[国产单片机] 【东软载波ESF0654 PDS开发板活动】测试串口0
1015|0
 楼主| 一路向北lm 发表于 2019-12-16 20:45 | 显示全部楼层 |阅读模式
由于ES32F065板卡没有板载串口转USB芯片,需要自己外接一个USB串口模块进行测试。
串口初始化函数:
  1. <font size="4"><b>//串口GPIO初始化
  2. static void uart_232_pin_init(void)
  3. {
  4.     gpio_init_t x;
  5.     /* Initialize tx pin */
  6.     x.mode = GPIO_MODE_OUTPUT;
  7.     x.odos = GPIO_PUSH_PULL;
  8.     x.pupd = GPIO_PUSH_UP;
  9.     x.odrv = GPIO_OUT_DRIVE_NORMAL;
  10.     x.flt  = GPIO_FILTER_DISABLE;
  11.     x.type = GPIO_TYPE_TTL;
  12.     x.func = GPIO_FUNC_3;
  13.     ald_gpio_init(GPIOB, GPIO_PIN_10, &x);
  14.     /* Initialize rx pin */
  15.     x.mode = GPIO_MODE_INPUT;
  16.     x.odos = GPIO_PUSH_PULL;
  17.     x.pupd = GPIO_PUSH_UP;
  18.     x.odrv = GPIO_OUT_DRIVE_NORMAL;
  19.     x.flt  = GPIO_FILTER_DISABLE;
  20.     x.type = GPIO_TYPE_TTL;
  21.     x.func = GPIO_FUNC_3;
  22.     ald_gpio_init(GPIOB, GPIO_PIN_11, &x);
  23. }
  24. //串口初始化
  25. void uart_232_module_init(uint32_t baud)
  26. {
  27.     uart_232_pin_init();
  28.     memset(&h_uart, 0x0, sizeof(h_uart));
  29.     /* Initialize uart */
  30.     h_uart.perh             = UART0;
  31.     h_uart.init.baud        = baud;
  32.     h_uart.init.word_length = UART_WORD_LENGTH_8B;
  33.     h_uart.init.stop_bits   = UART_STOP_BITS_1;
  34.     h_uart.init.parity      = UART_PARITY_NONE;
  35.     h_uart.init.mode        = UART_MODE_UART;
  36.     h_uart.init.fctl        = UART_HW_FLOW_CTL_DISABLE;
  37.     ald_uart_init(&h_uart);
  38. }
  39. </b></font>
串口接收数据函数:
  1. <font size="4"><b>uart_232_status_t bsp_uart_232_recv(uint8_t *buf, uint16_t size)
  3.     if (buf == NULL)
  4.         return UART_232_ERROR;
  5.     if (ald_uart_recv(&h_uart, buf, size, 500) != OK)
  6.         return UART_232_ERROR;
  7.     return UART_232_OK;
  8. }
  9. </b></font>
串口写数据函数:
  1. <font size="4"><b>uart_232_status_t bsp_uart_232_send(uint8_t *buf, uint16_t size)
  3.     if (buf == NULL)
  5.     if (ald_uart_send(&h_uart, buf, size, 500) != OK)
  8. }
  9. </b></font>
添加修改main.cmian.h,实现对串口的读写操作。
  1. <font size="4"><b>#include "main.h"
  2. unsigned char Sendbuf[16] = "es32f0654 is ok!";
  3. int main()
  4. {
  5.         led_module_init();   //LED初始化
  6.         bsp_key_init();      //按键初始化
  7.         uart_232_module_init(115200);
  8.   bsp_uart_232_send(Sendbuf,16);
  9.         while (1)
  10.         {
  11.         }
  12. }
  13. #ifndef   __MAIN_H__
  14. #define   __MAIN_H__
  15. #include "bsp_led.h"
  16. #include "bsp_key.h"
  17. #include "bsp_uart_232.h"
  18. #endif
  19. </b></font>
硬件连接后,打印数据如下:
