component v_controlunit
port ( ir : in std_logic_vector(15 downto 0);
  sr : in std_logic_vector(7 downto 0);
  skip, extirq, timerirq : in std_logic;
  en : buffer std_logic;
  wr_reg : buffer std_logic;
  rd_ram, wr_ram, ld_mar, ld_mbr, inc_zp, dec_zp : out std_logic;
  sren : out std_logic_vector (6 downto 0);
  c2a,c2b : out std_logic;
  asel : out integer range 0 to 1;
  bsel : out integer range 0 to 3;
  bitsel : out integer range 0 to 7;
  set : out std_logic;
  add, subcp, logic, right, dir, pass_a : out std_logic;
  wcarry : out std_logic;
  logicsel : out integer range 0 to 3;
  rightsel : out integer range 0 to 2;
  dirsel : out integer range 0 to 1;
  addoffset : out std_logic;
  push, pull : out std_logic;
  cpse, skiptest : out std_logic;
  bclr,bset : out std_logic;
  bld : out std_logic;
  cbisbi : out std_logic;
  vec2, vec4 : buffer std_logic;
  dest : out integer range 0 to 15;
  srsel : out integer range 0 to 7;
  offset : out std_logic_vector(8 downto 0);
  clr_i, set_i, clr_intf, clr_tov0 : out std_logic;
  rd_sreg, wr_sreg : out std_logic;
  rd_gimsk, wr_gimsk, rd_timsk, wr_timsk, rd_tifr,wr_tifr : out std_logic;
  rd_mcucr,wr_mcucr, rd_tccr0, wr_tccr0, rd_tcnt0,wr_tcnt0 : out std_logic;
  rd_portb, wr_portb, rd_ddrb, wr_ddrb, rd_pinb : out std_logic;
  rd_portc, wr_portc, rd_ddrc, wr_ddrc, rd_pinc : out std_logic;
  rd_portd, wr_portd, rd_ddrd, wr_ddrd, rd_pind : out std_logic
end component;
-- General Purpose Register (16 x 8bit)
component v_gpr
port ( c : in std_logic_vector(7 downto 0);
  wr_reg, inc_zp, dec_zp : in std_logic;
  rd, rr, dest : in integer range 0 to 15;
  reg_rd, reg_rr, addrbus : out std_logic_vector(7 downto 0)
end component;
-- ALU
component v_alu
port ( reg_rd, reg_rr, imm_value : in std_logic_vector(7 downto 0);
  c2a, c2b : in std_logic;
  asel : in integer range 0 to 1;
  bsel : in integer range 0 to 3;
  bitsel : in integer range 0 to 7;
  set : in std_logic;
  c_flag, t_flag : in std_logic;
  add, subcp, logic, right, dir, bld, cbisbi, pass_a : in std_logic;
  cpse, skiptest : in std_logic;
  wcarry : in std_logic;
  logicsel : in integer range 0 to 3;
  rightsel : in integer range 0 to 2;
  dirsel : in integer range 0 to 1;
  c : buffer std_logic_vector(7 downto 0);
  tosr : buffer std_logic_vector (6 downto 0);
  skip : out std_logic
end component;
-- Status Register (8 bit wide, flags are ITHSVNZC)
component v_sr
port (  clk,clrn: in std_logic;
   sren,tosr : in std_logic_vector(6 downto 0);
   srsel : in integer range 0 to 7;
   clr_i,set_i,bset,bclr : in std_logic;
   rd_sreg, wr_sreg : in std_logic;
   c : inout std_logic_vector(7 downto 0);
   sr : inout std_logic_vector(7 downto 0)
end component;
-- Data RAM (128 bytes)
component v_ram
port ( addrbus : in std_logic_vector(7 downto 0);
  rd_ram, wr_ram, ld_mar, ld_mbr : in std_logic;
end component;
-- Standard 8-bit I/O Port module (all ports share this same module)
component v_port
port ( rd_port, wr_port, rd_ddr, wr_ddr, rd_pin : in std_logic;
  pin : inout std_logic_vector(7 downto 0)
end component;
-- 8-bit Timer with overflow interrupt request, can drive by external clock source
component v_timer
port ( extpin, clr_tov0 : in std_logic;
  rd_timsk, wr_timsk, rd_tifr, wr_tifr : in std_logic;
