让温度继续回升,这次你爱升多少就多少,只要别烫着就ok
终于,看到下载成功的信息了:
Fri Jan 21 13:57:55 2011: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 4.0 Kickstart\arm\config\flashloader\Luminary\FlashLM3Sxxxx16k.mac
Fri Jan 21 13:57:56 2011: JTAG Speed is set to: 500 kHz
Fri Jan 21 13:57:56 2011: JTAG IDCODE = 0x3BA00477
Fri Jan 21 13:57:56 2011: AHB-AP ID = 0x14770011
Fri Jan 21 13:57:56 2011: AHB-AP ROM = 0xE00FF003
Fri Jan 21 13:57:56 2011: ROM Component ID = 0xB105100D
Fri Jan 21 13:57:56 2011: Device ID = 0x00000000 ()
Fri Jan 21 13:57:56 2011: Software reset was performed
Fri Jan 21 13:57:56 2011: Initial reset was performed
Fri Jan 21 13:57:56 2011: Turning off watchdog
Fri Jan 21 13:57:58 2011: 2920 bytes downloaded and verified (1.39 Kbytes/sec)
Fri Jan 21 13:57:59 2011: Loaded debugee: C:\Program Files\IAR Systems\Embedded Workbench 4.0 Kickstart\arm\config\flashloader\Luminary\FlashLM3Sxxxx16k.d79
Fri Jan 21 13:57:59 2011: Software reset was performed
Fri Jan 21 13:57:59 2011: Target reset
Fri Jan 21 13:58:11 2011: Program exit reached.
Fri Jan 21 13:58:16 2011: 21000 bytes downloaded into FLASH and verified (1.16 Kbytes/sec)
Fri Jan 21 13:58:16 2011: Loaded debugee: E:\ECU-work\1138-1.25G6\Debug\Exe\PORT.d79
Fri Jan 21 13:58:16 2011: Target reset
