STM32F103的CAN发送数据CAN分析仪接收不到数据
2621|2
 楼主| zzzhangliyuan 发表于 2019-7-10 17:15 | 显示全部楼层 |阅读模式
我现在在调试STM32F103的CAN总线,就是用STM32F103通过CAN发送数据,利用CAN总线分析仪在电脑上看到数据,现在收不到数据。我把我的电路和代码以及波形放上来请广大网友指点一二,谢谢啦~~~~
下面是主函数,很简单就是初始化之后循环发送数据。
int main(void)
        CAN_Config();
        LED_GPIO_Config();
         CAN_SetMsg();
        while(1)
                CAN_Transmit(CAN1, &TxMessage);
                 GPIO_WriteBit(GPIOD, GPIO_Pin_2,
                             (BitAction)((1-GPIO_ReadOutputDataBit(GPIOD, GPIO_Pin_2))));
                Delay_ms(50);
下面是CAN的配置程序:
static void CAN_GPIO_Config(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOB, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
        GPIO_PinRemapConfig(GPIO_Remap1_CAN1, ENABLE);
        /* Configure CAN pin: RX */        // PB8
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
    /* Configure CAN pin: TX */        // PB9
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
static void CAN_NVIC_Config(void)
           NVIC_InitTypeDef NVIC_InitStructure;
                /* Configure one bit for preemption priority */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
        NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
波特率为36MHz/(2+5+5)/24=125K
static void CAN_Mode_Config(void)
           CAN_InitTypeDef        CAN_InitStructure;
        CAN_DeInit(CAN1);
        CAN_StructInit(&CAN_InitStructure);
        CAN_InitStructure.CAN_TTCM=DISABLE;
        CAN_InitStructure.CAN_ABOM=ENABLE;
        CAN_InitStructure.CAN_AWUM=ENABLE;
        CAN_InitStructure.CAN_NART=DISABLE;
        CAN_InitStructure.CAN_RFLM=DISABLE;
        CAN_InitStructure.CAN_TXFP=DISABLE;
        CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
        CAN_InitStructure.CAN_SJW=CAN_SJW_2tq;
        CAN_InitStructure.CAN_BS1=CAN_BS1_5tq;
        CAN_InitStructure.CAN_BS2=CAN_BS2_5tq;
        CAN_InitStructure.CAN_Prescaler =24;
        CAN_Init(CAN1, &CAN_InitStructure);
static void CAN_Filter_Config(void)
        CAN_FilterInitTypeDef  CAN_FilterInitStructure;
         CAN_FilterInitStructure.CAN_FilterNumber=0;
         CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
         CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
        CAN_FilterInitStructure.CAN_FilterIdHigh= (((u32)0x1314<<3)&0xFFFF0000)>>16;
        CAN_FilterInitStructure.CAN_FilterIdLow= (((u32)0x1314<<3)|CAN_ID_EXT|CAN_RTR_DATA)&0xFFFF;
        CAN_FilterInitStructure.CAN_FilterMaskIdHigh= 0xFFFF;
        CAN_FilterInitStructure.CAN_FilterMaskIdLow= 0xFFFF;
        CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_Filter_FIFO0 ;
        CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
        CAN_FilterInit(&CAN_FilterInitStructure);
        CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE);
CAN通信报文的内容设置:
void CAN_SetMsg(void)
  //TxMessage.StdId=0x00;
  TxMessage.ExtId=0x1314;
  TxMessage.IDE=CAN_ID_EXT;
  TxMessage.RTR=CAN_RTR_DATA;
  TxMessage.DLC=2;
  TxMessage.Data[0]=0xAB;
  TxMessage.Data[1]=0xCD;
 楼主| zzzhangliyuan 发表于 2019-7-17 16:02 | 显示全部楼层
问题找到了,是我没有把CAN总线分析仪的速率配置好,我误把串口波特率当成了CAN的波特率了
cainiao518 发表于 2019-7-18 09:03 | 显示全部楼层
双方速率一致才能正常通信
