[Cortex-M0技术交流] 我的WDT代码只有只能中断不能重启
3201|8
 楼主| cuijianbo 发表于 2011-10-13 10:38 | 显示全部楼层 |阅读模式
哪位仁兄帮我解决一下,吾不胜感激。
屏蔽掉void WDT_IRQHandler(void)的WDT->WTCR.WTR = 1;这句,代码死循环后WDT没有令其重启。
代码如下
/* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved.                                         */
#include <stdio.h>
#include <string.h>
#include "NUC1xx.h"
#include "Driver\DrvSYS.h"
#include "Driver\DrvGPIO.h"
#include "Driver\DrvUART.h"
//static uint16_t TimerCounter=0;
//static uint8_t Alarm_E=1;
//static uint32_t WDTCOUN=0;
void Delay(int count);
/*------- WDT ----------------------------------------------*/
void InitWDT(void)
NVIC_DisableIRQ(WDT_IRQn); //Disable WDT interrupt
outpw(&WDT->WTCR ,0 );  //Disable WDT
UNLOCKREG();
/* Step 1. Enable and Select WDT clock source */
SYSCLK->CLKSEL1.WDT_S =3;//Select 10Khz for WDT clock source
SYSCLK->APBCLK.WDT_EN =1;//Enable WDT clock source
/* Step 2. Select Timeout Interval */
WDT->WTCR.WTIS=5;//Select level 7
/* Step 3. Enable Watchdog Timer Reset function */
WDT->WTCR.WTRE = 1;
/* Step 4. Enable WDT interrupt */
WDT->WTCR.WTIF =1;//Write 1 to clear for safety
WDT->WTCR.WTIE = 1;
NVIC_EnableIRQ(WDT_IRQn);
/* Step 5. Enable WDT module */
//Enable WDT
WDT->WTCR.WTE = 1;
  //Clear WDT counter
//WDT->WTCR.WTR = 1;
LOCKREG();
UNLOCKREG();
WDT->WTCR.WTIF =1;
    WDTCOUN++;
  if (WDTCOUN<10) WDT->WTCR.WTR=1; //Wait 10 times
    WDT->WTCR.WTR = 1;
  LOCKREG();
printf("WDT interrupt\n");
  MAIN function
int32_t main (void)
STR_UART_T sParam;
UNLOCKREG();
SYSCLK->PWRCON.XTL32K_EN = 1;//Enable 32Khz for RTC clock source
SYSCLK->PWRCON.XTL12M_EN = 1;
SYSCLK->CLKSEL0.HCLK_S = 0;
LOCKREG();
/* Set UART Pin */
DrvGPIO_InitFunction(E_FUNC_UART0);
  /* UART Setting */
    sParam.u32BaudRate   = 115200;
    sParam.u8cDataBits   = DRVUART_DATABITS_8;
    sParam.u8cStopBits   = DRVUART_STOPBITS_1;
    sParam.u8cParity   = DRVUART_PARITY_NONE;
    sParam.u8cRxTriggerLevel= DRVUART_FIFO_1BYTES;
/* Set UART Configuration */
  if(DrvUART_Open(UART_PORT0,&sParam) != E_SUCCESS)
  printf("UART0 open failed\n");
  return FALSE;
    printf("\n\n");
    printf("+-----------------------------------------------------------+\n");
    printf("|            Timer_WDT_RTC Sample Program                   |\n");
// InitTIMER0();
// InitRTC();
InitWDT();
/* Synch field transmission & Request Identifier Field transmission*/
while(1);
lixiaoxu2meng 发表于 2011-10-13 11:14 | 显示全部楼层
你好 我有一篇 WDT 的例子你可以看一下
Ryanhsiung 发表于 2011-10-13 11:34 | 显示全部楼层
DrvWDT_Ioctl (E_WDT_IOC_ENABLE_RESET_FUNC, 0); //使能看门狗定时器复位功能
有没有初始化这一句???
 楼主| cuijianbo 发表于 2011-10-13 14:02 | 显示全部楼层
2楼的可以再NUC100上运行可以复位吗?
Ryanhsiung 发表于 2011-10-13 14:06 | 显示全部楼层
我就是抄他的例程,可以啊!!!
 楼主| cuijianbo 发表于 2011-10-13 14:08 | 显示全部楼层
3楼说的和我的NVIC_EnableIRQ(WDT_IRQn);是一样的
 楼主| cuijianbo 发表于 2011-10-13 17:15 | 显示全部楼层
我上面发的代码在NUC140可以,但在NUC100就不行,很奇怪
 楼主| cuijianbo 发表于 2011-10-14 14:30 | 显示全部楼层
2# lixiaoxu2meng 仁兄,你的代码测了一下,    // DrvWDT_Ioctl (E_WDT_IOC_RESET_TIMER,0); //定时喂狗 可以去掉看 WDT复位效果
这句话屏蔽掉了,现象是A2先亮时间最长,然后A4亮,最后A3亮时间最短,之后三个灯一直是灭的。WDT复位后应该系统重启才是,也就是复位后A2A3A4以此亮。怎么到我这就不行了呢?
 楼主| cuijianbo 发表于 2011-10-14 14:31 | 显示全部楼层
5# Ryanhsiung 你用的是NUC什么系列的芯片?
