我的PT2272的Dout没有输出是怎么回事啊?
2859|4
 楼主| lxk419 发表于 2008-8-3 02:43 | 显示全部楼层 |阅读模式
我做的红外遥控用的是PT2260和PT2272,用万用表测是接收管能够接受到信号,但为什么没有输出呢。是不是编码之类的弄错了???请高手指教!!!!
hch 发表于 2008-8-3 06:57 | 显示全部楼层
编码脚和 振荡电阻详细对一下
 楼主| lxk419 发表于 2008-8-3 11:51 | 显示全部楼层
编码脚全是悬浮的,
我的编码脚全是悬浮的,而震荡电阻一个是470一个是1M这样可以嘛?<br />
 楼主| lxk419 发表于 2008-8-3 23:08 | 显示全部楼层
datasheet上说用440k和1M啊
PT2262-IR&nbsp;is&nbsp;specially&nbsp;designed&nbsp;for&nbsp;infrared&nbsp;remote&nbsp;control&nbsp;applications&nbsp;and&nbsp;its&nbsp;output&nbsp;waveform<br />carries&nbsp;38KHz&nbsp;frequency.&nbsp;To&nbsp;get&nbsp;the&nbsp;38KHz&nbsp;carrier&nbsp;frequency&nbsp;at&nbsp;the&nbsp;data&nbsp;output,&nbsp;the&nbsp;oscillator<br />frequency&nbsp;must&nbsp;be&nbsp;76KHz.&nbsp;A&nbsp;440KΩ&nbsp;resistor&nbsp;connected&nbsp;between&nbsp;OSC1&nbsp;and&nbsp;OSC2&nbsp;pins&nbsp;of&nbsp;PT2262-IR<br />is&nbsp;recommended.&nbsp;Moreover,&nbsp;for&nbsp;a&nbsp;matching&nbsp;decoder&nbsp;frequency,&nbsp;1MΩ&nbsp;resistor&nbsp;connected&nbsp;between&nbsp;the<br />OSC1&nbsp;and&nbsp;OSC2&nbsp;pins&nbsp;of&nbsp;PT2272&nbsp;is&nbsp;also&nbsp;recommended<br />我用470和1M影响大不大?
dhh278 发表于 2008-8-4 17:23 | 显示全部楼层
PT2260与2262是一样的不
