哪位告诉一下CRC校验!!!给我解释一下这个吧。
4979|7
 楼主| azeale123 发表于 2010-9-3 18:22 | 显示全部楼层 |阅读模式
/************************CRC高位和地位字节值表***************************/
uchar code  chCRCHTalbe[] =                                 // CRC 高位字节值表
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
uchar code chCRCLTalbe[] =                                 // CRC 低位字节值表
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7,
0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E,
0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09, 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9,
0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC,
0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32,
0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D,
0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A, 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38,
0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF,
0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1,
0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4,
0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F, 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB,
0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA,
0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0,
0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97,
0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C, 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E,
0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89,
0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83,
0x41, 0x81, 0x80, 0x40
/***************************CRC校验**************************************/
int CRC16_1(char* pchMsg, int wDataLen)
    uchar chCRCHi = 0xFF; // 高CRC字节初始化
    uchar chCRCLo = 0xFF; // 低CRC字节初始化
    int wIndex;            // CRC循环中的索引
    while (wDataLen--)
  // 计算CRC
  wIndex = chCRCLo ^ *pchMsg++ ;
  chCRCLo = chCRCHi ^ chCRCHTalbe[wIndex];
  chCRCHi = chCRCLTalbe[wIndex] ;
    return ((chCRCHi << 8) | chCRCLo) ;
void uart2_pro()
int crc2=0;
int crc3=0;
uchar k=0;
k=S2CON;
k=k&0x01;//串口2的接收标志位
if((k)&&(shuju_finish_flag==0))
  rec_485[i_485] =S2BUF;
  i_485++;
  if(i_485==21)//(收到21个返回的数据 然后进行数据处理)
   i_485=0;
   crc2=CRC16_1(rec_485,19);//计算所收到的前19个数据的crc校验码
   crc3=rec_485[19]+(rec_485[20]*256);//所得到的crc校验码
   if(crc2==crc3)//相等则说明接收数据没错误
其中crc2=crc3中的crc3不懂怎么回事,哪位告诉一下吧。。。。。。。
原野之狼 发表于 2010-9-3 20:40 | 显示全部楼层
CRC3是源数据包里的CRC域 通过在本地对数据包的数据域进行CRC计算然后与源数据的CRC域作比较 相等表示校验通过
至于为什么是
那是由通讯协定决定的 数据打包的时候把CRC结果的高8位放在rec_485[20] 低八位放在rec_485[19]
 楼主| azeale123 发表于 2010-9-3 20:59 | 显示全部楼层
2# 原野之狼
您好  我还想问一下,关于发出来的时候源数据包里的CRC域第19和20个数怎么计算啊!!!我也是刚学单片机不久的小新手  请教了
原野之狼 发表于 2010-9-3 21:52 | 显示全部楼层
由源数据端设备根据CRC算法计算出来的
hotpower 发表于 2010-9-3 22:01 | 显示全部楼层
这是个crc16,前19个字节的crc结果为crc2,crc3是应该得到的校验和,若相等表示数据传送正确。假如把19改为21,则crc2应该为0,则crc3就是多余的。
hotpower 发表于 2010-9-3 22:12 | 显示全部楼层
最后两个字节就是crc3。
hotpower 发表于 2010-9-5 12:28 | 显示全部楼层
