FFT算法的完整DSP实现(2): FFT的DSP实现
更正 更正 。。。
上面程序中的BitReverse函数由于使用了malloc函数,当要分配的n比较大时,在DSP上运行会出现一定的问题,因此改用伪代码中提供的倒位序方法更可靠。
修正后的完整FFT代码文件粘贴如下,在实际的DSP项目中测试通过,可直接拷贝复用。
- * zx_fft.h
- * Created on: 2013-8-5
- * Author: monkeyzx
- #ifndef _ZX_FFT_H
- #define _ZX_FFT_H
- #include "../Headers/Global.h"
- #define TYPE_FFT_E float /* Type is the same with COMPLEX member */
- #ifndef PI
- #define PI (3.14159265f)
- #endif
- typedef COMPLEX TYPE_FFT; /* Define COMPLEX in Config.h */
- extern int fft(TYPE_FFT *x, int N);
- extern int ifft(TYPE_FFT *x, int N);
- #endif /* ZX_FFT_H_ */
复制代码
- * zx_fft.c
- * Implementation of Fast Fourier Transform(FFT)
- * and reversal Fast Fourier Transform(IFFT)
- * TEST OK 2014.01.14
- * == 2014.01.14
- * Replace @BitReverse(x,x,N,M) by refrence to
- * <The Scientist and Engineer's Guide to Digital Signal Processing>
- #include "zx_fft.h"
- * FFT Algorithm
- * === Inputs ===
- * x : complex numbers
- * N : nodes of FFT. @N should be power of 2, that is 2^(*)
- * === Output ===
- * the @x contains the result of FFT algorithm, so the original data
- * in @x is destroyed, please store them before using FFT.
- int fft(TYPE_FFT *x, int N)
- int i,j,l,k,ip;
- static int M = 0;
- static int le,le2;
- static TYPE_FFT_E sR,sI,tR,tI,uR,uI;
- M = (int)(log(N) / log(2));
- * bit reversal sorting
- l = N / 2;
- j = l;
- //BitReverse(x,x,N,M);
- for (i=1; i<=N-2; i++) {
- if (i < j) {
- tR = x[j].real;
- tI = x[j].imag;
- x[j].real = x.real;
- x[j].imag = x.imag;
- x.real = tR;
- x.imag = tI;
- k = l;
- while (k <= j) {
- j = j - k;
- k = k / 2;
- j = j + k;
- * For Loops
- for (l=1; l<=M; l++) { /* loop for ceil{log2(N)} */
- le = (int)pow(2,l);
- le2 = (int)(le / 2);
- uR = 1;
- uI = 0;
- sR = cos(PI / le2);
- sI = -sin(PI / le2);
- for (j=1; j<=le2; j++) { /* loop for each sub DFT */
- //jm1 = j - 1;
- for (i=j-1; i<=N-1; i+=le) { /* loop for each butterfly */
- ip = i + le2;
- tR = x[ip].real * uR - x[ip].imag * uI;
- tI = x[ip].real * uI + x[ip].imag * uR;
- x[ip].real = x.real - tR;
- x[ip].imag = x.imag - tI;
- x.real += tR;
- x.imag += tI;
- } /* Next i */
- tR = uR;
- uR = tR * sR - uI * sI;
- uI = tR * sI + uI *sR;
- } /* Next j */
- } /* Next l */
- return 0;
- * Inverse FFT Algorithm
- * === Inputs ===
- * === Output ===
- int ifft(TYPE_FFT *x, int N)
- int k = 0;
- for (k=0; k<=N-1; k++) {
- x[k].imag = -x[k].imag;
- fft(x, N); /* using FFT */
- x[k].real = x[k].real / N;
- x[k].imag = -x[k].imag / N;
- return 0;
复制代码
另外,可能还需要您在其它头文件中定义COMPLEX的复数类型
- typedef struct {
- float real;
- float imag;
- } COMPLEX;
复制代码
增加:FFT频谱结果显示
- clc;
- clear;
- % Read a real audio signal
- [fname,pname]=uigetfile(...
- {'*.wav';'*.*'},...
- 'Input wav File');
- [x fs nbits] = wavread(fullfile(pname,fname));
- % Window
- % N = 1024;
- N = size(x,1);
- x = x(1:N, 1);
- % FFT
- y = fft(x);
- % 频率对称,取N/2
- y = y(1:N/2);
- % FFT频率与物理频率转换
- x1 = 1:N/2;
- x2 = (1:N/2)*fs/(N/2); % /1000表示KHz
- log_x2 = log2(x2);
- % plot
- figure,
- subplot(2,2,1);plot(x);
- xlabel('Time/N');ylabel('Mag');grid on
- title('原始信号');
- subplot(2,2,2);plot(x1, abs(y));
- xlabel('Freq/N');ylabel('Mag');grid on
- title('FFT信号/横坐标为点数');
- subplot(2,2,3);plot(x2,abs(y));
- xlabel('Freq/Hz');ylabel('Mag');grid on
- title('FFT信号/横坐标为物理频率');
- subplot(2,2,4);plot(log_x2,abs(y));
- xlabel('Freq/log2(Hz)');ylabel('Mag');grid on
- title('FFT信号/横坐标为物理频率取log');
- % 更常见是将幅值取log
- y = log2(abs(y));
- figure,
- plot(x2,y);
- xlabel('Freq/Hz');ylabel('Mag/log2');grid on
- title('幅值取log2');
复制代码
