源码: 一款运行于 S3C2450 的 GPS测试软件,带界面
11474|3
 楼主| liuwei0908 发表于 2010-10-15 20:16 | 显示全部楼层 |阅读模式
ADS工程文件:
源码:
#include        "Include.h"
const        U32                __HeapSize                        =4096;
const        U32                __StackSize                        =2048;
const        U32                __Priority                        =200;
const        char        __Name[32]                        ="GPS测试软件";
const        U32                __Icon                                =0;
const        char        __IconPath[32]                ="0.bmp";
const        char        __Version[8]                ="V1.0";
const        char        __Date[16]                        =__DATE__;
const        char        __Time[16]                        =__TIME__;
const        char        __Desc[32]                        ="Copyright:Liuwei";
HANDLE        hInst;
typedef        struct        PLANETINFO
        U8        ID;
        U8        RSS;
}PLANENTINFO;
HANDLE        hdev_com1;
char         buf[128];
char        gpgsv[128];        //GNSS 天空範圍內的衛星
char        gpgga[128];        //衛星定位定位資訊
char        gprmc[128];        //衛星定位定位資訊
char        gpvtg[128];        //對地方向及對地速度
char        gpmss[128];        //MSK 接收訊號
float        time,longitude,latitude,speed,way;
U32                date;
U32                state,NS,WE;
U32                code;
U32                planet_num;        //可用卫星数
float        precision;        //精度
float        height;        //海拔高度
float        ave_height;        //平均高度
U32                unit0;
U32                unit1;
HWND        hWndUI;
HANDLE hThread;
int        rx_exit=0;
PLANENTINFO        PlanetInfo[12];
static        int        gps_rdy=0;
static        int        __strcpy(char *dst,char *src)
        while(1)
                *dst++=*src;
                if(*src=='\0')        break;
                src++;
nmea数据如下:
$GPGGA,121252.000,3937.3032,N,11611.6046,E,1,05,2.0,45.9,M,-5.7,M,,0000*77
$GPRMC,121252.000,A,3958.3032,N,11629.6046,E,15.15,359.95,070306,,,A*54
$GPVTG,359.95,T,,M,15.15,N,28.0,K,A*04
$GPGGA,121253.000,3937.3090,N,11611.6057,E,1,06,1.2,44.6,M,-5.7,M,,0000*72
$GPGSA,A,3,14,15,05,22,18,26,,,,,,,2.1,1.2,1.7*3D
$GPGSV,3,1,10,18,84,067,23,09,67,067,27,22,49,312,28,15,47,231,30*70
$GPGSV,3,2,10,21,32,199,23,14,25,272,24,05,21,140,32,26,14,070,20*7E
$GPGSV,3,3,10,29,07,074,,30,07,163,28*7D
说明:NMEA0183格式以“$”开始,主要语句有GPGGA,GPVTG,GPRMC等
1、 GPS DOP and Active Satellites(GSA)当前卫星信息
$GPGSA,<1>,<2>,<3>,<3>,,,,,<3>,<3>,<3>,<4>,<5>,<6>,<7><CR><LF>
$GPGSA,A,3,16,23,31,32,14,,,,,,,,1.53,1.20,0.95*0A
<1>模式 :M = 手动, A = 自动。
<2>定位型式 1 = 未定位, 2 = 二维定位, 3 = 三维定位。
<3>PRN 数字:01 至 32 表天空使用中的卫星编号,最多可接收12颗卫星信息。
<4> PDOP位置精度因子(0.5~99.9)
<5> HDOP水平精度因子(0.5~99.9)
<6> VDOP垂直精度因子(0.5~99.9)
<7> Checksum.(检查位).
2、 GPS Satellites in View(GSV)可见卫星信息
$GPGSV, <1>,<2>,<3>,<4>,<5>,<6>,<7>,?<4>,<5>,<6>,<7>,<8><CR><LF>
$GPGSV,3,2,12,42,39,118,,32,38,225,20,20,34,252,,31,34,060,34*76
<1> GSV语句的总数
<2> 本句GSV的编号
<3> 可见卫星的总数,00 至 12。
<4> 卫星编号, 01 至 32。
<5>卫星仰角, 00 至 90 度。
<6>卫星方位角, 000 至 359 度。实际值。
<7>讯号噪声比(C/No), 00 至 99 dB;无表未接收到讯号。
<8>Checksum.(检查位).
