[产品供应] 北京蓝景世纪 TRF7960RHBR QTY:5KPCS 现货热卖!
1813|0
 楼主| jameswangchip 发表于 2011-11-3 11:57 | 显示全部楼层 |阅读模式
    TRF7960RHBR 是TI 推出的一款多标准完全集成的 13.56MHz RFID AFE 和数据成帧阅读系统。
The TRF7960/61 is an integrated analog front end and data-framing system for a 13.56-MHz RFID reader system. Built-in programming options make it suitable for a wide range of applications for proximity and vicinity RFID systems.
The reader is configured by selecting the desired protocol in the control registers. Direct access to all control registers allows fine tuning of various reader parameters as needed.
A parallel or serial interface can be implemented for communication between the MCU and reader. Transmit and receive functions use internal encoders and decoders with a 12-byte FIFO register. For direct transmit or receive functions, the encoders / decoders can be bypassed so the MCU can process the data in real time.
ADI 全线产品小批量采购服务中心
北京蓝景世纪科技开发有限责任公司
地址:北京市海淀区知春路128号泛亚大厦1892B
电话:010-51663026 ,82626934
传真:010-51664726
联系人: Mr Richie Lee
邮件:salesonline@163.com
www.bluechipsemi.com
个人签名:新浪微博:阿牛哥在北京 http://www.weibo.com/brotherbull QQ:1047177125
2887
