[其他] 【HC32L136 demo板】+HT1621
1377|2
 楼主| Cjy_JDxy 发表于 2019-9-24 21:48 | 显示全部楼层 |阅读模式
今天写了个HT1621的驱动程序,开发环境keil。
* Include files
#include "gpio.h"
* Local pre-processor symbols/macros ('#define')
* Global variable definitions (declared in header file with 'extern')
* Local type definitions ('typedef')
* Local function prototypes ('static')
* Local variable definitions ('static')                                      *
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
#define CS_0           Gpio_ClrIO(GpioPortB, GpioPin5)
#define CS_1           Gpio_SetIO(GpioPortB, GpioPin5)
#define WR_0           Gpio_ClrIO(GpioPortB, GpioPin7)
#define WR_1           Gpio_SetIO(GpioPortB, GpioPin7)
#define DA_0           Gpio_ClrIO(GpioPortB, GpioPin8)
#define DA_1           Gpio_SetIO(GpioPortB, GpioPin8)
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //显示缓冲区
unsigned int i;
void COMMAND_HT1621(unsigned char comm)
        unsigned char i;
        CS_0;
        WR_0;
        for(i=0;i<3;i++)        //写命令
                if((0x04<<i)&0x04)  DA_1;    //100
                else                DA_0;
                WR_0;
                WR_1;
        for(i=0;i<9;i++)        //写命令数据
                if((comm<<i)&0x80)  DA_1;    //100
                else                DA_0;
                WR_0;
                WR_1;
        CS_1;
void HT1621_Display(void)
        unsigned char i;
        CS_0;                        //片选CS
        WR_0;
                if((0x05<<i)&0x04)  DA_1;
                else                DA_0;
                WR_0;
                WR_1;
        for(i=0;i<6;i++)                   //写地址
                if((20<<i)&0x20)    DA_1;  //20对应 SEG地址
                  else                DA_0;
                WR_0;
                WR_1;
        for(i=0;i<8;i++)                   //写数据
                if((DpyNum[5]<<i)&0x80)   DA_1;
                else                      DA_0;
                WR_0;
                WR_1;
                if((DpyNum[4]<<i)&0x80)   DA_1;
                else                      DA_0;
                WR_0;
                WR_1;
                if((DpyNum[3]<<i)&0x80)   DA_1;
                else                      DA_0;
                WR_0;
                WR_1;
                if((DpyNum[2]<<i)&0x80)   DA_1;
                else                      DA_0;
                WR_0;
                WR_1;
                if((DpyNum[1]<<i)&0x80)   DA_1;
                else                      DA_0;
                WR_0;
                WR_1;
                if((DpyNum[0]<<i)&0x80)   DA_1;
                else                      DA_0;
                WR_0;
                WR_1;
        CS_1;                          //释放CS
void LCD_Init(void)
        COMMAND_HT1621(0x01);         //SYS EN
        COMMAND_HT1621(0x03);         //LCD ON
        COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
        HT1621_Display();             //clear screen
* Function implementation - global ('extern') and local ('static')
** \brief  Main function of project
** \return uint32_t return value, if needed
** This sample
int32_t main(void)
    stc_gpio_config_t pstcGpioCfg;
    ///< 打开GPIO外设时钟门控
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
    ///< 端口方向配置->输出
    pstcGpioCfg.enDir = GpioDirOut;
    ///< 端口驱动能力配置->高驱动能力
    pstcGpioCfg.enDrv = GpioDrvH;
    ///< 端口上下拉配置->无上下拉
    pstcGpioCfg.enPuPd = GpioNoPuPd;
    ///< 端口开漏输出配置->开漏输出关闭
    pstcGpioCfg.enOD = GpioOdDisable;
    ///< 端口输入/输出值寄存器总线控制模式配置->AHB
    pstcGpioCfg.enCtrlMode = GpioAHB;
    ///< GPIO IO PD05初始化(PD05在STK上外接LED)
    Gpio_Init(GpioPortD, GpioPin5, &pstcGpioCfg);
    Gpio_Init(GpioPortB, GpioPin5, &pstcGpioCfg);
                Gpio_Init(GpioPortB, GpioPin7, &pstcGpioCfg);
    Gpio_Init(GpioPortB, GpioPin8, &pstcGpioCfg);
                LCD_Init();
                DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"三"
                DpyNum[1] = SegCode[1];
                DpyNum[2] = SegCode[3];
                DpyNum[3] = SegCode[5];
                DpyNum[4] = SegCode[7];
                DpyNum[5] = SegCode[9];
                HT1621_Display();               //刷新LCD
    while(1)
//        ///< 端口PD05设置为高电平(LED点亮)
//        Gpio_SetIO(GpioPortD, GpioPin5);
//        delay1ms(1000);
//        ///< 端口PD05设置为低电平(LED关闭)
//        Gpio_ClrIO(GpioPortD, GpioPin5);
//        delay1ms(1000);
* EOF (not truncated)
caizhiwei 发表于 2019-9-25 09:33 | 显示全部楼层
不错啊,妹子,不过mcu内部集成了断码液晶驱动器了,可以节省成本
 楼主| Cjy_JDxy 发表于 2019-9-25 10:13 | 显示全部楼层
我是男的
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