第<4>,<5>,<6>,<7>项个别卫星会重复出现,每行最多有四颗卫星。其余卫星信息会于次一行出现,若未使用,这些字段会空白。
3、Global Positioning System Fix Data(GGA)GPS定位信息
$GPGGA,<1>,<2>,<3>,<4>,<5>,<6>,<7>,<8>,<9>,M,<10>,M,<11>,<12>*hh<CR><LF>
$GPGGA,050458.000,2459.8991,N,10242.8698,E,1,5,1.20,1885.0,M,-32.2,M,,*45
<1> UTC时间,hhmmss(时分秒)格式
<2> 纬度ddmm.mmmm(度分)格式(前面的0也将被传输)
<3> 纬度半球N(北半球)或S(南半球)
<4> 经度dddmm.mmmm(度分)格式(前面的0也将被传输)
<5> 经度半球E(东经)或W(西经)
<6> GPS状态:0=未定位,1=非差分定位,2=差分定位,6=正在估算
<7> 正在使用解算位置的卫星数量(00~12)(前面的0也将被传输)
<8> HDOP水平精度因子(0.5~99.9)
<9> 海拔高度(-9999.9~99999.9)
<10> 地球椭球面相对大地水准面的高度
<11> 差分时间(从最近一次接收到差分信号开始的秒数,如果不是差分定位将为空)
<12> 差分站ID号0000~1023(前面的0也将被传输,如果不是差分定位将为空)
4、Recommended Minimum Specific GPS/TRANSIT Data(RMC)推荐定位信息
$GPRMC,<1>,<2>,<3>,<4>,<5>,<6>,<7>,<8>,<9>,<10>,<11>,<12>*hh<CR><LF>
$GPRMC,050459.000,A,2459.8990,N,10242.8698,E,0.67,158.73,190808,,,A*6A
<2> 定位状态,A=有效定位,V=无效定位
<3> 纬度ddmm.mmmm(度分)格式(前面的0也将被传输)
<4> 纬度半球N(北半球)或S(南半球)
<5> 经度dddmm.mmmm(度分)格式(前面的0也将被传输)
<6> 经度半球E(东经)或W(西经)
<7> 地面速率(000.0~999.9节,前面的0也将被传输)
<8> 地面航向(000.0~359.9度,以真北为参考基准,前面的0也将被传输)
<9> UTC日期,ddmmyy(日月年)格式
<10> 磁偏角(000.0~180.0度,前面的0也将被传输)
<11> 磁偏角方向,E(东)或W(西)
<12> 模式指示(仅NMEA0183 3.00版本输出,A=自主定位,D=差分,E=估算,N=数据无效)
5、 Track Made Good and Ground Speed(VTG)地面速度信息
$GPVTG,<1>,T,<2>,M,<3>,N,<4>,K,<5>*hh<CR><LF>
<1> 以真北为参考基准的地面航向(000~359度,前面的0也将被传输)
<2> 以磁北为参考基准的地面航向(000~359度,前面的0也将被传输)
<3> 地面速率(000.0~999.9节,前面的0也将被传输)
<4> 地面速率(0000.0~1851.8公里/小时,前面的0也将被传输)
<5> 模式指示(仅NMEA0183 3.00版本输出,A=自主定位,D=差分,E=估算,N=数据无效)
void        gps_rx_thread(void *p)
        char dat;
        int i;
        DCB dcb;
        U32        v[20];
        U32 event;
        if(DeviceIoCtrl(hdev_com1,CMD_COM_GET_DCB,0,&dcb))
                dcb.BaudRate=9600;
                DeviceIoCtrl(hdev_com1,CMD_COM_SET_DCB,0,&dcb);
        i=0;
        while(rx_exit==0)
                event=DeviceWaitEvent(hdev_com1,0);
                if(event==EVT_COM_RXCHAR)
                        DeviceRead(hdev_com1,0,&dat,1);
                        buf[i++]=dat;
                        if((i>=127)||(dat=='\r')||(dat=='\n'))
                                buf[i]='\0';
                                i=0;
                                gps_rdy=1;
                                if(buf[0]=='$')
                                if(buf[1]=='G')
                                if(buf[2]=='P')
                                if(buf[3]=='G')
                                if(buf[4]=='S')
                                if(buf[5]=='V')
                                        __strcpy(gpgsv,buf);
                                        StrScanf(gpgsv,        "$GPGSV,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d"
        ,&v[0],&v[1],&v[2],&v[3],&v[4],&v[5],&v[6],&v[7],&v[8],&v[9]
        ,&v[10],&v[11],&v[12],&v[13],&v[14],&v[15],&v[16],&v[17],&v[18]);
                                        if(v[1]==1)
                                                PlanetInfo[0].ID        =v[3];
                                                PlanetInfo[0].RSS        =v[6];
                                                PlanetInfo[1].ID        =v[7];
                                                PlanetInfo[1].RSS        =v[10];
                                                PlanetInfo[2].ID        =v[11];
                                                PlanetInfo[2].RSS        =v[14];
                                                PlanetInfo[3].ID        =v[15];
                                                PlanetInfo[3].RSS        =v[18];
                                        if(v[1]==2)
                                                PlanetInfo[4].ID        =v[3];
                                                PlanetInfo[4].RSS        =v[6];
                                                PlanetInfo[5].ID        =v[7];
                                                PlanetInfo[5].RSS        =v[10];
                                                PlanetInfo[6].ID        =v[11];
                                                PlanetInfo[6].RSS        =v[14];
                                                PlanetInfo[7].ID        =v[15];
                                                PlanetInfo[7].RSS        =v[18];
                                        if(v[1]==3)
                                                PlanetInfo[8].ID        =v[3];
                                                PlanetInfo[8].RSS        =v[6];
                                                PlanetInfo[9].ID        =v[7];
