端点3发送数据出错,请教一下原因
3097|2
 楼主| rex994997787 发表于 2011-4-17 20:56 | 显示全部楼层 |阅读模式
se, ADDR, AD, DDR, TE
#define EP_NUM     (4)
#define MAX_EP1_PACKET_SIZE 0x40
#define MAX_EP2_PACKET_SIZE 0x40
/* --------------   Buffer Description Table  -----------------*/
/* buffer table base address */
#define BTABLE_ADDRESS      (0x00)
/* EP0  */
/* rx/tx buffer base address */
#define ENDP0_RXADDR        (0x20)
#define ENDP0_TXADDR        (0x60)
/* EP1  */
/* tx buffer base address */
#define ENDP1_RXADDR        (0x108)
#define ENDP1_TXADDR        (0x148)
#define ENDP2_RXADDR        (0x188)
#define ENDP2_TXADDR        (0x1c8)
//#define ENDP3_RXADDR        (0x148)
#define ENDP3_TXADDR        (0x208)
/*初始化部分*/
SetEPType(ENDP0, EP_CONTROL);
  SetEPTxStatus(ENDP0, EP_TX_STALL);
  SetEPRxAddr(ENDP0, ENDP0_RXADDR);
  SetEPTxAddr(ENDP0, ENDP0_TXADDR);
  Clear_Status_Out(ENDP0);
  SetEPRxCount(ENDP0, Device_Property.MaxPacketSize);
  SetEPRxValid(ENDP0);
  /* Initialize Endpoint 1 */
  SetEPType(ENDP1, EP_BULK);
  SetEPTxAddr(ENDP1, ENDP1_TXADDR);
  SetEPRxAddr(ENDP1, ENDP1_RXADDR);
  SetEPTxCount(ENDP1, MAX_EP1_PACKET_SIZE);
  SetEPRxCount(ENDP1, MAX_EP1_PACKET_SIZE);
  SetEPRxStatus(ENDP1, EP_RX_VALID);
  SetEPTxStatus(ENDP1, EP_TX_NAK);
  SetEPType(ENDP2, EP_BULK);
  SetEPTxAddr(ENDP2, ENDP2_TXADDR);
  SetEPRxAddr(ENDP2, ENDP2_RXADDR);
  SetEPTxCount(ENDP2, MAX_EP2_PACKET_SIZE);
  SetEPRxCount(ENDP2, MAX_EP2_PACKET_SIZE);
  SetEPRxStatus(ENDP2, EP_RX_VALID);
  SetEPTxStatus(ENDP2, EP_TX_NAK);
  SetEPType(ENDP3, EP_INTERRUPT);
  SetEPTxAddr(ENDP3, ENDP3_TXADDR);
  SetEPTxCount(ENDP3, 4);
  SetEPTxStatus(ENDP3, EP_TX_NAK);
/*发送部分*/
UserToPMABufferCopy(CardOutBuf, ENDP3_TXADDR, 2);
SetEPTxCount(ENDP3, 2);
SetEPTxStatus(ENDP3, EP_TX_VALID);
地址分配是这样的,描述符应该没错,端点三作为中断端点,原本应该发送50 02,可它却发了80 01 ,发送的数据不对,请教一下,是不是我哪里弄错了?
 楼主| rex994997787 发表于 2011-4-17 21:12 | 显示全部楼层
airwill 发表于 2011-4-18 10:07 | 显示全部楼层
恭喜楼主, 自己就找到了结果. 其实很多问题前人已经遇到过, 甚至解决过了, 搜索一下以往的相关帖子就可以了. 不过感觉 21ic 搜索相关帖子的功能不是太强, 希望网站管理者能改进一下.
