不行,我在网上搜到的解析是这样:“The density of "ones" at the modulator output is proportional to the input signal. For an increasing input the comparator generates a greater number of "ones," and vice versa for a decreasing input. By summing the error voltage, the integrator acts as a lowpass filter to the input signal and a highpass filter to the quantization noise. Thus, most of the quantization noise is pushed into higher frequencies . Oversampling has changed not the total noise power, but its distribution.”说明shaping只是起到distribution的作用,而没有削减作用。
