[其他] 【HC32L136 demo板】+另一种HT1621
1010|0
 楼主| Cjy_JDxy 发表于 2019-9-25 20:00 | 显示全部楼层 |阅读模式
今天写了另外一款HT1621的驱动,开发环境用的IAR。
代码:
* Include files
#include "gpio.h"
* Local pre-processor symbols/macros ('#define')
typedef unsigned char uchar;
* Global variable definitions (declared in header file with 'extern')
unsigned int counter;
* Local type definitions ('typedef')
unsigned int tmp;
unsigned int n1, n2, n3, n4;
unsigned char Ht1621Tab[]={0x00,0x00,0x00,0x00};
unsigned char DispTab[]={0x7B,0x12,0x67,0x57,0x1E,0x5D,0x7D,0x13,0x7F,0x5F,0x69,0x45,0x3f, 0x7a, 0x3e};
              //          0    1    2    3    4    5    6    7    8    9    C    三   A     V     H
#define  BIAS     0x52             //0b1000 0101 0010  1/3duty 4com
#define  SYSDIS   0X00             //0b1000 0000 0000  关振系统荡器和LCD偏压发生器
#define  SYSEN    0X02             //0b1000 0000 0010 打开系统振荡器
#define  LCDOFF   0X04             //0b1000 0000 0100  关LCD偏压
#define  LCDON    0X06             //0b1000 0000 0110  打开LCD偏压
#define  XTAL     0x28             //0b1000 0010 1000 外部接时钟
#define  RC256    0X30             //0b1000 0011 0000  内部时钟
#define  WDTDIS1  0X0A            //0b1000 0000 1010  禁止看门狗
void Ht1621_CS_0() { Gpio_ClrIO(GpioPortB, GpioPin5);}  // define P2.2 ---> CS
void Ht1621_CS_1() { Gpio_SetIO(GpioPortB, GpioPin5);}
void Ht1621_WR_0() { Gpio_ClrIO(GpioPortB, GpioPin7);}  // define P2.1 ---> WR
void Ht1621_WR_1() { Gpio_SetIO(GpioPortB, GpioPin7);}
void Ht1621_DO_0() { Gpio_ClrIO(GpioPortB, GpioPin8);}  // define P2.0 ---> DAT
void Ht1621_DO_1() { Gpio_SetIO(GpioPortB, GpioPin8);}
//函数名称:Delay()
//功    能:延时子程序
void Delay(unsigned char us)  //5,7,9
  while(--us);
//函数名称:Delayms()
void Delayms(unsigned int ims)
  unsigned int i,j;
    for(i=0;i<ims;i++)
      for(j=0;j<65;j++) { Delay(1); }
//Ht1621Wr_Data()
void Ht1621Wr_Data(unsigned char Data,unsigned char cnt)
  unsigned char i;
  for (i=0;i<cnt;i++)
     Ht1621_WR_0();
     if((Data & 0x80)==0x80) {Ht1621_DO_1();}
     else {Ht1621_DO_0();}
     Ht1621_WR_1();
     Data<<=1;
//void Ht1621WrCmd(uchar Cmd)
void Ht1621WrCmd(unsigned char Cmd)
   Ht1621_CS_0();
   Ht1621Wr_Data(0x80,4);          //写入命令标志100
   Ht1621Wr_Data(Cmd,8);           //写入命令数据
   Ht1621_CS_1();
//void Ht1621WrOneData(uchar Addr,uchar Data)
void Ht1621WrOneData(unsigned char Addr,unsigned char Data)
  Ht1621_CS_0();
  Ht1621Wr_Data(0xa0,3);  //写入数据标志101
  Ht1621Wr_Data(Addr<<2,6); //写入地址数据
  Ht1621Wr_Data(Data,4); //写入数据的前四位 7  6  5  4
  Ht1621_CS_1();
//void Ht1621WrAllData()
void Ht1621WrAllData(unsigned char Addr,unsigned char *p,unsigned char cnt)
  unsigned char i;
  Ht1621_CS_0();
  for (i=0;i<cnt;i++)
    Ht1621Wr_Data(*p,8); //写入数据
    p++;
  Ht1621_CS_1();
//void Ht1621_Init(void)
   Ht1621WrCmd(BIAS);
   Ht1621WrCmd(RC256);             //使用内部振荡器
   //Ht1621WrCmd(XTAL);             //使用外部振荡器
   Ht1621WrCmd(SYSDIS);
   Ht1621WrCmd(WDTDIS1);
   Ht1621WrCmd(SYSEN);
   Ht1621WrCmd(LCDON);
//DISPLAY
void Display(void)
   unsigned char com;
   com = 0;
   if((DispTab[n1]&0x01) == 0x01){ com = com + 0x10;}
   if((DispTab[n2]&0x01) == 0x01){ com = com + 0x20;}
   if((DispTab[n3]&0x01) == 0x01){ com = com + 0x40;}
   if((DispTab[n4]&0x01) == 0x01){ com = com + 0x80;}
