一个晚上写的1602时钟程序
2430|3
ligouning|  楼主 | 2011-7-27 21:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/*=========================1602显示时钟==============*/
/*============三个独立按键设置时间==========*/
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
char shi1,shi2,fen1,fen2,miao1,miao2,aa,bb,shi,fen,miao,count;
uchar a[]="0123456789";
sbit wlen=P2^7;
sbit wlrs=P2^5;
sbit RW=P2^6;
sbit EN=P3^2; //==========独立按键1选择设置
sbit jia=P3^3;//==========独立按键2调时间加
sbit jian=P3^4; //=========独立按键3调时间减
void delay(uchar z);  //======延时函数
void write_com(uchar com); //====1602写命令函数
void write_date(uchar date); //===1602写数据函数
void init(); //=========初始化1602
void write();//=========将时,分,秒送显示
void do_date();//========对时,分,秒进行分解
void main()
init();
TMOD = 0x01;
IE   = 0x82;
TH0  = (65536-46296)/256; //====计时50ms
TL0  = (65536-46296)%256;
TR0 = 1;
while(1)
  write_com(0x80+0x46);
  delay(2);
  write_date(':');
  write_com(0x80+0x49);
  delay(2);
  write_date(':');
  if(EN==0)    //=====对独立按键进行检测并用软件消抖
   delay(5);
   if(EN==0)
    while(EN==0);
    TR0=0;
    count++;  //=====count计数选择对时,分,秒调动
    if(count==4)//====设置结束,时钟跑
     count=0;
     TR0=1;
  //==================调秒
if(count==1&&jia==0)
   delay(5);
    while(jia==0);
    miao++;
    if(miao==60)
    {miao=0;}
  if(count==1&&jian==0)
   delay(5);
    while(jian==0);
    miao--;
    if(miao+1==0)
    {miao=59;}
//==================调分
  if(count==2&&jia==0)
   delay(5);
    while(jia==0);
    fen++;
    if(fen==60)
    {fen=0;}
  if(count==2&&jian==0)
   delay(5);
    while(jian==0);
    fen--;
    if(fen+1==0)
    {fen=59;}
//==================调时
  if(count==3&&jia==0)
   delay(5);
    while(jia==0);
    shi++;
    if(shi==24)
    {shi=0;}
  if(count==3&&jian==0)
   delay(5);
    while(jian==0);
    shi--;
    if(shi+1==0)
    {shi=23;}
  do_date();
  write();
/*......................................延时程序,延时1ms................*/
void delay(uchar z)
uchar x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
/*......................................1602命令函数.....................*/
wlrs=0;      //写命令0/写数据1
RW=0;     //读0/写1
P0=com;     //给1602送命令
delay(5);
wlen=1;
delay(5);
wlen=0;
/*......................................1602数据函数.....................*/
wlrs=1;
RW=0;
P0=date;
delay(5);
wlen=1;
delay(5);
wlen=0;
void init()
wlen=0;
write_com(0x38);
write_com(0x01);
write_com(0x0c);
write_com(0x04);
void write()
write_com(0x80+0x44);
write_date(a[shi2]);
write_com(0x80+0x45);
write_date(a[shi1]);
write_com(0x80+0x47);
write_date(a[fen2]);
write_com(0x80+0x48);
write_date(a[fen1]);
write_com(0x80+0x4a);
write_date(a[miao2]);
write_com(0x80+0x4b);
write_date(a[miao1]);
void timer0() interrupt 1
TH0=(65536-46296)/256;
TL0=(65536-46296)%256;
aa++;
if(aa==20)
  aa=0;
  miao++;
  if(miao==60)
   miao=0;
   fen++;
  if(fen==60)
   fen=0;
   shi++;
  if(shi==24)
  {shi=0;}
//===========对时,分,秒进行分解
void do_date()
shi2=shi/10;
shi1=shi%10;
fen2=fen/10;
fen1=fen%10;
miao2=miao/10;
miao1=miao%10;
NICKY99| | 2011-7-28 11:00 | 只看该作者
robotics30| | 2011-7-29 17:14 | 只看该作者
程序没问题,但main()里面太乱,可以把按键检测单独做成key().另外,该程序没有光标显示,改时间的时候不方便.
ligouning|  楼主 | 2011-7-29 20:52 | 只看该作者
3楼讲的,学习了。
