OD的是P0.x,可以双向!<br />Port 0 is an 8-bit open drain bidirectional I/O port. As an output port each pin can sink eight TTL inputs. When 1s are written to port 0 pins, the pins can be used as high-impedance inputs.<br />Port 0 may also be configured to be the multiplexed low-order address/data bus during accesses to external program and data memory. In this mode P0 has internal pullups.<br />Port 0 also receives the code bytes during Flash programming,and outputs the code bytes during program verification. External pullups are required during program verification.<br />(from ATMEL AT89C51.pdf)