   Ht1621WrOneData(0 , com);
   com = 0;
   if((DispTab[n1]&0x02) == 0x02){ com = com + 0x10;}
   if((DispTab[n2]&0x02) == 0x02){ com = com + 0x20;}
   if((DispTab[n3]&0x02) == 0x02){ com = com + 0x40;}
   if((DispTab[n4]&0x02) == 0x02){ com = com + 0x80;}
   Ht1621WrOneData(1 , com);
   com = 0;
   if((DispTab[n1]&0x10) == 0x10){ com = com + 0x10;}
   if((DispTab[n2]&0x10) == 0x10){ com = com + 0x20;}
   if((DispTab[n3]&0x10) == 0x10){ com = com + 0x40;}
   if((DispTab[n4]&0x10) == 0x10){ com = com + 0x80;}
   Ht1621WrOneData(2 , com);
   com = 0;
   if((DispTab[n1]&0x40) == 0x40){ com = com + 0x10;}
   if((DispTab[n2]&0x40) == 0x40){ com = com + 0x20;}
   if((DispTab[n3]&0x40) == 0x40){ com = com + 0x40;}
   if((DispTab[n4]&0x40) == 0x40){ com = com + 0x80;}
   Ht1621WrOneData(3 , com);
   com = 0;
   if((DispTab[n1]&0x20) == 0x20){ com = com + 0x10;}
   if((DispTab[n2]&0x20) == 0x20){ com = com + 0x20;}
   if((DispTab[n3]&0x20) == 0x20){ com = com + 0x40;}
   if((DispTab[n4]&0x20) == 0x20){ com = com + 0x80;}
   Ht1621WrOneData(4 , com);
   com = 0;
   if((DispTab[n1]&0x08) == 0x08){ com = com + 0x10;}
   if((DispTab[n2]&0x08) == 0x08){ com = com + 0x20;}
   if((DispTab[n3]&0x08) == 0x08){ com = com + 0x40;}
   if((DispTab[n4]&0x08) == 0x08){ com = com + 0x80;}
   Ht1621WrOneData(5 , com);
   com = 0;
   if((DispTab[n1]&0x04) == 0x04){ com = com + 0x10;}
   if((DispTab[n2]&0x04) == 0x04){ com = com + 0x20;}
   if((DispTab[n3]&0x04) == 0x04){ com = com + 0x40;}
   if((DispTab[n4]&0x04) == 0x04){ com = com + 0x80;}
   Ht1621WrOneData(6 , com);
//Display_lcd_dot
void Display_lcd_dot(void)
   Ht1621WrOneData(7 , 0x50);
//convertor()
void data_convertor(unsigned long adc_value)
    tmp=adc_value;         //adc
    n4=tmp/100;
    tmp=tmp%100;
    n3=tmp/10;
    tmp=tmp%10;
    n2=tmp;
                 // 4
    n1=10;       //display "C"
* Local function prototypes ('static')
* Local variable definitions ('static')                                      *
* Function implementation - global ('extern') and local ('static')
** \brief  Main function of project
** \return uint32_t return value, if needed
** This sample
int32_t main(void)
    stc_gpio_config_t pstcGpioCfg;
    counter = 235;
    ///< 打开GPIO外设时钟门控
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
    ///< 端口方向配置->输出
    pstcGpioCfg.enDir = GpioDirOut;
    ///< 端口驱动能力配置->高驱动能力
    pstcGpioCfg.enDrv = GpioDrvH;
    ///< 端口上下拉配置->无上下拉
    pstcGpioCfg.enPuPd = GpioNoPuPd;
    ///< 端口开漏输出配置->开漏输出关闭
    pstcGpioCfg.enOD = GpioOdDisable;
    ///< 端口输入/输出值寄存器总线控制模式配置->AHB
    pstcGpioCfg.enCtrlMode = GpioAHB;
    ///< GPIO IO PD05初始化(PD05在STK上外接LED)
    Gpio_Init(GpioPortD, GpioPin5, &pstcGpioCfg);
    Gpio_Init(GpioPortB, GpioPin5, &pstcGpioCfg);
    Gpio_Init(GpioPortB, GpioPin7, &pstcGpioCfg);
    Gpio_Init(GpioPortB, GpioPin8, &pstcGpioCfg);
    Ht1621_Init();        //上电初始化LCD
    Delay(100);           //延时一段时间
    Ht1621WrAllData(0,Ht1621Tab,16);// Clear LCD display
    Ht1621_Init();
    while(1)
        data_convertor(counter);
        Display();
        Display_lcd_dot();
        Delayms(1000);
        counter++;
效果图:
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
