能帮我看看本程序吗谢谢啦
1643|1
 楼主| youngcraft 发表于 2011-1-15 09:46 | 显示全部楼层 |阅读模式
TI, tc, UART, RTC, TE
#include <string.h>
#include <math.h>
#include "option.h"
#include "def.h"
#include "44b.h"
#include "44blib.h"
#define READ_COUNT2 (rTCNTO2 & 0xffff)
#define MaxBeepFreq 50000
#define MinBeepFreq 20
extern int  Uart_GetIntNum(void);
void SetBeepPwm(unsigned short Freq, unsigned char HiRatio);
void StopBeepPwm(void);
void __irq TIMER2_int(void);
void Isr_Init(void);
void HaltUndef(void);
void HaltSwi(void);
void HaltPabort(void);
void HaltDabort(void);
int pwmcnt=0;
* pwm2  timer test  *
void Main(void)
int beginf, endf;
int  i, j;
rSYSCFG=SYSCFG_8KB;
#if (PLLON==1)
ChangePllValue(PLL_M,PLL_P,PLL_S);
#endif
Isr_Init();
Port_Init();
//Uart_Init(0,115200);
//Uart_Select(0);
//Uart_Printf("[PWM2  Test]\n");
//Uart_Printf("输入起始频率= (%d--%d): ", MinBeepFreq,MaxBeepFreq);
beginf = 100;
//Uart_GetIntNum();
//while (beginf<MinBeepFreq ||beginf>=MaxBeepFreq){
  //Uart_Printf("ERROR !!!!  input begin f= (%d--%d): ", MinBeepFreq,MaxBeepFreq);
  //beginf = Uart_GetIntNum();
//Uart_Printf("输入终止频率= (%d--%d): ", MinBeepFreq,MaxBeepFreq);
endf =500;//改为200!!!!!
// Uart_GetIntNum();
//while (endf<MinBeepFreq ||endf>=MaxBeepFreq ||endf < beginf ){
  //Uart_Printf("ERROR !!!!  input end f> beginf   (%d--%d) : ",MinBeepFreq,MaxBeepFreq);
  //endf = Uart_GetIntNum();
//Uart_Printf("起始频率= %d ; 终止频率=%d : ", beginf, endf );
rINTCON = 5;
rINTMOD = 0;
rINTMSK=~(BIT_GLOBAL|BIT_TIMER2);
pISR_TIMER2= (unsigned  int)TIMER2_int;   //(unsigned)
rPDATE = 0x157;    //Beep = 10
rPCONE = 0x596b;      // tout2
rPUPE  = 0xff;
for(i=beginf; i<endf; i++){
  pwmcnt=0;
  SetBeepPwm( i, 1);
  for (pwmcnt=0,j=0; pwmcnt<5;){
StopBeepPwm();
if(Freq>MaxBeepFreq)
  Freq = MaxBeepFreq;
if(HiRatio>100)
  HiRatio = 100;
rTCON   &= 0xffff0fff;   // clear manual update bit, stop Timer2
rTCFG0  &= 0xffff00ff;   // set Timer 2&3 prescaler 0
rTCFG1  &= 0xfffff0ff;   // set Timer 2 MUX 1/16
rTCFG1  |= 0x00000300;
rTCNTB2  = MCLK/(Freq*16);   //if set inverter off, when TCNT2<=TCMP2, TOUT is high, TCNT2>TCMP2, TOUT is low
rTCMPB2  = (rTCNTB2*(100-HiRatio))/100; //if set inverter on,  when TCNT2<=TCMP2, TOUT is low,  TCNT2>TCMP2, TOUT is high
rTCON |= 0x00002000;   // manual update
rTCON &= 0xffff0fff;   // clear manal update bit
rTCON   |= 0x0000d000;   // auto reload, inverter on, start Timer 2
rTCON &= ~0x1000;
rI_ISPC=BIT_TIMER2;
pwmcnt++;
return;
void Isr_Init(void)
    U32 i;
    pISR_UNDEF=(unsigned)HaltUndef;
    pISR_SWI  =(unsigned)HaltSwi;
    pISR_PABORT=(unsigned)HaltPabort;
    pISR_DABORT=(unsigned)HaltDabort;
     for(i=_RAM_STARTADDRESS;i<(_RAM_STARTADDRESS+0x20);i+=4)
*((volatile unsigned *)i)=0xEA000000+0x1FFE;
    //rINTCON=0x1;   // Vectored Int. IRQ enable,FIQ disable
    rINTCON=0x5;   // Non-vectored,IRQ enable,FIQ disable
    rINTMOD=0x0;   // All=IRQ mode
    rINTMSK|=BIT_GLOBAL|BIT_EINT3;   // All interrupt is masked.
    Uart_Printf("Undefined instruction exception!!!\n");
    while(1);
void HaltSwi(void)
    Uart_Printf("SWI exception!!!\n");
    while(1);
    Uart_Printf("Pabort exception!!!\n");
    while(1);
    Uart_Printf("Dabort exception!!!\n");
    while(1);
本程序是利用ARM的PWM功能来实现声音频率的输出
