[开发工具] ST推出的支持Linux开发的IDE
2127|16
 楼主| 734774645 发表于 2018-4-28 11:00 | 显示全部楼层 |阅读模式
http://download.atollic.com/TrueSTUDIO/installers/Atollic_TrueSTUDIO_for_STM32_linux_x86_64_v9.0.1_20180420-1214.tar.gz
  1. *****************************************************************************
  2. **  Release notes for Atollic TrueSTUDIO(R) for STM32 v9.0.1
  3. **  Linux installation package
  4. **
  5. **  This product supports STMicrolectronics STM32 microcontrollers.
  6. **
  7. **  Copyright (c) 2009-2018 STMicrolectronics. All rights reserved.
  8. **
  9. *****************************************************************************
  10. 1. Installation instructions
  11. System requirements
  12.     * 64-bit distribution with 32-bit C runtime libraries installed
  13.     * SysV compatible Linux system.
  14. TrueSTUDIO is supported on the following distributions:
  15.     * Ubuntu 16.04 LTS 64-bit (using Unity or Gnome 3 as recommended desktop)
  16.     * Fedora 25 64-bit (using Xfce4 as recommended desktop)
  17.     Note: TrueSTUDIO on Linux is only available as a 64-bit application.
  18. Install TrueSTUDIO by performing three steps
  19.     * Extract the downloaded archive
  20.       $ tar -xvf ~/Downloads/Atollic_TrueSTUDIO_for_STM32_linux_x86_64_v9.0.1_yyyymmdd-hhmm.tar.gz
  21.     * Run install.sh, the installation will prompt for install location
  22.       $ cd Atollic_TrueSTUDIO_for_STM32_9.0.1_installer && sudo ./install.sh
  23.     * Start TrueSTUDIO from the Applications menu, or alternatively start
  24.       from the command line:
  25.       $ cd /opt/Atollic_TrueSTUDIO_for_STM32_9.0.1/ide && ./TrueSTUDIO
  26. -----------------------------------------------------------------------------
  27. 2. News information
  28. News version 9.0.1
  29.     See release info in readme.txt
  30. News version 9.0.0
  31.     Atollic TrueSTUDIO(R) for STM32 v9.0.0 and is based on the Atollic
  32.      TrueSTUDIO for ARM v8.1.0 product
  33. -----------------------------------------------------------------------------
  34. 3. Known issues for this release
  35.     * If "Restart" button has been used when debugging then the debug session
  36.        needs to be terminated using "Terminate & Remove", accessed from
  37.        context menu with right-click on the launch object in the Debug view
  38.     * The information center requires that webkit-gtk libraries are installed
  39.     * TrueSTUDIO needs to be started from the
  40.        "$TrueSTUDIO_Install/ide" directory
  41.     * TrueSTUDIO requires that 32-bit libc6 is available on the system.
  42.        install.sh tries to install it for you but this might fail.
  43.        In that case you need to manually install it.
  44.     * ETM tracing is very slow on linux and requires a lot of memory
  45.        to work correctly.
 楼主| 734774645 发表于 2018-4-28 11:01 | 显示全部楼层
http://download.atollic.com/TrueSTUDIO/installers/Atollic_TrueSTUDIO_for_ARM_linux_x86_64_v8.1.0_20171023-2304.tar.gz
  2. **  Release notes for Atollic TrueSTUDIO(R) for ARM(R) v8.1.0
  4. **
  5. **  This product supports ARM-based microcontrollers.
  6. **
  7. **  (c)Copyright 2009-2017 Atollic AB.
  8. **
  20.       $ tar -xvf ~/Downloads/Atollic_TrueSTUDIO_for_ARM_linux_x86_64_v8.1.0_yyyymmdd-hhmm.tar.gz
  22.       $ cd Atollic_TrueSTUDIO_for_ARM_8.1.0_installer && sudo ./install.sh
  25.       $ cd /opt/Atollic_TrueSTUDIO_for_ARM_8.1.0/ide && ./TrueSTUDIO
  28. News version 8.1.0
  29.     * Linux installer allows customer to continue installation even if
  30.        automatic 32-bit library installation fails.
  31.     * Solved debug script issue, sometimes the debug script was empty.
