使用tensorflow实现u-net的一个例子
1185|0
 楼主| keer_zu 发表于 2019-3-31 09:40 | 显示全部楼层 |阅读模式
basic-u-net-using-tensorflow
  1. import os
  2. import sys
  3. import numpy as np
  4. import tensorflow as tf
  5. import random
  6. import math
  7. import warnings
  8. import pandas as pd
  9. import cv2
  10. import matplotlib.pyplot as plt
  11. from tqdm import tqdm
  12. from itertools import chain
  13. from skimage.io import imread, imshow, imread_collection, concatenate_images
  14. from skimage.transform import resize
  15. from skimage.morphology import label
  16. warnings.filterwarnings('ignore', category=UserWarning, module='skimage')
  17. seed = 42
  18. random.seed = seed
  19. np.random.seed = seed
  20. # Set some parameters
  21. IMG_WIDTH = 128
  22. IMG_HEIGHT = 128
  23. IMG_CHANNELS = 3
  24. TRAIN_PATH = '../input/stage1_train/'
  25. TEST_PATH = '../input/stage1_test/'
  26. warnings.filterwarnings('ignore', category=UserWarning, module='skimage')
  27. seed = 42
  28. random.seed = seed
  29. np.random.seed = seed
  30. # Get train and test IDs
  31. train_ids = next(os.walk(TRAIN_PATH))[1]
  32. test_ids = next(os.walk(TEST_PATH))[1]
  33. # Get and resize train images and masks
  34. images = np.zeros((len(train_ids), IMG_HEIGHT, IMG_WIDTH, IMG_CHANNELS), dtype=np.uint8)
  35. labels = np.zeros((len(train_ids), IMG_HEIGHT, IMG_WIDTH, 1), dtype=np.bool)
  36. print('Getting and resizing train images and masks ... ')
  37. sys.stdout.flush()
  38. for n, id_ in tqdm(enumerate(train_ids), total=len(train_ids)):
  39.     path = TRAIN_PATH + id_
  40.     img = imread(path + '/images/' + id_ + '.png')[:,:,:IMG_CHANNELS]
  41.     img = resize(img, (IMG_HEIGHT, IMG_WIDTH), mode='constant', preserve_range=True)
  42.     images[n] = img
  43.     mask = np.zeros((IMG_HEIGHT, IMG_WIDTH, 1), dtype=np.bool)
  44.     for mask_file in next(os.walk(path + '/masks/'))[2]:
  45.         mask_ = imread(path + '/masks/' + mask_file)
  46.         mask_ = np.expand_dims(resize(mask_, (IMG_HEIGHT, IMG_WIDTH), mode='constant',
  47.                                       preserve_range=True), axis=-1)
  48.         mask = np.maximum(mask, mask_)
  49.     labels[n] = mask
  50. X_train = images
  51. Y_train = labels
  52. # Get and resize test images
  53. X_test = np.zeros((len(test_ids), IMG_HEIGHT, IMG_WIDTH, IMG_CHANNELS), dtype=np.uint8)
  54. sizes_test = []
  55. print('Getting and resizing test images ... ')
  56. sys.stdout.flush()
  57. for n, id_ in tqdm(enumerate(test_ids), total=len(test_ids)):
  58.     path = TEST_PATH + id_
  59.     img = imread(path + '/images/' + id_ + '.png')[:,:,:IMG_CHANNELS]
  60.     sizes_test.append([img.shape[0], img.shape[1]])
  61.     img = resize(img, (IMG_HEIGHT, IMG_WIDTH), mode='constant', preserve_range=True)
  62.     X_test[n] = img
  63. print('Done!')
1497