http://www.hotpower.org/HotAjax/HotPower_HotAjax.html
//CRC位域8表(小端):
const unsigned int CRCR16_A001_Table[256] = {
  0x0000,0xC0C1,0xC181,0x0140,0xC301,0x03C0,0x0280,0xC241,0xC601,0x06C0,0x0780,0xC741,0x0500,0xC5C1,0xC481,0x0440,
  0xCC01,0x0CC0,0x0D80,0xCD41,0x0F00,0xCFC1,0xCE81,0x0E40,0x0A00,0xCAC1,0xCB81,0x0B40,0xC901,0x09C0,0x0880,0xC841,
  0xD801,0x18C0,0x1980,0xD941,0x1B00,0xDBC1,0xDA81,0x1A40,0x1E00,0xDEC1,0xDF81,0x1F40,0xDD01,0x1DC0,0x1C80,0xDC41,
  0x1400,0xD4C1,0xD581,0x1540,0xD701,0x17C0,0x1680,0xD641,0xD201,0x12C0,0x1380,0xD341,0x1100,0xD1C1,0xD081,0x1040,
  0xF001,0x30C0,0x3180,0xF141,0x3300,0xF3C1,0xF281,0x3240,0x3600,0xF6C1,0xF781,0x3740,0xF501,0x35C0,0x3480,0xF441,
  0x3C00,0xFCC1,0xFD81,0x3D40,0xFF01,0x3FC0,0x3E80,0xFE41,0xFA01,0x3AC0,0x3B80,0xFB41,0x3900,0xF9C1,0xF881,0x3840,
  0x2800,0xE8C1,0xE981,0x2940,0xEB01,0x2BC0,0x2A80,0xEA41,0xEE01,0x2EC0,0x2F80,0xEF41,0x2D00,0xEDC1,0xEC81,0x2C40,
  0xE401,0x24C0,0x2580,0xE541,0x2700,0xE7C1,0xE681,0x2640,0x2200,0xE2C1,0xE381,0x2340,0xE101,0x21C0,0x2080,0xE041,
  0xA001,0x60C0,0x6180,0xA141,0x6300,0xA3C1,0xA281,0x6240,0x6600,0xA6C1,0xA781,0x6740,0xA501,0x65C0,0x6480,0xA441,
  0x6C00,0xACC1,0xAD81,0x6D40,0xAF01,0x6FC0,0x6E80,0xAE41,0xAA01,0x6AC0,0x6B80,0xAB41,0x6900,0xA9C1,0xA881,0x6840,
  0x7800,0xB8C1,0xB981,0x7940,0xBB01,0x7BC0,0x7A80,0xBA41,0xBE01,0x7EC0,0x7F80,0xBF41,0x7D00,0xBDC1,0xBC81,0x7C40,
  0xB401,0x74C0,0x7580,0xB541,0x7700,0xB7C1,0xB681,0x7640,0x7200,0xB2C1,0xB381,0x7340,0xB101,0x71C0,0x7080,0xB041,
  0x5000,0x90C1,0x9181,0x5140,0x9301,0x53C0,0x5280,0x9241,0x9601,0x56C0,0x5780,0x9741,0x5500,0x95C1,0x9481,0x5440,
  0x9C01,0x5CC0,0x5D80,0x9D41,0x5F00,0x9FC1,0x9E81,0x5E40,0x5A00,0x9AC1,0x9B81,0x5B40,0x9901,0x59C0,0x5880,0x9841,
  0x8801,0x48C0,0x4980,0x8941,0x4B00,0x8BC1,0x8A81,0x4A40,0x4E00,0x8EC1,0x8F81,0x4F40,0x8D01,0x4DC0,0x4C80,0x8C41,
  0x4400,0x84C1,0x8581,0x4540,0x8701,0x47C0,0x4680,0x8641,0x8201,0x42C0,0x4380,0x8341,0x4100,0x81C1,0x8081,0x4040
//CRC位域8查表算法(小端):
unsigned int GetCRCR16_A001_FFFF_0000_Table(unsigned char *crcBuff, unsigned char crcLen) {
unsigned char i;
unsigned int crc = 0xFFFF;
  for(i = 0; i < crcLen; i ++) {
    crc = (crc >> 8) ^ CRCR16_A001_Table[(crc & 0xFF) ^ crcBuff];
  return crc;
void main() {
const unsigned char dataTable[] = "\x01\x23\x45\x67\x89\xAB\xCD\xEF";
unsigned int crc;
  crc = GetCRCR16_A001_FFFF_0000_Table((unsigned char *)dataTable, sizeof(dataTable) - 1);
  while(1);
hotpower 发表于 2010-9-5 12:29 | 显示全部楼层
//CRC位域4表(小端):
const unsigned int CRCR16_A001_Table[16] = {
  0x0000,0xCC01,0xD801,0x1400,0xF001,0x3C00,0x2800,0xE401,0xA001,0x6C00,0x7800,0xB401,0x5000,0x9C01,0x8801,0x4400
//CRC位域4查表算法(小端):
unsigned char i;
unsigned char crcTemp;
  for(i = 0; i < (crcLen * 2); i ++) {
    if (i & 1) crcTemp = crcBuff[i >> 1] >> 4;
    else crcTemp = crcBuff[i >> 1] & 0x0F;
    crc = (crc >> 4) ^ CRCR16_A001_Table[(crc & 0x0F) ^ crcTemp];
  return crc;
void main() {
unsigned int crc;
  while(1);