  rd_tccr0, wr_tccr0, rd_tcnt0, wr_tcnt0 : in std_logic;
  timerirq : out std_logic
end component;
-- External Interrupt
component v_extint
port ( clk, clrn, extpin, clr_intf : in std_logic;
  rd_mcucr, wr_mcucr, rd_gimsk, wr_gimsk : in std_logic;
  extirq : out std_logic;
end component;
begin
--U_v_freqdiv: v_freqdiv
-- port map (clock, div2, div4, div8, div16);
U_v_pc: v_pc
  port map (offset, en, addoffset, push, pull, vec2, vec4, clk, clrn, pc);
U_v_rom: v_rom
  port map (pc, instruction);
U_v_ir: v_ir
  port map (instruction, en, clk, clrn, ir, imm_value, rd, rr);
U_v_controlunit: v_controlunit
  port map (ir, sr, clk, clrn, skip, extirq, timerirq, en, wr_reg, rd_ram, wr_ram, ld_mar, ld_mbr, inc_zp, dec_zp, sren, c2a, c2b, asel, bsel, bitsel, set, add, subcp, logic, right, dir, pass_a, wcarry, logicsel, rightsel, dirsel, addoffset, push, pull, cpse, skiptest, bclr, bset, bld, cbisbi, vec2, vec4, dest, srsel, offset, clr_i, set_i, clr_intf, clr_tov0, rd_sreg, wr_sreg, rd_gimsk, wr_gimsk, rd_timsk, wr_timsk, rd_tifr, wr_tifr, rd_mcucr, wr_mcucr, rd_tccr0, wr_tccr0, rd_tcnt0, wr_tcnt0, rd_portb, wr_portb, rd_ddrb, wr_ddrb, rd_pinb, rd_portc, wr_portc, rd_ddrc, wr_ddrc, rd_pinc, rd_portd, wr_portd, rd_ddrd, wr_ddrd, rd_pind);
U_v_gpr: v_gpr
  port map (c, wr_reg, inc_zp, dec_zp, rd, rr, dest, clk, clrn, reg_rd, reg_rr, addrbus);
U_v_alu: v_alu
  port map (reg_rd, reg_rr, imm_value, c2a, c2b, asel, bsel, bitsel, set, c_flag, t_flag, add, subcp, logic, right, dir, bld, cbisbi, pass_a, cpse, skiptest, wcarry, logicsel, rightsel, dirsel, clk, clrn, c, tosr, skip);
U_v_sr: v_sr
  port map (clk, clrn, sren, tosr, srsel, clr_i, set_i, bset, bclr, rd_sreg, wr_sreg, c, sr);
U_v_ram: v_ram
  port map (addrbus, rd_ram, wr_ram, ld_mar, ld_mbr, clk, clrn, c);
U_v_timer: v_timer
  port map (ext_timer_clk_pin, clr_tov0, rd_timsk, wr_timsk, rd_tifr, wr_tifr, rd_tccr0, wr_tccr0, rd_tcnt0, wr_tcnt0, clk, clrn, c, timerirq);
U_v_extint: v_extint
  port map (clk, clrn, ext_irq_pin, clr_intf, rd_mcucr, wr_mcucr, rd_gimsk, wr_gimsk, extirq, c);
-- The same module v_port is used by 3 I/O ports, just the signals are different
U_v_portB: v_port
  port map (rd_portb, wr_portb, rd_ddrb, wr_ddrb, rd_pinb, clk, clrn, c, pinb);
U_v_portC: v_port
  port map (rd_portc, wr_portc, rd_ddrc, wr_ddrc, rd_pinc, clk, clrn, c, pinc);
U_v_portD: v_port
  port map (rd_portd, wr_portd, rd_ddrd, wr_ddrd, rd_pind, clk, clrn, c, pind);
-- Global reset, it resets ALL flip-flops and registers to the initial state (normally gnd)
clrn <= reset;
vcc <= '1';
gnd <= '0';
t_flag <= sr(6);
c_flag <= sr(0);
-- These are the external interrupt request pin and external timer clock source pin
-- They share pins with the I/O ports
-- TIPS: You can use any of the 24 I/O pins, I use pind(7) for my applications
ext_irq_pin <= pind(2);
ext_timer_clk_pin <= pind(4);
-- When I use the UP1 board, the on-board 25 MHz clock is too fast and
-- I need to divide it by 4 so that the MCU can run
-- For waveform simulation, it does not require division (clk <= clock)
-- TIPS: To have division, uncomment v_freqdiv module instantation on top of the page and
--       assign clk with div2, div4, div8 or div16
clk <= clock;
end riscmcu;
