[经验分享] 步进电机驱动代码分析
2323|1
 楼主| 黎明前奏 发表于 2011-11-13 10:30 | 显示全部楼层 |阅读模式
#include "STC12C5A60S2.h"
void delay();
//Motor
sbit F1 = P0^0;
sbit F2 = P0^1;
sbit F3 = P0^2;
sbit F4 = P0^3;
unsigned char code FFW[8]={0xfe,0xfc,0xfd,0xf9,0xfb,0xf3,0xf7,0xf6}; //反转
unsigned char code FFZ[8]={0xf6,0xf7,0xf3,0xfb,0xf9,0xfd,0xfc,0xfe}; //正转
unsigned int  K, rate;
*                 步进电机驱动   *
void  motor_ffw(void)
   unsigned char i;
      for (i=0; i<8; i++)       //一个周期转30度
          P0 = FFW[i]&0x1f;  //取数据
          delay();           //调节转速
延时程序
void delay(void)
   unsigned int k,t;
    t=rate;
   while(t--)
     for(k=0; k<150; k++)
*步进电机运行
void  motor_turn(void)
   unsigned char x;
   rate=0x0a;
   x=0x40;
   do
  motor_ffw();          //加速
      rate--;
}while(rate!=0x01);
   do
   motor_ffw();        //匀速
   x--;
}while(x!=0x01);
   do
  motor_ffw();         //减速
      rate++;
}while(rate!=0x0a);
main()
    while(1)
motor_turn();
一个机会 发表于 2011-11-13 11:28 | 显示全部楼层
看不懂的代码啊
