使用TFTP与NFS挂载遇到的问题
3575|3
 楼主| zhenqi2008 发表于 2011-10-26 12:39 | 显示全部楼层 |阅读模式
下面是我的操作及测试TFTP和NFS服务有没有打开:
[root@localhost /]# service nfs restart
关闭 NFS mountd:                                         [确定]
关闭 NFS 守护进程:^[                                     [确定]
关闭 NFS quotas                                           [确定]
关闭 NFS 服务:                                           [确定]
启动 NFS 服务:                                           [确定]
关掉 NFS 配额:                                           [确定]
启动 NFS 守护进程:                                       [确定]
启动 NFS mountd:                                         [确定]
[root@localhost /]# service xinetd restart
停止 xinetd:                                            [确定]
启动 xinetd:                                             [确定]
[root@localhost /]# mount -t nfs 192.168.2.202:/home/zzq  /mnt
[root@localhost /]# cd mnt
[root@localhost mnt]# ls
bin     Documents  home  mnt    nfsroot.tar.gz Public  Templates  var
Desktop Download   init  Music Pictures        sbin   tmp        Videos
dev     etc        lib  nfs   proc           sys     usr
      已配置好NFS服务
[root@localhost /]# /etc/init.d/iptables status
防火墙已停
[root@localhost /]# tftp 192.168.2.202
tftp> get abc.c
tftp> q
[root@localhost /]#
防火墙也已经关闭
U-Boot> ping 192.168.2.202
macb0: link up, 100Mbps full-duplex (lpa: 0x45e1)
Using macb0 device
host 192.168.2.202 is alive
板子能够与linux服务器PING 通
U-Boot> printenv
bootdelay=3
baudrate=115200
ethact=macb0
ethaddr=00:22:33:45:43:33
filesize=217580
fileaddr=71100000
bootcmd=nand read 0x72000000 0x200000 0x200000 ;nand read 0x71100000 0x400000 0x
300000 ;bootm 0x72000000
ipaddr=192.168.2.44
serverip=192.168.2.202
bootargs=mem=64M console=ttyS0 115200 root=/dev/nfs rw nfsroot=192.168.2.202:/ho
me/zzq ip=192.168.2.44:192.168.2.202:192.168.2.1:255.255.255.0::eth0:off
Environment size: 402/131067 bytes
以上为板子所设置的环境变量
Using macb0 device
U-Boot> tftp 0x72000000 uImage
Using macb0 device
TFTP from server 192.168.2.202; our IP address is 192.168.2.44
Filename 'uImage'.
Load address: 0x72000000
Loading: #T T T #T T T T T #T T T T T #T #T T T T T #T T T T T T #T #T T T T T T
T T T T #T ##T T T
Retry count exceeded; starting again
Using macb0 device
Filename 'uImage'.
Loading: #T T T #T T #T T #T T T T T T T #T T T T T #T T T T T T T T
下载不能成功
但我在共享目录中新建一个其他的文件:234.c  可以下载成功 这能不能说明我的TFTP服务器已经打开了。
U-Boot> tftp 0x72000000 234.c
Using macb0 device
Filename '234.c'.
Loading: #
done
Bytes transferred = 2921 (b69 hex)
请教下工程师们,问题可能是怎样产生的?
 楼主| zhenqi2008 发表于 2014-6-22 10:20 | 显示全部楼层
在用客户端下载文件时小的文件能下载成功,而一些上M的文件就总是提示Transfer timed out,怎么传输不了大文件,还需要什么配置吗?
 楼主| zhenqi2008 发表于 2014-6-25 21:22 | 显示全部楼层
顶一下。 有没有人遇到类似的情况呢?
 楼主| zhenqi2008 发表于 2014-7-15 08:54 | 显示全部楼层
找到答案了  数据大小的问题
