// F04x_UART0_INT.c
// Copyright 2006 Silicon Laboratories, Inc.
// http://www.silabs.com
// Program Description:
// This program demonstrates how to configure the C8051F040 to write to and read
// from the UART interface. The program reads a word using the UART0 interrupts
// and outputs that word to the screen, with all characters in uppercase
// How To Test:
// 1) Download code to a 'F04x device that is connected to a UART transceiver
// 2) Verify jumpers J6 and J9 are populated on the 'F04x TB.
// 3) Connect serial cable from the transceiver to a PC
// 4) On the PC, open HyperTerminal (or any other terminal program) and connect
// to the COM port at <BAUDRATE> and 8-N-1
// 5) Type up to 64 characters into the Terminal and press Enter. The MCU
// will then print back the characters that were typed
// Target: C8051F04x
// Tool chain: Keil C51 7.50 / Keil EVAL C51
// Command Line: None
// Release 1.0
// -Initial Revision (SM)
// -10 JULY 2007
// Includes
#include <C8051F040.h> // SFR declarations
#include <stdio.h>
// 16-bit SFR Definitions for 'F04x
sfr16 RCAP2 = 0xCA; // Timer2 capture/reload
sfr16 TMR2 = 0xCC; // Timer2
// Global Constants
#define BAUDRATE 115200 // Baud rate of UART in bps
// SYSTEMCLOCK = System clock frequency in Hz
#define SYSTEMCLOCK 22118400L
// Function Prototypes
void OSCILLATOR_Init (void);
void PORT_Init (void);
void UART0_Init (void);
// Global Variables
#define UART_BUFFERSIZE 64
unsigned char UART_Buffer[UART_BUFFERSIZE];
unsigned char UART_Buffer_Size = 0;
unsigned char UART_Input_First = 0;
unsigned char UART_Output_First = 0;
unsigned char TX_Ready =1;
static char Byte;
// main() Routine
void main (void)
SFRPAGE = CONFIG_PAGE;
WDTCN = 0xDE; // Disable watchdog timer
WDTCN = 0xAD;
OSCILLATOR_Init (); // Initialize oscillator
PORT_Init (); // Initialize crossbar and GPIO
UART0_Init (); // Initialize UART0
EA = 1;
SFRPAGE = UART0_PAGE;
while (1)
// If the complete word has been entered via the terminal followed
// by carriage return
if((TX_Ready == 1) && (UART_Buffer_Size != 0) && (Byte == 13))
TX_Ready = 0; // Set the flag to zero
TI0 = 1; // Set transmit flag to 1
// Initialization Subroutines
// OSCILLATOR_Init
// Return Value : None
// Parameters : None
// This function initializes the system clock to use an external 22.1184MHz
// crystal.
int i; // Software timer
char SFRPAGE_SAVE = SFRPAGE; // Save Current SFR page
SFRPAGE = CONFIG_PAGE; // Set SFR page
OSCICN = 0x80; // Set internal oscillator to run
// at its slowest frequency
CLKSEL = 0x00; // Select the internal osc. as
// the SYSTEMCLOCK source
// Initialize external crystal oscillator to use 22.1184 MHz crystal
OSCXCN = 0x67; // Enable external crystal osc.
for (i=0; i < 256; i++); // Wait at least 1ms
while (!(OSCXCN & 0x80)); // Wait for crystal osc to settle
CLKSEL = 0x01;
// Select external crystal as SYSTEMCLOCK source
SFRPAGE = SFRPAGE_SAVE; // Restore SFRPAGE
// PORT_Init
// This function configures the crossbar and GPIO ports.
// Pinout:
// P0.0 digital push-pull UART TX
// P0.1 digital open-drain UART RX
// P1.6 digital push-pull LED
XBR0 = 0x04; // Enable UART0
XBR1 = 0x00;
XBR2 = 0x40; // Enable crossbar and weak pull-up
P0MDOUT |= 0x01; // Set TX pin to push-pull
P1MDOUT |= 0x40; // Set P1.6(LED) to push-pull
SFRPAGE = SFRPAGE_SAVE; // Restore SFR page
// UART0_Init Variable baud rate, Timer 2, 8-N-1
// Configure UART0 for operation at <BAUDRATE> 8-N-1 using Timer2 as
// baud rate source.
char SFRPAGE_SAVE;
SFRPAGE_SAVE = SFRPAGE; // Preserve SFRPAGE
SFRPAGE = TMR2_PAGE;
TMR2CN = 0x00; // Timer in 16-bit auto-reload up timer
// mode
TMR2CF = 0x08; // SYSCLK is time base; no output;
// up count only
RCAP2 = - ((long) SYSTEMCLOCK/BAUDRATE/16);
TMR2 = RCAP2;
TR2= 1; // Start Timer2
SCON0 = 0x50; // 8-bit variable baud rate;
// 9th bit ignored; RX enabled
// clear all flags
SSTA0 = 0x15; // Clear all flags; enable baud rate
// doubler (not relevant for these
// timers);
// Use Timer2 as RX and TX baud rate
// source;
ES0 = 1;
IP |= 0x10;
// Interrupt Service Routines
// UART0_Interrupt
// This routine is invoked whenever a character is entered or displayed on the
// Hyperterminal.
void UART0_Interrupt (void) interrupt 4
if (RI0 == 1)
// Check if a new word is being entered
if( UART_Buffer_Size == 0) {
UART_Input_First = 0; }
RI0 = 0;
Byte = SBUF0; // Read a character from Hyperterminal
if (UART_Buffer_Size < UART_BUFFERSIZE)
UART_Buffer[UART_Input_First] = Byte;
UART_Buffer_Size++; // Update array's size
UART_Input_First++; // Update counter
if (TI0 == 1) // Check if transmit flag is set
TI0 = 0;
if (UART_Buffer_Size != 1) // If buffer not empty
// Check if a new word is being output
if ( UART_Buffer_Size == UART_Input_First ) {
UART_Output_First = 0; }
Byte = UART_Buffer[UART_Output_First];
if ((Byte >= 0x61) && (Byte <= 0x7A)) { // If upper case letter
Byte -= 32; }
SBUF0 = Byte; // Transmit to Hyperterminal
UART_Output_First++; // Update counter
UART_Buffer_Size--; // Decrease array size
else
UART_Buffer_Size = 0; // Set the array size to 0
TX_Ready = 1; // Transmission complete
// End Of File
