求助UASRT问题
3188|0
 楼主| jiweili010 发表于 2011-3-29 10:47 | 显示全部楼层 |阅读模式
关于STM8L152的UASRT问题
我程序如下
void clock_init(void)
  //Fmaster = 8.00M
  //Fcpu = Fmaster
  CLK_SWR = 0x04;
  CLK_SWCR |= 0x02;
  Delay(1000);
  while((CLK_SWCR && 0x01 ) == 0)  // Wait switch  ready
   _NOP();
  CLK_CKDIVR = 0x00;
  CLK_ECKR |=0X01;  //使能外部时钟
  Delay(1000);
  while((CLK_ECKR && 0x02 ) == 0)  // 使能  ready
    _NOP();
  CLK_CSSR |= 0x01;
  CLK_PCKENR1 |=0X27;//开启时钟,stm8的外设时钟可控
  CLK_PCKENR2 |=0X20;//开启时钟,stm8的外设时钟可控
  SYSCFG_RMPCR1 = 0x20;
void uart0_init(void)
    USART1_BRR2 = 0x00; //disable while setting baud rate
USART1_BRR1 = 0x00;
        USART1_CR1 = 0x00;
        USART1_CR3 = 0x00;
        USART1_SR_TC = 0;
switch (data_value)
  case 0:
  USART1_CR1 |= 0x00; //异步 8位数据 1停止位 无校验
  break;
  case 2:
  USART1_CR1 |= 0x06; //异步 8位数据 1停止位 奇校验
  break;
  case 1:
  USART1_CR1 |= 0x04; //异步 8位数据 1停止位 偶校验
  break;
  default:
  break;
  //8000000/9600=0x0341
        //8000000/4800 = 0x0682
switch (baud_value)
  case 0:
  USART1_BRR2 = 0x1A; //set baud rate as 1200
   USART1_BRR1 = 0xA0;
  break;
  case 1:
  USART1_BRR2 = 0x05; //set baud rate as 2400
   USART1_BRR1 = 0xD0;
  break;
         case 2:
  USART1_BRR2 = 0x02; //set baud rate as 4800
   USART1_BRR1 = 0x68;
  break;
         case 3:
  USART1_BRR2 = 0x01; //set baud rate as 9600
   USART1_BRR1 = 0x34;
  break;
  default:
  break;
         USART1_CR2_RIEN=1;
        USART1_CR2_REN=1;
        USART1_CR2_TCIEN=0;
        USART1_CR2_TIEN=0;
        USART1_CR2_TEN=0;
RECE_485;
cnt_tras_num=0;
cnt_rece_num=0;
uar_rece_succeed=0;
uar_tras_succeed=0;
fg_now_receive=0;
checkoutError = 0;
#pragma vector=USART_R_RXNE_vector
__interrupt void uart0_rx_isr(void)
       uchar temp;
      if ((USART1_SR_FE==1)||(USART1_SR_PE==1))
checkoutError = 1;
        temp = USART1_SR;
        temp = USART1_DR;
        uar_rece_buf[cnt_rece_num] = temp;
        USART1_SR_RXNE=0;
        checkoutError = 0;
if (uar_rece_buf[0] != addr_value)
     cnt_rece_num = 0;
     checkoutError = 1;
else if (cnt_rece_num<30)
  cnt_rece_num++;
#pragma vector = USART_T_TC_vector
__interrupt void uart0_tx_isr(void)
           if (sendPosi<cnt_tras_num)
                ++sendPosi;
                USART1_DR = uar_tras_buf[sendPosi];
else
  USART1_CR2_RIEN=1;
                USART1_CR2_REN=1;
                USART1_CR2_TCIEN=0;
                USART1_CR2_TIEN=0;
                USART1_CR2_TEN=0;
RECE_485;
cnt_tras_num=0;
cnt_rece_num=0;
uar_rece_succeed=0;
uar_tras_succeed=0;
fg_now_receive=0;
checkoutError = 0;
        USART1_SR_TC = 0;
        USART1_SR_TXE = 0;
void beginSend(void)
USART1_CR2_TCIEN=1;
        USART1_CR2_TIEN=1;
        USART1_CR2_TEN=1;
        SEND_485;
sendPosi = 0;
        USART1_SR_TC = 0;
        USART1_SR_TXE = 0;
void checkComm0Modbus(void)
uint crcData;
uint tempData;
if(cnt_rece_num>1)
  switch(uar_rece_buf[1])
          case 6://设置单个寄存器
     if(cnt_rece_num >= 8)
                                                USART1_CR2_RIEN=0;
                                                USART1_CR2_REN=0;
      if((uar_rece_buf[0]==addr_value) && (checkoutError==0))
       crcData = crc16(uar_rece_buf,6);
       if(crcData == uar_rece_buf[7]+(uar_rece_buf[6]<<8))
       {//校验正确
                    if(uar_rece_buf[1] == 6)
         readRegisters();        }
                                                        else
                                                         checkoutError=1;
                                                         cnt_rece_num = 0;
                                                else if(uar_rece_buf[0]!=addr_value)
                                                 checkoutError=1;
      cnt_rece_num = 0;
     break;
   default:
                                { checkoutError=1;
                                cnt_rece_num = 0;
                                }break;
void readRegisters(void)
uint addr;
uint tempAddr;
uint crcData;
uint readCount;
uint byteCount;
uint i;
uint tempData = 0;
//起始地址
addr = (uar_rece_buf[2]<<8) + uar_rece_buf[3];
tempAddr = addr & 0xffff;
//寄存器数量
readCount = (uar_rece_buf[4]<<8) + uar_rece_buf[5]; //要读的个数
byteCount = readCount * 2;
for(i=0; i<byteCount; i+=2,tempAddr++)
  tempData = getRegisterVal(tempAddr);
  uar_tras_buf[i+3] = tempData >> 8;
  uar_tras_buf[i+4] = tempData & 0xff;
uar_tras_buf[0] = addr_value;
uar_tras_buf[1] = 0x03;
uar_tras_buf[2] = byteCount;
byteCount += 3;
crcData = crc16(uar_tras_buf,byteCount);
uar_tras_buf[byteCount] = crcData >> 8;
byteCount++;
uar_tras_buf[byteCount] = crcData & 0xff;
cnt_tras_num = byteCount + 1;
beginSend();
我主程序里循环执行的是checkComm0Modbus();
现在的问题是发送回的数据一直不正确,并且检测了一下接收到的数据,只有第一次正常,第二次就不正常了,会一直停留在接收终端中,找不到原因,求帮助
