关于ds1302
2203|1
久之1990|  楼主 | 2011-11-26 13:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<iom88.h>
#include<avr_macros.h>
#define uchar unsigned char
#define uint unsigned int
#define DDR_WR_IO   DDRC |= 0X10
#define DDR_RE_IO   DDRC &= 0XEF
#define SCLK_1  PORTC_Bit5=1
#define SCLK_0  PORTC_Bit5=0
#define RST_1   PORTC_Bit3=1
#define RST_0   PORTC_Bit3=0
#define WR_IO_1 PORTC_Bit4 = 1
#define WR_IO_0 PORTC_Bit4 = 0
#define RE_IO   (PINC&0X10)
uchar table[] = {0xc0,0xf9,0xa4,0xb0,0x99,
                 0x92,0x82,0xf8,0x80,0x90};//0~9
uchar duanma[] = {0x7f,0xbf,0xdf,0xef};
uchar shu[] = {0,0,0,0};
void delay(uchar x)
  uchar kk;
  for(;x>0;x--)
    for(kk=200;kk>0;kk--);
void display()
  uchar i;
  for(i=0;i<4;i++)
    PORTD = 0xff;
    PORTD = duanma
    PORTB = table[shu
    delay(2);
uchar read_byte_ds1302()
  uchar i;
  uchar dat=0;
  DDR_RE_IO;
  for(i=0;i<8;i++)
    dat = dat>>1;
    SCLK_1;
    SCLK_0;
    if(RE_IO)
      dat |= 0x80;
  return (dat/16*10 + dat%16);
void write_byte_ds1302(uchar dat)
  uchar i;
  DDR_WR_IO ;
  for(i=0;i<8;i++)
    SCLK_0;
    if(dat&0x01)
       WR_IO_1;
    else
       WR_IO_0;
    SCLK_1;
    dat = dat>>1;
uchar read_data(uchar add)
  uchar dat;
  RST_1;
  write_byte_ds1302(add);
  dat = read_byte_ds1302();
  RST_0;
  return dat;
void write_data(uchar add,uchar dat)
  RST_1;
  write_byte_ds1302(dat);
  RST_0;
void init_ds1302()
  write_data(0x8e,0x00);
  write_data(0x80,0x56);
  write_data(0x82,0x36);
  write_data(0x8e,0x80);
void gettime()
  shu[0] = read_data(0x81)%10;
  shu[2] = read_data(0x83)%10;
void main()
  DDRD = 0XFF;
  DDRB = 0XFF;
  DDRC = 0XFF;
  init_ds1302();
  while(1)
     gettime();
     display();
为什么总显示两个5呢?
outstanding| | 2013-8-25 11:35 | 只看该作者
这样贴出来,你应该把关键的部分标出来啊
