这是一个TI的5438例程,其中一句一直搞不清楚是什么意思,为什么这么用,头文件里也没有这样的定义。 就是其中黑体的那一句,请求路过的高手解答一下,谢谢
include "msp430x54x.h"
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer - SET BREAKPOINT HERE
P1DIR |= 0x01; // Set P1.0 to output direction
TA0R = 0x3FFF; // Valid opcode (for "jmp $")
while(1)
P1OUT ^= 0x01; // Toggle P1.0 using exclusive-OR
__delay_cycles(50000); // Delay loop
// C code to directly call an address location
((void (*)())0x350)(); // Invalid fetch ("call #0350h")
/* 0x350 is address of TA0R register and is within the module register memory
address range (0x0100 --0x0FEF) */