  32. News version 8.0.0
  33.     * ST-Link GDB server for Linux now included.
  34.     * Increased default maximum Java heap size usage, -Xmx<size>, to 2032 MB
  35.        for 64-bit linux version.
  36. Known issues for this release
  37.     * If "Restart" button has been used when debugging then the debug session
  38.        needs to be terminated using "Terminate & Remove", accessed from
  39.        context menu with right-click on the launch object in the Debug view
  40.     * The P&E Micro GDB server needs read/write access to the
  41.        $TrueSTUDIO_Install/Servers/PE_Micro_gdbserver folder
  42.     * The information center requires that webkit-gtk libraries are installed
  43.     * TrueSTUDIO needs to be started from the
  44.        "$TrueSTUDIO_Install/ide" directory
  45.     * TrueSTUDIO requires that 32-bit libc6 is available on the system.
  46.        install.sh tries to install it for you but this might fail.
  47.        In that case you need to manually install it.
  48.     * ETM tracing is very slow on linux and requires a lot of memory
  49.        to work correctly
  50. News version 7.1.1 Beta
  51.     * No Linux specific changes in this version
  52. News version 7.1.0 Beta
  53.     * Fourth release of Linux version.
  54.     * PC Tools and make utilities included
  55.     * Fixed issue with conversion tools to hex, binary, etc where the
  56.        generated file would be empty.
  57. News version 7.0.1 Alpha-1
  58.     * Third Alpha release of Linux version.
  59.        See readme.txt for general fixes included in this version.
  60. News version 7.0.0 Alpha-2
  61.     * Second Alpha release of Linux version.
  62.     * P&E Micro GDB server is now included
不知道这不支持其他竞争对手的芯片了,竞争对手是不是很伤心。
colin2135 发表于 2018-4-28 11:44 | 显示全部楼层
TrueSTUDIO V9.0的版本只支持stm32, V9.0之前的版本支持基本厂家的芯片。
 楼主| 734774645 发表于 2018-4-28 15:15 | 显示全部楼层
是的,被ST收购后,其他厂家估计很不爽,少了个支持
静听风易 发表于 2018-4-28 15:33 | 显示全部楼层
原来是Linux下开发的IDE,那么有个问题,一直以来,Linux下开发是用的什么工具呢?
 楼主| 734774645 发表于 2018-4-28 15:58 | 显示全部楼层
原来是Linux下开发的IDE,那么有个问题,一直以来,Linux下开发是用的什么工具呢? ...
不知道啊,才知道这个的
tkyl01 发表于 2018-4-28 17:35 | 显示全部楼层
linux下用makefile+gcc+vim,好的不要不要的,IDE早放弃了,windows好久没用了
android2 发表于 2018-4-29 10:41 | 显示全部楼层
竞争上到另一个级别了
 楼主| 734774645 发表于 2018-4-29 17:45 | 显示全部楼层
linux下用makefile+gcc+vim,好的不要不要的,IDE早放弃了,windows好久没用了 ...
牛人啊,makefile 要自己编写吧。
tkyl01 发表于 2018-5-2 16:21 | 显示全部楼层
一开始是自己编的,学了些语法之类的,后来发现cube可以生成makefile,不过需要改动一下,直接用可能不行
john_lee 发表于 2018-5-3 15:45 | 显示全部楼层
linux 也有各种 IDE:eclipse cdt, segger embedded studio, codeblocks, codelite 等等。
我现在用 codelite + segger ozone。
lehuijie 发表于 2018-5-3 22:57 | 显示全部楼层
一开始是自己编的,学了些语法之类的,后来发现cube可以生成makefile,不过需要改动一下,直接用可能不行 ...
cube是什么
updownq 发表于 2018-5-3 23:06 | 显示全部楼层
是uclinux吗?
tkyl01 发表于 2018-5-4 16:56 | 显示全部楼层
全名 STM32CubeMX
七颗咖啡豆 发表于 2018-5-4 21:23 | 显示全部楼层
开发个单片机没必要用linux系统吧。。。。。。
gejigeji521 发表于 2018-5-9 22:28 来自手机 | 显示全部楼层
好牛X,你们这些大神知道的真多,我说的包括回帖的几个大牛
