CCS+C6678LE开发记录10:(图像)数据处理与传输框架
721|0
 楼主| qwe890asd 发表于 2017-10-7 12:55 | 显示全部楼层 |阅读模式
探索了这么久也该上一点料,本文关注PC<-->DSP数据处理与传输的简单框架。
这个框架其实也很简单,具体描述如下:
1.PC端通过ETH0发送(图像)数据到DSP
2.DSP收到完整数据后进行处理(Image Processing...)
3.DSP端数据处理完毕后将数据发回给PC
4.PC端收到发回的处理结果,然后保存
下面是一段代码,数据处理执行的操作很简单:对图像像素值取补
newValue=255-oldValue
  • int udpTransferTask( SOCKET s, UINT32 unused )
  •     printf("TASK execution %d\n",++task_counter);
  •     struct timeval tv;
  •     tv.tv_sec  = 1;
  •     tv.tv_usec = 0;
  •     setsockopt(s,SOL_SOCKET,SO_SNDTIMEO,&tv,sizeof(tv));
  •     setsockopt(s,SOL_SOCKET,SO_RCVTIMEO,&tv,sizeof(tv));
  •     struct sockaddr_in sin1;
  •     int sz=sizeof(sin1);
  •     int hlen=strlen(reply);
  •     int nr,total=0;
  •     HANDLE hBuffer=NULL;
  •     unsigned char* pBuf=NULL;
  •     int width,height,size;
  •     int i,n=sizeof(int);
  •     unsigned char* ptr=NULL;
  •     // Image width
  •     recvncfrom( s, (void**)&pBuf, 0, (PSA)&sin1, &sz, &hBuffer );
  •     recvncfree( hBuffer );
  •     ptr=(unsigned char*)&width;
  •     for(i=0;i<n;++i) ptr=pBuf;
  •     // Image height
  •     ptr=(unsigned char*)&height;
  •     // Image data size
  •     size=width*height;
  •     printf("Image Size: %d * %d\n",width,height);
  •     // Data buffer
  •     unsigned char* data=(unsigned char*)malloc(size);
  •     if(data==NULL)
  •         printf("Failed to allocate memory!\n");
  •         return 2;
  •     ptr=data;
  •     while(1)
  •         nr=recvncfrom( s, (void**)&pBuf, 0, (PSA)&sin1, &sz, &hBuffer );
  •         if(nr<=0) break;
  •         total+=nr;
  •         for(i=0;i<nr;++i)
  •             ptr=pBuf;
  •         ptr+=nr;
  •         sendto( s, reply, hlen, 0, (PSA)&sin1, sz );
  •     if(total!=size)
  •         free(data);
  •         size=0;
  •         printf("Data transfer is imcomplete!\n");
  •         return 1;
  •     processDataFrame(data,width,height);
  •     total=0;
  •     int unit=64;
  •     int loop=size/unit;
  •     int residue=size-loop*unit;
  •     pBuf=data;
  •     for(i=1;i<=loop;++i)
  •         nr=sendto(s,pBuf,unit,0,(PSA)&sin1, sz);
  •         pBuf+=unit;
  •         total+=nr;
  •     if(residue>0)
  •         nr=sendto(s,pBuf,residue,0,(PSA)&sin1, sz);
  •         total+=nr;
  •     printf("Finished sending back %dB.\n",total);
  •     free(data);
  •     return 1;
  • void processDataFrame(unsigned char* data,int width,int height)
  •     printf("Processing data...");
  •     int i, size=width*height;
  •     unsigned char tmp;
  •     for(i=0;i<size;++i)
  •         tmp=data;
  •         data=255-tmp;
  •     printf("Finished.\n");
[color=rgb(51, 102, 153) !important]复制代码
发回数据时建议设置更小的分片大小,这里设置为64字节,实测效果尚可。
