MSP430F1611Flash数组写入
3110|2
 楼主| lilingdz 发表于 2010-11-23 17:01 | 显示全部楼层 |阅读模式
当我把定义的一个数组写入FLASH里时,只能写入第一个数,后面的数都写不进去了,程序如下,那些路过的高手解答一下吧!!感激不尽!!!
#include "msp430x16x.h"
#define uint unsigned int
#define uchar unsigned char
#define Flase_add 0x5000
void Erasure_Flash_Segment(uint add);//段擦除
void Writ_Flash_Word(uchar data,uint add);//字写
void Bcs_Init(void);//系统时钟初始化
void Flash_Init(void);//flase 初始化
uchar DataBuff[6]={1,2,3,4,5,6};
void main()
        WDTCTL = WDTPW + WDTHOLD;//stup wdt
        Bcs_Init();
        Flash_Init();
        uchar i;
    uint *Flase_p;
    uchar *Data_p;
    *Flase_p = Flase_add;
    Data_p = &DataBuff[0];
    Erasure_Flash_Segment(Flase_add);
    Writ_Flash_Word(1,0x5200);
        for(i = 0; i < 6; i++)
        Writ_Flash_Word(*Data_p,*Flase_p);
        Data_p++;
        Flase_p++;
        Writ_Flash_Word(1,0x52a0);
        while(1);
void Bcs_Init(void)
        uchar i;
        BCSCTL1 &= ~XT2OFF;//open oxt2
        do
                        IFG1 &= ~OFIFG;//clear ofifg
                        for(i = 0xff; i > 0; i--);//wait
        while(IFG1 & OFIFG);
        BCSCTL2 |= SELM_2 + SELS + DIVS_3;//mclk = xt2 = smclk/8
        FCTL2 = FWKEY + FSSEL_2 + FN2;//fclk = smclk/4=250k
        uint *ps;
        ps = (uint *)add;
        while(FCTL3 & BUSY);                        //flash是否忙
        FCTL1 = FWKEY + ERASE;                        //擦除
        FCTL3 = FWKEY;                                        //clear lock
        *ps = 0x00;                                                //erasur
        FCTL3 = FWKEY + LOCK;                        //open lock
        uchar * pw;
        pw = (uchar *)add;
        FCTL1 = FWKEY + WRT;                        //word writ
        * pw = data;                                                //writ
        FCTL1 = FWKEY;                                        //clear writ
 楼主| lilingdz 发表于 2010-11-23 17:02 | 显示全部楼层
在运行Writ_Flash_Word(1,0x5200);
的时候都能正常写入!!
bit6019 发表于 2011-1-2 20:11 | 显示全部楼层
这么久了不知道楼主解决没?
