返回列表 发新帖我要提问本帖赏金: 3.00元(功能说明)
[STM32F1] ST分享大集结+STM32 ADXL345 加速度传感器
3959|32
 楼主| gaoke231 发表于 2017-11-26 22:47 | 显示全部楼层
ADX345进行校正。
void ADX345_Adjust(void)
    int32_t offx = 0, offy = 0, offz = 0;
    int16_t xValue, yValue, zValue;
    uint8_t i;
        ADX345_WriteReg(ADX_POWER_CTL, 0x00);         //先进入休眠模式.
        ADX345_DelayMs(100);
        ADX345_Init();
    ADX345_DelayMs(20);
    /* 读取十次数值 */
    for(i=0; i<10; i++)
        ADX345_ReadXYZ(&xValue, &yValue, &zValue);
        offx += xValue;
        offy += yValue;
        offz += zValue;
        ADX345_DelayMs(10);   //才样频率在100HZ,10ms采样一次最好
    /* 求出平均值 */
    offx /= 10;
    offy /= 10;
    offz /= 10;
    /* 全分辨率下,每个输出LSB为3.9 mg或偏移寄存器LSB的四分之一,所以除以4 */
    xValue = -(offx / 4);
        yValue = -(offy / 4);
        zValue = -((offz - 256) / 4);
    /* 设置偏移量 */
        ADX345_WriteReg(ADX_OFSX, xValue);
        ADX345_WriteReg(ADX_OFSY, yValue);
        ADX345_WriteReg(ADX_OFSZ, zValue);
读取ADX的XYZ轴的值(进行过数据处理)
void ADX_GetXYZData(int16_t *xValue, int16_t *yValue, int16_t *zValue)
    int32_t xTotal = 0, yTotal = 0, zTotal = 0;
    uint8_t i;
    *xValue = 0;
    *yValue = 0;
    *zValue = 0;
    /* 读取十次采样值 */
    for(i=0; i<10; i++)
        ADX345_ReadXYZ(xValue, yValue, zValue);
        xTotal += *xValue;
        yTotal += *yValue;
        zTotal += *zValue;
    /* 求出平均值 */
    *xValue = xTotal / 10;
    *yValue = yTotal / 10;
    *zValue = zTotal / 10;
 楼主| gaoke231 发表于 2017-11-26 22:48 | 显示全部楼层
将AD值转换成角度值
int16_t ADX_GetAngle(float xValue, float yValue, float zValue, uint8_t dir)
        float temp;
        float res = 0;
        switch(dir)
        /* 与自然Z轴的角度 */
                case 0:
                        temp = sqrt((xValue * xValue + yValue * yValue)) / zValue;
                        res = atan(temp);
                        break;
        /* 与自然X轴的角度 */
                case 1:
                        temp = xValue / sqrt((yValue * yValue + zValue * zValue));
                        res = atan(temp);
                        break;
        /* 与自然Y轴的角度 */
                case 2:
                        temp = yValue / sqrt((xValue * xValue + zValue * zValue));
                        res = atan(temp);
                        break;
        default:
            break;
 楼主| gaoke231 发表于 2017-11-26 22:49 | 显示全部楼层
int8_t SYSTEM_SetClock(uint8_t freq)
    ErrorStatus HSEStartUpStatus;
    uint32_t pllMul;
    /* 选择倍频系数 */
    switch(freq)
        case(32):
            pllMul = RCC_PLLMul_4;
            break;
        case(40):
            pllMul = RCC_PLLMul_5;
            break;
        case(48):
            pllMul = RCC_PLLMul_6;
            break;
        case(56):
            pllMul = RCC_PLLMul_7;
            break;
        case(64):
            pllMul = RCC_PLLMul_8;
