107 的SPI2 怪问题!
1962|1
 楼主| huixiesui 发表于 2010-12-12 14:39 | 显示全部楼层 |阅读模式
#define ADC_Pin_CS  GPIO_Pin_12//PB
#define ADC_Pin_SCLK GPIO_Pin_13//PB
#define ADC_Pin_DOUT GPIO_Pin_14//PB
#define ADC_Pin_DIN  GPIO_Pin_15//PB
#define ADC_Pin_SYNC GPIO_Pin_8//PD
#define ADC_GPIO_CS  GPIOB//PB
#define ADC_GPIO_SCLK GPIOB//PB
#define ADC_GPIO_DOUT GPIOB//PB
#define ADC_GPIO_DIN GPIOB//PB
#define ADC_GPIO_SYNC GPIOD//PD
#define ADC_SPI   SPI2//
void ADC_GPIO_Init(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOD , ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Pin = ADC_Pin_SYNC;
GPIO_Init(ADC_GPIO_SYNC , &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = ADC_Pin_SCLK;
GPIO_Init(ADC_GPIO_SCLK, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Pin = ADC_Pin_DIN;
GPIO_Init(ADC_GPIO_DIN, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_InitStructure.GPIO_Pin = ADC_Pin_DOUT;
GPIO_Init(ADC_GPIO_DOUT, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = ADC_Pin_CS;
GPIO_Init(ADC_GPIO_CS, &GPIO_InitStructure);
ADC_CS(H);
ADC_SYNC(H);
void ADC_SPI_Init(void)
SPI_InitTypeDef   SPI_InitStructure;
/* SPI1 configuration ------------------------------------------------------*/
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;//;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(ADC_SPI, &SPI_InitStructure);
/*Enable SPIx.NSS as a GPIO*/
SPI_SSOutputCmd(ADC_SPI, ENABLE);
SPI_Cmd(ADC_SPI, ENABLE);
uint16_t ADC_RW(uint16_t data)
    while (SPI_I2S_GetFlagStatus(ADC_SPI, SPI_I2S_FLAG_TXE) == RESET);
    /* Send SPIx data */
    SPI_I2S_SendData(ADC_SPI, data);
    while (SPI_I2S_GetFlagStatus(ADC_SPI, SPI_I2S_FLAG_RXNE) == RESET);
return SPI_I2S_ReceiveData(ADC_SPI);;
ADC_RW(0xAA);
SCLK 输出低电平! MOSI有数据输出. SCLK 无信号
但是添加代码运行
  GPIO_SetBits(ADC_GPIO_SCLK,ADC_Pin_SCLK);
  GPIO_ResetBits(ADC_GPIO_SCLK,ADC_Pin_SCLK);
引脚电平则有高低输出 上面配置不变
实在搞不懂是什么问题了.求高手解答....
(I/O 口全部悬空测量)
 楼主| huixiesui 发表于 2010-12-13 14:47 | 显示全部楼层
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; <--- 测试的时候改了忘记改回来. 问题原因