                                                PlanetInfo[9].RSS        =v[10];
                                                PlanetInfo[10].ID        =v[11];
                                                PlanetInfo[10].RSS        =v[14];
                                                PlanetInfo[11].ID        =v[15];
                                                PlanetInfo[11].RSS        =v[18];
                                                InvalidateRect(hWndUI,0,0);
                                if(buf[0]=='$')
                                if(buf[1]=='G')
                                if(buf[2]=='P')
                                if(buf[3]=='G')
                                if(buf[4]=='G')
                                if(buf[5]=='A')
                                        __strcpy(gpgga,buf);
                                        //$GPGGA,121253.000,3937.3090,N,11611.6057,E,1,06,1.2,44.6,M,-5.7,M,,0000*72
                                        StrScanf(gpgga,"$GPGGA,%f,%f,%c,%f,%c,%d,%d,%f,%f,%c,%f,%c",
                                        &time,&latitude,&NS,&longitude,&WE,&code,&planet_num,&precision,&height,&unit0,&ave_height,&unit1);
                                if(buf[0]=='$')
                                if(buf[1]=='G')
                                if(buf[2]=='P')
                                if(buf[3]=='R')
                                if(buf[4]=='M')
                                if(buf[5]=='C')
                                        __strcpy(gprmc,buf);
                                        //$GPRMC,121252.000,A,3958.3032,N,11629.6046,E,15.15,359.95,070306,,,A*54
                                        StrScanf(gprmc,"$GPRMC,%f,%c,%f,%c,%f,%c,%f,%f,%d",
                                        &time,&state,&latitude,&NS,&longitude,&WE,&speed,&way,&date);
                                if(buf[0]=='$')
                                if(buf[1]=='G')
                                if(buf[2]=='P')
                                if(buf[3]=='V')
                                if(buf[4]=='T')
                                if(buf[5]=='G')
                                        __strcpy(gpvtg,buf);
                                if(buf[0]=='$')
                                if(buf[1]=='G')
                                if(buf[2]=='P')
                                if(buf[3]=='M')
                                if(buf[4]=='S')
                                if(buf[5]=='S')
                                        __strcpy(gpmss,buf);
        ExitThread(0);
static        RESULT        WinProc(HWND hwnd,U32 msg,WPARAM wParam,LPARAM lParam)
        HDC hdc;
        RECT rc;
        int        x,y,i;
        switch(msg)
                case        WM_CREATE:
                                buf[0]                =0;
                                gpgsv[0]        =0;
                                gprmc[0]        =0;
                                gpgga[0]        =0;
                                gpvtg[0]        =0;
                                gpmss[0]        =0;
                                rx_exit                =0;
                                gps_rdy                =0;
                                break;
                case        WM_TIMER:
                        //        SendMessage(hwnd,WM_CLOSE,0,0);
                                break;
                case        WM_PAINT:
                                hdc=BeginPaint(hwnd);
                                if(hdc&& (gps_rdy==1))
                                        GetClientRect(hwnd,&rc);
                                        ClrScreen(hdc,GetWindowLong(hwnd,GWL_BKCOLOR));
                                        x=2;
                                        y=2;
                                        Label(hdc,x,y,rc.dx-4,20,RGB(200,0,0),GetWindowBkColor(hwnd),RGB(0,0,0),LEFT,gpgsv);
                                        y+=19;
                                        Label(hdc,x,y,rc.dx-4,20,RGB(200,0,0),GetWindowBkColor(hwnd),RGB(0,0,0),LEFT,gprmc);
                                        y+=19;
                                        Label(hdc,x,y,rc.dx-4,20,RGB(200,0,0),GetWindowBkColor(hwnd),RGB(0,0,0),LEFT,gpgga);
                                        y+=19;
                                        Label(hdc,x,y,rc.dx-4,20,RGB(200,0,0),GetWindowBkColor(hwnd),RGB(0,0,0),LEFT,gpvtg);
