MSP430F4152 SPI 问题
2247|5
 楼主| daylilies2001 发表于 2011-3-28 21:25 | 显示全部楼层 |阅读模式
用UCB0端口做了4线的SPI,DCO倍频至2M,赋给SMCLK,SMCLK用作SPI的时钟源,但是实际量到的SPICLK只有50HZ,还请大家帮忙看一下程序的问题出在哪?谢谢!
#include "msp430f4152.h"
#define uchar unsigned char
#define uint unsigned int
void main( void )
  uint i;
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  FLL_CTL0 &=~XTS_FLL;
  FLL_CTL0 |=XCAP11PF;
  /*时钟配置*/
  SCFQCTL =SCFQ_2M;           //MCLK=64ACLK
  FLL_CTL1 &=~SMCLKOFF;       //SMCLK使能
do
    IFG1 &=~OFIFG;            //清除中断标志
    for(i=0;i<0x47ff;i++);
  }while((IFG1&OFIFG));
  P6DIR |=BIT3;
  P6OUT |=BIT3;               //P6.3置高
  /****模块初始化****/
  _BIC_SR(GIE);               //关闭总中断
  /*初始化RS232*/
  UCA0CTL1 |=UCSWRST;         //置位SWRST
  UCA0CTL0 &=~UCPEN;          //无奇偶校验
  UCA0CTL0 &=~UC7BIT;         //8位数据
  UCA0CTL0 &=~UCSPB;          //1位停止位
  UCA0CTL0 &=~(UCMODE1+UCMODE0+UCSYNC);//UART模式
  UCA0CTL1 |=UCSSEL0;         //ACLK作为时钟源
  UCA0BR0  =0x03;
  UCA0BR1  =0x00;
  UCA0MCTL =0x06;            //波特率为9600
  P6SEL |=BIT5+BIT6;          //P6.5,P6.6设置为UART模式
  UCA0CTL1 &=~UCSWRST;           //清零SWRST
  /*初始化SPI*/
  P6SEL |=BIT1+BIT2+BIT4;   //P6.1,P6.2,P6.4设置为SPI模式
  UCB0CTL1 |=UCSWRST;
  UCB0CTL0 |=UCMST+UCSYNC+UCCKPH+UCCKPL+UCMSB; //采用同步方式
// UCB0CTL0 |=UCMODE1;            //4线SPI,片选低有效
  UCB0CTL1 |=UCSSEL_2;            //SMCLK做时钟源
  UCB0BR0 =0x02;
  UCB0BR1 =0x00;                 //SPI时钟频率为4M(SMCLK)
  UCB0CTL1 &=~UCSWRST;           //清零SWRST
  IE2 |=UCA0RXIE;                  //使能RS232接收中断
// IE2 |=UCB0RXIE;                //使能SPI接收中断
  _BIS_SR(GIE);                    //使能总中断
  UCA0TXBUF =0x55;
  while((IFG2&UCA0TXIFG)==0);
  IFG2 &=~UCA0TXIFG;
                                   //置低P6.3,SPI片选端
  P6OUT &=~BIT3;
  for(i=50;i>0;i--);
  UCB0TXBUF =0x80;                //读ADXL345ID
  while((IFG2&UCB0TXIFG)==0);
  IFG2 &=~UCB0TXIFG;
  i=0;
  while((IFG2&UCB0RXIFG)==0);
  IFG2 &=~UCB0RXIFG;
  i=UCB0RXBUF;
  UCA0TXBUF=i;
  IFG2 &=~UCA0TXIFG;
  for(i=50;i>0;i--);
  P6OUT |=BIT3;
  while(1);
#pragma vector =USCIAB0RX_VECTOR
__interrupt void UART0_RX(void)
  uchar i;
  if(IFG2&UCA0RXIFG)
    IE2 &=~UCA0RXIE;
    IFG2 &=~UCA0RXIFG;
    i =UCA0RXBUF;
    UCA0TXBUF =i+1;
    IFG2 &=~UCA0TXIFG;
    IE2 |=UCA0RXIE;
  else
    IE2 &=~UCB0RXIE;
    IFG2 &=~UCB0RXIFG;
    UCA0TXBUF =0x77;
    IFG2 &=~UCA0TXIFG;
    UCA0TXBUF =UCB0RXBUF;
    IFG2 &=~UCA0TXIFG;
    IE2 |=UCB0RXIE;
riantsoul 发表于 2011-3-28 21:47 | 显示全部楼层
肯定是某个地方给分频了,2M/4了,我估计是这样子
 楼主| daylilies2001 发表于 2011-3-29 10:57 | 显示全部楼层
那也不会分成50Hz哦?
米其林r 发表于 2011-3-29 12:31 | 显示全部楼层
最近正研究!
yoyowodeai 发表于 2011-3-29 21:07 | 显示全部楼层
对SPI不懂,完全
yirongfu 发表于 2011-3-29 22:24 | 显示全部楼层
照理是1MHz,你确定测量没问题?232那一路正常不?
