[国产单片机]
【东软载波ESF0654 PDS开发板活动】+ TN9
733|0
Cjy_JDxy|  楼主 | 2019-12-17 18:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
今晚捣鼓了一下TN9,红外体温计模块。
代码:
#include "main.h"
/** @addtogroup Projects_Examples_MD
/** @addtogroup Examples
#define uchar unsigned char
#define uint  unsigned int
void ACK_0() { md_gpio_set_pin_low(ACK_GPIO_PORT, ACK_GPIO_PIN);}  //
void ACK_1() { md_gpio_set_pin_high(ACK_GPIO_PORT, ACK_GPIO_PIN);}
#define DATA            md_gpio_get_input_data(DATA_GPIO_PORT, DATA_GPIO_PIN)
#define CLOCK           md_gpio_get_input_data(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN)
float Temp;
float Temp1,Temp2;
unsigned char ReadData[5];
unsigned int a,b;
//????:Delay()
void Delay(unsigned char us)  //5,7,9
  while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
  unsigned int i,j;
    for(i=0;i<ims;i++)
      for(j=0;j<65;j++) { Delay(1); }
  * @brief  This function configures GPIO
  * @param  None
  * @retval None
void config_gpio(void)
        md_gpio_set_pin_function(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN);
        md_gpio_set_pin_mode_input(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN);
        md_gpio_set_pin_function(DATA_GPIO_PORT, DATA_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(DATA_GPIO_PORT, DATA_GPIO_PIN);
        md_gpio_set_pin_mode_input(DATA_GPIO_PORT, DATA_GPIO_PIN);
        md_gpio_set_pin_function(ACK_GPIO_PORT, ACK_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(ACK_GPIO_PORT, ACK_GPIO_PIN);
        md_gpio_set_pin_mode_output(ACK_GPIO_PORT, ACK_GPIO_PIN);
        md_gpio_set_pin_function(LED2_GPIO_PORT, LED2_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(LED2_GPIO_PORT, LED2_GPIO_PIN);
        md_gpio_set_pin_mode_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
void TN_IRACK_EN(void)
        ACK_0();
        Delay(1);
void TN_IRACK_UN(void)
        ACK_1();
        Delay(1);
void TN_ReadData(unsigned char Flag)
        unsigned char i,j,k,BitState=0;
        for(k=0;k<7;k++)
                for(j=0;j<5;j++)
                        for(i=0;i<8;i++)
                                while(1)
                                  if(CLOCK==0)
                                    break;
                                  Delay(1);
                                Delay(1);
                                if(DATA==1)
                                  BitState=1;
                                else
                                  BitState=0;
                                ReadData[j]= ReadData[j]<<1;
                                ReadData[j]= ReadData[j]|BitState;
                                Delay(1);
                                while(1)
                                  if(CLOCK==1)
                                    break;
                                  Delay(1);
                if(ReadData[0]==Flag)
                        k=8;
        TN_IRACK_UN();
float TN_GetData(unsigned char X)
        //Ack_Clk_Data_init;
  config_gpio();
        TN_ReadData(X);
        Temp=(ReadData[1]<<8)|ReadData[2];
        Temp=(float)Temp/16.00-273.15;
        return Temp;
float TN_GetTemp(unsigned char mode)
        float T;
                TN_IRACK_UN();
                TN_IRACK_EN();
                if(mode==0)
                        T=TN_GetData(0x4c);
                else
                        T=TN_GetData(0x66);
        return T;
  * @brief  Test main function
  * @retval Status.
int main()
        md_init_1ms_tick();
        config_gpio();
        while (1)
                Temp1=TN_GetTemp(0);
                Temp2=TN_GetTemp(1);
                a=((unsigned int)(Temp1*10));
                b=((unsigned int)(Temp2*10));
                Delayms(1500);
效果图:
a是体温,b是环境温度。
把手靠近TN9,指示30来度,否则和环境温度差不多。
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
