The LT®3080 is a 1.1A low dropout linear regulator that can
be paralleled to increase output current or spread heat in
surface mounted boards. Architected as a precision cur-
rent source and voltage follower allows this new regulator
to be used in many applications requiring high current,
Output Current: 1.1A