                                        y+=19;
                                        if(1);
                                                char buf[64];
                                                //&time,&state,&latitude,&NS,&longitude,&WE,&speed,&way,&date;
                                                StrPrintf(buf,"坐标: %.4f%c,%.4f%c  ",latitude/100,NS,longitude/100,WE);
                                                DrawText(hdc,x,y,rc.dx-4,20,RGB(0,0,100),GetWindowBkColor(hwnd),LEFT,buf);
                                                y+=16;
                                                StrPrintf(buf,"速度: %.2f  ",speed);
                                                y+=16;
                                                StrPrintf(buf,"方向: %.2f  ",way);
                                                y+=16;
                                                StrPrintf(buf,"卫星数: %d  ",planet_num);
                                                y+=16;
                                                StrPrintf(buf,"水平精度: %.2fM  ",precision);
                                                y+=16;
                                                StrPrintf(buf,"海拔高度: %.2f%c  ",height,unit0);
                                                y+=16;
                                                StrPrintf(buf,"平均高度: %.2f%c  ",ave_height,unit1);
                                                y+=16;
                                        if(1)
                                                char buf[8];
                                                x=rc.dx-(12*20);
                                                y=5*20;
                                                for(i=0;i<12;i++)
                                                        if(i<planet_num)
        StrPrintf(buf,"%d",PlanetInfo[i].ID);
        VProgressBar(hdc,x+i*20,y,16,80,RGB(200,0,0),GetWindowLong(hwnd,GWL_BKCOLOR),RGB(0,0,0),100,PlanetInfo[i].RSS);
        DrawText(hdc,x+i*20,y,16,80,RGB(240,240,240),RGB_TRANS,CENTER,buf);
                                                        else
        VProgressBar(hdc,x+i*20,y,16,80,RGB(200,0,0),GetWindowLong(hwnd,GWL_BKCOLOR),RGB(0,0,0),100,0);
                                                y+=80;
                                                DrawText(hdc,x,y,rc.dx-x,20,RGB(0,0,128),RGB_TRANS,CENTER,"GPS卫星信号强度");
                                EndPaint(hwnd,hdc);
                                break;
                case        WM_CLOSE:
                                if(MessageBox(hwnd,"确定要退出程序吗?","信息",MB_YESNO|MB_ICONQUESTION)==IDYES)
                                        if(hdev_com1)
                                                //it=1;
                                                TerminateThread(hThread,0);
                                                DeviceClose(hdev_com1,0);
                                        DestroyWindow(hwnd);
                                break;
                case        WM_DESTROY:
                                PostQuitMessage(hwnd);
                                break;
                default:
                return        DefWindowProc(hwnd,msg,wParam,lParam);
//__KERNEL_H__
int        WinMain(HANDLE hInstance,void *argv)
        HWND hwnd;
        MSG msg;
        WNDCLASS wcls;
        hInst        =hInstance;
        wcls.lpClassName        =(char*)__Name;
        wcls.Style                        =0;
        wcls.lpfnProc                =WinProc;
        wcls.hIcon                        =0;
        wcls.hIconSm                =0;
        wcls.hCursor                =0;
        wcls.BkColor                =RGB(160,160,160);
        hwnd        =CreateWindow(        &wcls,(char*)__Name,WS_OVERLAPPEDWINDOW,
                                                        20,30,480,240,
                                                        NULL,NULL,hInst,NULL);
        hWndUI        =hwnd;
        ShowWindow(hwnd,SW_SHOW);
        hdev_com1        =DeviceOpen("COM1",0);
        if(hdev_com1)
                hThread=CreateThread(gps_rx_thread,0,8192,10,0);
        else
                MessageBox(hwnd,"打开串口失败!","错误",MB_OK|MB_ICONERROR);
        while(GetMessage(&msg,hwnd))
                TranslateMessage(&msg);
                DispatchMessage(&msg);
        return msg.lParam
 楼主| liuwei0908 发表于 2010-10-15 20:19 | 显示全部楼层
软件运行效果:
 楼主| liuwei0908 发表于 2010-10-15 20:27 | 显示全部楼层
使用的GPS模块:
