PIC16F1937的硬件I2C主模式的写数据问题!!!
2913|0
 楼主| WalKerOne 发表于 2011-7-1 19:27 | 显示全部楼层 |阅读模式
求大家帮我看看下面这个程序(PIC16F1937作为I2C主节点向PCF8576D写数据,显示不正确),我按照应用笔记上的时序操作的,但是有问题,不知道问题出在哪?要延时还是怎么的?各位大侠有调试通过了的C语言的硬件I2C主模式的写程序吗?能否提供我一份,非常感谢!
uchar DisBuf[19] = {0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf,0xcf};
void main()
    OSCCON = 0x7a;    // INTOSCIO, PLL disabled, Fosc = 16MHz
    PORTC = 0x60;
    LATC = 0x60;
    TRISC = 0x9e;         // SCL and SDA is input
    SSPADD = 0x09;     // 0x09 for 400kHz at 16MHz
    SSPSTAT = 0x00;   // Enable High speed 400kHz slew rate control
    SSPCON1 = 0x28;  // Enable I2C Master initially
    SSPCON2 = 0x00;  // Clear control bits
    SSPCON3 = 0x08;  // Disable all interrupt of I2C Master, keep 300ns on SDA after SCL's falling edge
    While(1){
        SEN = 1;
        while(SEN);
        SSPBUF = PCF8576D_Addr & 0xfe;
        while(ACKSTAT);
        SSPBUF = 0xe0;
        while(ACKSTAT);
        SSPBUF = 0xc8;
        while(ACKSTAT);
        SSPBUF = 0x00;
        while(ACKSTAT);
        for(i=0;i<19;i++){
            SSPBUF = DisBuf;
            while(ACKSTAT);
        PEN = 1;
        while(PEN);
