I2C的主模式可以用IO口软件模拟,如果需要使用I2C的从模式,只能用硬件的I2C模块。PIC的8脚单片机有带有硬件I2C模块的,型号是PIC12F1822。
PIC12F/LF1822/PIC16F/LF1823 8/14-Pin Flash MCUs w/ nanoWatt XLP Technology (03/09/2010)
Program Memory Type Flash
Program Memory (KB) 3.5
CPU Speed (MIPS) 8
RAM Bytes 128
Data EEPROM (bytes) 256
Digital Communication Peripherals 1-A/E/USART, 1-MSSP(SPI/I2C)
Capture/Compare/PWM Peripherals 1 ECCP
Timers 2 x 8-bit, 1 x 16-bit
ADC 4 ch, 10-bit
Comparators 1
Temperature Range (C) -40 to 125
Operating Voltage Range (V) 1.8 to 5.5
Pin Count 8
XLP Yes
Cap Touch Channels 4
Features
• Enhanced Mid-range Core with 49 Instruction, 16 Stack Levels
•Flash Program Memory with self read/write capability
•Internal 32MHz oscillator
•Integrated Capacitive mTouch Sensing Module
•Data Signal Modulator Module
•MI2C, SPI, EUSART w/auto baud
•ECCP (Enhanced/Capture Compare PWM) Module
•Comparator with selectable Voltage Reference
•4 Channel 10b ADC with Voltage Reference
•25mA Source/Sink current I/O
•Two 8-bit Timers (TMR0/TMR2)
•One 16-bit Timer (TMR1)
•Extended Watchdog Timer (EWDT)
•Enhanced Power-On/Off-Reset
•Brown-Out Reset (BOR)
•In Circuit Serial Programming (ICSP)
•On Board In-Circuit Debug
•Wide Operating Voltage (1.8V – 5.5V)
•Low Power PIC12LF182x variants (1.8V – 3.6V)
•Standby Current (PIC12LF182X): 20 nA @ 1.8V, typical
•Active Current(PIC12LF1822): 50 uA/MHz @ 1.8V, typical