            break;
        case(72):
            pllMul = RCC_PLLMul_9;
            break;
        default:
            RCC_DeInit();
            return -1;
    /* 复位RCC */
    RCC_DeInit();
    /* 使能打开HSE外部高速时钟 */
    RCC_HSEConfig(RCC_HSE_ON);
    /* 等待HSE时钟就绪 */
    HSEStartUpStatus = RCC_WaitForHSEStartUp();
    /* 当HSE时钟就绪 */
    if (HSEStartUpStatus == SUCCESS)
        /* 使能开启FLASH ,允许程序去操作FLASH上面的数据,要是不设置程序会出错 */
        FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
        /* FLASH代码2个延时周期 */
        FLASH_SetLatency(FLASH_Latency_2);
        /* 设置AHB总线的时钟分频 */
        RCC_HCLKConfig(RCC_SYSCLK_Div1);        //不分频
        /* 设置高速时钟的时钟分频(最大72MHZ) */
        RCC_PCLK2Config(RCC_HCLK_Div1);         //不分频
        /* 设置低速时钟的时钟分频(最大36MHZ) */
        RCC_PCLK1Config(RCC_HCLK_Div2);         //二分频
        /* 设置PLL的时钟输入和倍频数 */
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1, pllMul);//选择HSE不分频输入,倍频pllMul倍
        /* 开启 PLL */
        RCC_PLLCmd(ENABLE);
        /* 等待PLL时钟就绪 */
        while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
        /* 选择PLL时钟作为输入 */
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
        /* 等待系统时钟切换完成 */
        while(RCC_GetSYSCLKSource() != 0x08)
    else              //若HSE时钟开始失败,返回设置失败
        return -1;
    return 0;         //返回设置成功
 楼主| gaoke231 发表于 2017-11-26 22:50 | 显示全部楼层
void SYSTICK_Config(void)
    /* 时钟是72MHZ时,所以计数72次(最大为16777215),就是1us */
        /* 主要是为了设置时钟 */
        if(SysTick_Config(72) == 0)//开启成功返回0
                /* 调用这个设置函数的时候默认是直接打开计数器的,现在把它关掉。 */
                /* 关闭中断 */
                 SysTick->CTRL &= ~(SysTick_CTRL_ENABLE_Msk | SysTick_CTRL_TICKINT_Msk);
 楼主| gaoke231 发表于 2017-11-30 22:33 | 显示全部楼层
在主函数里面我们要先进行初始化
TFT_Init();
    FLASH_Init();
    SYSTICK_Config();
    USART1_Config(9600);
    LED_Config();
 楼主| gaoke231 发表于 2017-11-30 22:34 | 显示全部楼层
包括TFT彩屏的初始化 flash初始化  系统定时器初始化  串口1初始化
 楼主| gaoke231 发表于 2017-11-30 22:37 | 显示全部楼层
彩屏显示 以及系统的时间心跳
GUI_Show12Char(60, 42, "ADX345 ERROR!", RED, BLACK);
SYSTICK_Delay1ms(100);
 楼主| gaoke231 发表于 2017-11-30 22:38 | 显示全部楼层
在主程序中调用 ADX345_Adjust(); 获取数据。
/* 读取X,Y,Z的加速度值 */
            ADX_GetXYZData(&Xval, &Yval, &Zval);
            printf(" x:%d \n", Xval);
            printf(" y:%d \n", Yval);
            printf(" z:%d \n", Zval);
            /* 将读取到的加速度值转换为角度值 */
            Xang=ADX_GetAngle(Xval, Yval, Zval,1);
                        Yang=ADX_GetAngle(Xval, Yval, Zval,2);
                        Zang=ADX_GetAngle(Xval, Yval, Zval,0);
            GUI_DisplayData();
 楼主| gaoke231 发表于 2017-11-30 22:39 | 显示全部楼层
读取数据并实时显示,我们晃动板子数据会发生变化
 楼主| gaoke231 发表于 2017-11-30 22:40 | 显示全部楼层
可以将这个与控制电机模块结合做一个智能控制设备,其中的乐趣自己去探索。
 楼主| gaoke231 发表于 2017-11-30 22:42 | 显示全部楼层
有更好的想法可以传上来分享,这次结帖了。
