[DemoCode下载] MINI58的ADC比较模式
1235|11
 楼主| antusheng 发表于 2018-11-24 22:06 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * $Revision: 4 $
  5. * $Date: 15/06/02 9:19p $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate ADC conversion and comparison function by
  7. *           monitoring the conversion result of channel 0.
  8. *
  9. * @note
  10. * Copyright (C) 2015 Nuvoton Technology Corp. All rights reserved.
  11. *****************************************************************************/
  12. #include <stdio.h>
  13. #include "Mini58Series.h"
  14. void ADC_IRQHandler(void)
  15. {
  16.     uint32_t u32Flag;
  17.     // Get ADC comparator interrupt flag
  18.     u32Flag = ADC_GET_INT_FLAG(ADC, ADC_CMP0_INT | ADC_CMP1_INT);
  19.     if(u32Flag & ADC_CMP0_INT)
  20.         printf("Channel 0 input < 0x200\n");
  21.     if(u32Flag & ADC_CMP1_INT)
  22.         printf("Channel 0 input >= 0x200\n");
  23.     ADC_CLR_INT_FLAG(ADC, u32Flag);
  24. }
  25. void SYS_Init(void)
  26. {
  27.     /*---------------------------------------------------------------------------------------------------------*/
  28.     /* Init System Clock        */
  29.     /*---------------------------------------------------------------------------------------------------------*/
  30.     /* Unlock protected registers */
  31.     SYS_UnlockReg();
  32.     /* Set P5 multi-function pins for XTAL1 and XTAL2 */
  33.     SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
  34.     SYS->P5_MFP |= (SYS_MFP_P50_XT1_IN | SYS_MFP_P51_XT1_OUT);
  35.     /* Enable external 12MHz XTAL, HIRC */
  36.     CLK->PWRCTL = CLK_PWRCTL_XTL12M | CLK_PWRCTL_HIRCEN_Msk;
  37.     /* Waiting for clock ready */
  38.     CLK_WaitClockReady(CLK_STATUS_XTLSTB_Msk | CLK_STATUS_HIRCSTB_Msk);
  39.     /* Switch HCLK clock source to XTL */
  40.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_XTAL,CLK_CLKDIV_HCLK(1));
  41.     /* STCLK to XTL STCLK to XTL */
  42.     CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_XTAL);
  43.     /* Enable IP clock */
  44.     CLK_EnableModuleClock(UART0_MODULE);
  45.     CLK_EnableModuleClock(ADC_MODULE);
  46.     /* Select IP clock source */
  47.     CLK_SetModuleClock(UART0_MODULE,CLK_CLKSEL1_UARTSEL_XTAL,CLK_CLKDIV_UART(1));
  48.     CLK_SetModuleClock(ADC_MODULE,CLK_CLKSEL1_ADCSEL_XTAL,CLK_CLKDIV_ADC(6));
  49.     /*---------------------------------------------------------------------------------------------------------*/
  50.     /* Init I/O Multi-function        */
  51.     /*---------------------------------------------------------------------------------------------------------*/
  52.     /* Set P1 multi-function pins for UART RXD, TXD */
  53.     SYS->P1_MFP = SYS_MFP_P12_UART0_RXD | SYS_MFP_P13_UART0_TXD;
  54.     /* Set P5.3 to ADC channel 0 input pin */
  55.     SYS->P5_MFP |= SYS_MFP_P53_ADC_CH0;
  56.     /* Analog pin OFFD to prevent leakage */
  57.     P5->DINOFF |= (1 << 3) << GP_DINOFF_DINOFF0_Pos;
  58.     /* To update the variable SystemCoreClock */
  59.     SystemCoreClockUpdate();
  60.     /* Lock protected registers */
  61.     SYS_LockReg();
  62. }
  63. int32_t main (void)
  64. {
  65.     /* Init System, IP clock and multi-function I/O
  66.        In the end of SYS_Init() will issue SYS_LockReg()
  67.        to lock protected register. If user want to write
  68.        protected register, please issue SYS_UnlockReg()
  69.        to unlock protected register if necessary */
  70.     SYS_Init();
  71.     /* Init UART to 115200-8n1 for print message */
  72.     UART_Open(UART0, 115200);
  73.     printf("\nThis sample code demonstrate ADC conversion and comparison function\n");
  74.     printf("by monitoring the conversion result of channel 0 (P5.3)\n");
  75.     // Enable channel 0
  76.     ADC_Open(ADC, 0, 0, 0x01);
  77.     // Power on ADC
  78.     ADC_POWER_ON(ADC);
  79.     // Configure and enable Comparator 0 to monitor channel 0 input less than 0x200
  80.     ADC_ENABLE_CMP0(ADC, 0, ADC_CMP0_LESS_THAN, 0x200, 16);
  81.     // Configure and enable Comparator 1 to monitor channel 0 input greater or equal to 0x200
  82.     ADC_ENABLE_CMP1(ADC, 0, ADC_CMP1_GREATER_OR_EQUAL_TO, 0x200, 16);
  83.     // Enable ADC comparator 0 and 1 interrupt
  84.     ADC_EnableInt(ADC, ADC_CMP0_INT);
  85.     ADC_EnableInt(ADC, ADC_CMP1_INT);
  86.     NVIC_EnableIRQ(ADC_IRQn);
  87.     while(1)
  88.     {
  89.         // Trigger ADC conversion if it is idle
  90.         if(!ADC_IS_BUSY(ADC))
  91.         {
  92.             ADC_START_CONV(ADC);
  93.         }
  94.     }
  95. }
  96. /*** (C) COPYRIGHT 2015 Nuvoton Technology Corp. ***/
 楼主| antusheng 发表于 2018-11-24 22:55 | 显示全部楼层
一共就这两个比较器,都演示了。
 楼主| antusheng 发表于 2018-11-24 22:57 | 显示全部楼层
而且两个比较器可以同时对一个通道处理两个比较任务。
稳稳の幸福 发表于 2018-11-24 23:40 | 显示全部楼层
这个系列还真好用
huangcunxiake 发表于 2018-11-24 23:55 | 显示全部楼层
其实都是中断啊,厉害,中断实现的功能太多了。
天灵灵地灵灵 发表于 2018-11-25 00:00 | 显示全部楼层
在过零检测一类上应用很多。
在过零检测一类上应用很多。
玛尼玛尼哄 发表于 2018-11-25 00:13 | 显示全部楼层
中断处理函数的方式跟IO中断处理方式一样啊。
21mengnan 发表于 2018-11-25 15:33 | 显示全部楼层
所有的ADC都要这么操作吧
xixi2017 发表于 2018-11-27 21:24 | 显示全部楼层
上面的那个操作是为了防止数字口串扰到ADC,引起不必要的漏电。
 楼主| antusheng 发表于 2018-12-8 23:07 | 显示全部楼层
这个系列性价比超级好。
niuniu122 发表于 2020-6-10 10:32 | 显示全部楼层
您好  怎样搭建MINI58开发平台
