[STM32F1]
stm32 检测到按键按下 灯亮 否则灯不亮
1821|3
捉虫天师|  楼主 | 2017-12-25 20:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* File Name          : key_led.c.c
* Author               : MCD Application Team
* FW Version        : V2.0.1
* Date                  : 06/11/2012
* Description        : This file provides all the RCC firmware functions.
*开发板                  :神舟三号
* 现象                    :如程序执行前按住按键USER2 LED亮起,没按则灯不亮
#include "stm32f10x_lib.h"
/////////////   define LED   ///////////////
#define  RCC_GPIO_LED               RCC_APB2Periph_GPIOF
#define  GPIO_LED                     GPIOF
#define  GPIO_LED_PIN         GPIO_Pin_6
/////////////   define KEY   ///////////////
#define  RCC_GPIO_KEY       RCC_APB2Periph_GPIOD
#define  GPIO_KEY      GPIOD
#define  GPIO_KEY_PIN                    GPIO_Pin_3
/////////////   define Beep  ///////////////
#define  RCC_GPIO_BEEP                RCC_APB2Periph_GPIOB
#define  GPIO_BEEP                    GPIOB
#define  GPIO_BEEP_PIN                GPIO_Pin_10
/////////////   config LED   ///////////////
void LED_Config(void)
// RCC_ABP2PeriphClockCmd(RCC_GPIO_LED,ENABLE);
GPIO_InitStructure.GPIO_Pin =  GPIO_LED_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
// GPIO_SetBits(GPIO_LED,GPIO_LED_PIN); //初始化完成才能使用输出功能
GPIO_Init(GPIO_LED, &GPIO_InitStructure);
void LED_Turn_on(void)
GPIO_ResetBits(GPIO_LED,GPIO_LED_PIN);
void LED_Turn_off(void)
/////////////   config KEY   ///////////////
void KEY_Config(void)
// RCC_ABP2PeriphClockCmd(RCC_GPIO_KEY,ENABLE);
GPIO_InitStructure.GPIO_Pin =  GPIO_KEY_PIN;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//需要配置速率
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIO_KEY, &GPIO_InitStructure);
int Is_KeyDown(void)
if( !GPIO_ReadInputDataBit(GPIO_KEY,GPIO_KEY_PIN) )
  return  1 ;
else
     return 0  ;
/////// RccConfig///////
void RccConfiguration(void)
  ErrorStatus HSEStartUpStatus;
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);     //启动外部晶体震荡器
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp(); //等待启动完成
  if(HSEStartUpStatus == SUCCESS)   //如果启动成功,继续配置系统频率
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//选择flash预取址缓存模式
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2); //设置flash存储器延时时钟周期数
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);  //设置HCLK相对SYSCLK的分频比例  AHB时钟
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);   //设置PCLK2相对SYSCLK的分频比例  设置高速AHB时钟
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);//启动PLL
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
  RCC_APB2PeriphClockCmd(RCC_GPIO_LED,ENABLE);
  RCC_APB2PeriphClockCmd(RCC_GPIO_KEY,ENABLE);
  RCC_APB2PeriphClockCmd(RCC_GPIO_BEEP,ENABLE);
//////// NvicConfig//////////
void NvicConfiguration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
void ConfigureInterfaces(void)
    /* System Clocks Configuration */
    RccConfiguration();          //配置系统时钟
    /* NVIC configuration */
    NvicConfiguration();   //设置向量入口
int main(void)
ConfigureInterfaces();
LED_Config();
KEY_Config();
while(1)
    if(Is_KeyDown()==1)
         LED_Turn_on();
    else
         LED_Turn_off();
这个例子是检测按键的,通过判断按键状态做一个触发。
wahahaheihei| | 2017-12-25 22:36 | 只看该作者
其实按键最好的操作,就是按下计时,松手停止计时读时间,这样操作更多余地,同时按下的时候可以设置一个状态,而这个状态在松手的时候必须做出反相操作。
dongnanxibei| | 2017-12-26 10:45 | 只看该作者
学习一下,APB是怎么用的。
