香主,关于STM32F100用新固件库配置系统时钟的问题
4202|3
 楼主| lover3k 发表于 2011-1-22 09:21 | 显示全部楼层 |阅读模式
最近有一项目,综合比较下各方面,选择了STM32F100 的片子,也是现学现用,今天想做个SysTick的精准延时,发现新的固件库(3.0的貌似)中SysTick的函数和旧 的不一样了,新的函数库中只有SysTick_Config()这个函数了,而里面的系统时钟貌似只有
//以下为选择CPU的运行频率,系统已经默认了用户是使用8M的晶振了.
//#define SYSCLK_FREQ_HSE    HSE_Value        //这个值系统默认为8M
//#define SYSCLK_FREQ_20MHz  20000000
//#define SYSCLK_FREQ_36MHz  36000000
//#define SYSCLK_FREQ_48MHz  48000000
#define SYSCLK_FREQ_56MHz  56000000
//#define SYSCLK_FREQ_72MHz  72000000
这几种,然后新库函数中提供的定义如下:
*  Clock Definitions
#ifdef SYSCLK_FREQ_HSE
  const uint32_t SystemFrequency         = SYSCLK_FREQ_HSE;        /*!< System Clock Frequency (Core Clock) */
  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_HSE;        /*!< System clock                        */
  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_HSE;        /*!< AHB System bus speed                */
  const uint32_t SystemFrequency_APB1Clk = SYSCLK_FREQ_HSE;        /*!< APB Peripheral bus 1 (low)  speed   */
  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_HSE;        /*!< APB Peripheral bus 2 (high) speed   */
#elif defined SYSCLK_FREQ_20MHz
  const uint32_t SystemFrequency         = SYSCLK_FREQ_20MHz;      /*!< System Clock Frequency (Core Clock) */
  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_20MHz;      /*!< System clock                        */
  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_20MHz;      /*!< AHB System bus speed                */
  const uint32_t SystemFrequency_APB1Clk = SYSCLK_FREQ_20MHz;      /*!< APB Peripheral bus 1 (low)  speed   */
  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_20MHz;      /*!< APB Peripheral bus 2 (high) speed   */
#elif defined SYSCLK_FREQ_36MHz
  const uint32_t SystemFrequency         = SYSCLK_FREQ_36MHz;      /*!< System Clock Frequency (Core Clock) */
  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_36MHz;      /*!< System clock                        */
  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_36MHz;      /*!< AHB System bus speed                */
  const uint32_t SystemFrequency_APB1Clk = SYSCLK_FREQ_36MHz;      /*!< APB Peripheral bus 1 (low)  speed   */
  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_36MHz;      /*!< APB Peripheral bus 2 (high) speed   */
#elif defined SYSCLK_FREQ_48MHz
  const uint32_t SystemFrequency         = SYSCLK_FREQ_48MHz;      /*!< System Clock Frequency (Core Clock) */
  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_48MHz;      /*!< System clock                        */
  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_48MHz;      /*!< AHB System bus speed                */
  const uint32_t SystemFrequency_APB1Clk = (SYSCLK_FREQ_48MHz/2);  /*!< APB Peripheral bus 1 (low)  speed   */
  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_48MHz;      /*!< APB Peripheral bus 2 (high) speed   */
#elif defined SYSCLK_FREQ_56MHz
  const uint32_t SystemFrequency         = SYSCLK_FREQ_56MHz;      /*!< System Clock Frequency (Core Clock) */
  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_56MHz;      /*!< System clock                        */
  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_56MHz;      /*!< AHB System bus speed                */
  const uint32_t SystemFrequency_APB1Clk = (SYSCLK_FREQ_56MHz/2);  /*!< APB Peripheral bus 1 (low)  speed   */
  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_56MHz;      /*!< APB Peripheral bus 2 (high) speed   */
#elif defined SYSCLK_FREQ_72MHz
  const uint32_t SystemFrequency         = SYSCLK_FREQ_72MHz;      /*!< System Clock Frequency (Core Clock) */
  const uint32_t SystemFrequency_SysClk  = SYSCLK_FREQ_72MHz;      /*!< System clock                        */
  const uint32_t SystemFrequency_AHBClk  = SYSCLK_FREQ_72MHz;      /*!< AHB System bus speed                */
  const uint32_t SystemFrequency_APB1Clk = (SYSCLK_FREQ_72MHz/2);  /*!< APB Peripheral bus 1 (low)  speed   */
  const uint32_t SystemFrequency_APB2Clk = SYSCLK_FREQ_72MHz;      /*!< APB Peripheral bus 2 (high) speed   */
#else /*!< HSI Selected as System Clock source */
  const uint32_t SystemFrequency         = HSI_Value;                /*!< System Clock Frequency (Core Clock) */
  const uint32_t SystemFrequency_SysClk  = HSI_Value;                /*!< System clock                        */
  const uint32_t SystemFrequency_AHBClk  = HSI_Value;                /*!< AHB System bus speed                */
  const uint32_t SystemFrequency_APB1Clk = HSI_Value;                /*!< APB Peripheral bus 1 (low)  speed   */
  const uint32_t SystemFrequency_APB2Clk = HSI_Value;                /*!< APB Peripheral bus 2 (high) speed   */
#endif
我的问题是,STM32F100的 最大频率只有24M,在这里要怎么选择呢 ?
看了网上有人试验过,说只有在选择56M 的时候SysTick延时稳定,但STM32F100最大只有24M,选56M 的话这算正常工作么?
有点不解,所以还请论坛各位朋友帮忙看看。。
香主可以讲讲么?
airwill 发表于 2011-1-22 12:30 | 显示全部楼层
看样子只能选择 20Mhz 了。
不过我也看了这段程序,不止是郁闷,是忍无可忍。
本来 简单的一个寄存器设置, 搞得这么复杂,还弄出这么多的定义来。
最后掐头去尾, 重新整了个自己用的函数。
 楼主| lover3k 发表于 2011-1-22 14:09 | 显示全部楼层
恩,很是郁闷,貌似这新函数就没考虑F100 的 片子。。
lala1008 发表于 2011-1-25 11:58 | 显示全部楼层
学习中
