[AVR单片机] AVR开机代码求教
2253|2
 楼主| mugenwon 发表于 2011-5-22 10:13 | 显示全部楼层 |阅读模式
玩AVR不久,发现一条空的程序,但是汇编代码里面还是有不知名的代码,求教。
C程序:
void main(void)
汇编结果:
+00000000:   940C002A    JMP       0x0000002A     Jump
.......(这里没有用到,省略N行)
+0000002A:   E5CF        LDI       R28,0x5F       Load immediate
+0000002B:   E0D8        LDI       R29,0x08       Load immediate
+0000002C:   BFCD        OUT       0x3D,R28       Out to I/O location
+0000002D:   BFDE        OUT       0x3E,R29       Out to I/O location
+0000002E:   51C0        SUBI      R28,0x10       Subtract immediate
+0000002F:   40D0        SBCI      R29,0x00       Subtract immediate with carry
+00000030:   EA0A        LDI       R16,0xAA       Load immediate
+00000031:   8308        STD       Y+0,R16        Store indirect with displacement
+00000032:   2400        CLR       R0             Clear Register
+00000033:   E6E0        LDI       R30,0x60       Load immediate
+00000034:   E0F0        LDI       R31,0x00       Load immediate
+00000035:   E010        LDI       R17,0x00       Load immediate
+00000036:   36E0        CPI       R30,0x60       Compare with immediate
+00000037:   07F1        CPC       R31,R17        Compare with carry
+00000038:   F011        BREQ      PC+0x03        Branch if equal
+00000039:   9201        ST        Z+,R0          Store indirect and postincrement
+0000003A:   CFFB        RJMP      PC-0x0004      Relative jump
+0000003B:   8300        STD       Z+0,R16        Store indirect with displacement
+0000003C:   E5E4        LDI       R30,0x54       Load immediate
+0000003D:   E0F0        LDI       R31,0x00       Load immediate
+0000003E:   E6A0        LDI       R26,0x60       Load immediate
+0000003F:   E0B0        LDI       R27,0x00       Load immediate
+00000040:   E010        LDI       R17,0x00       Load immediate
+00000041:   35E4        CPI       R30,0x54       Compare with immediate
+00000042:   07F1        CPC       R31,R17        Compare with carry
+00000043:   F021        BREQ      PC+0x05        Branch if equal
+00000044:   95C8        LPM                      Load program memory
+00000045:   9631        ADIW      R30,0x01       Add immediate to word
+00000046:   920D        ST        X+,R0          Store indirect and postincrement
+00000047:   CFF9        RJMP      PC-0x0006      Relative jump
+00000048:   940E004B    CALL      0x0000004B     Call subroutine
+0000004A:   CFFF        RJMP      PC-0x0000      Relative jump
@0000004B: main
---- main.c ---------------------------------------------------------------------------------------
5:        ;
+0000004B:   9508        RET                      Subroutine return
C用ICC写,汇编用AVRstudio4看。请问那堆代码什么意思?当中还有LPM指令
 楼主| mugenwon 发表于 2011-5-22 10:33 | 显示全部楼层
已结贴??奇怪。。。
 楼主| mugenwon 发表于 2011-5-22 10:46 | 显示全部楼层
看了一下datasheet大概是配置堆栈之类的。继续看看
