[i.MX] imx-uart 21f0000.serial: Rx FIFO overrun
4256|1
 楼主| 符号aaa 发表于 2018-5-16 18:33 | 显示全部楼层 |阅读模式
imx-uart 21f0000.serial: Rx FIFO overrun   我在调试RS485全双工模式的时候,每次运行测试程序都会出现这个问题,而且还接收不到数据,有谁知道是为什么吗? 原因在哪里
wuguangnan110 发表于 2018-5-21 15:38 | 显示全部楼层
I have found a solution backporting the imx serial driver from mainline kernel 3.18.31 (drivers/tty/serial/imx.c from kernel.org). I have replaced imx.c from toradex imx6 3.14.28 kernel, recompile it and the Rx Fifo Overrun error is seemed to be solved, such as I have not observed it again in syslog doing some tests.
