[应用相关] 位定义
532|12
 楼主| jlyuan 发表于 2020-2-15 11:10 | 显示全部楼层 |阅读模式
stm32中如何进行位定义?
wyjie 发表于 2020-2-15 11:13 | 显示全部楼层
可以通过结构体变量进行定义。位段操作嘛。冒号。
yszong 发表于 2020-2-15 11:17 | 显示全部楼层
#define BITBAND(addr, bitnum) ((addr & 0xF0000000)+0x2000000+((addr &0xFFFFF)<<5)+(bitnum<<2))
#define MEM_ADDR(addr)  *((volatile unsigned long  *)(addr))
#define BIT_ADDR(addr, bitnum)   MEM_ADDR(BITBAND(addr, bitnum))
//IO口地址映射
#define GPIOA_ODR_Addr    (GPIOA_BASE+12) //0x4001080C
#define GPIOB_ODR_Addr    (GPIOB_BASE+12) //0x40010C0C
#define GPIOC_ODR_Addr    (GPIOC_BASE+12) //0x4001100C
#define GPIOD_ODR_Addr    (GPIOD_BASE+12) //0x4001140C
#define GPIOE_ODR_Addr    (GPIOE_BASE+12) //0x4001180C
#define GPIOF_ODR_Addr    (GPIOF_BASE+12) //0x40011A0C
#define GPIOG_ODR_Addr    (GPIOG_BASE+12) //0x40011E0C
#define GPIOA_IDR_Addr    (GPIOA_BASE+8) //0x40010808
#define GPIOB_IDR_Addr    (GPIOB_BASE+8) //0x40010C08
#define GPIOC_IDR_Addr    (GPIOC_BASE+8) //0x40011008
#define GPIOD_IDR_Addr    (GPIOD_BASE+8) //0x40011408
#define GPIOE_IDR_Addr    (GPIOE_BASE+8) //0x40011808
#define GPIOF_IDR_Addr    (GPIOF_BASE+8) //0x40011A08
#define GPIOG_IDR_Addr    (GPIOG_BASE+8) //0x40011E08
//IO口操作,只对单一的IO口!
//确保n的值小于16!
#define PAout(n)   BIT_ADDR(GPIOA_ODR_Addr,n)  //输出
#define PAin(n)    BIT_ADDR(GPIOA_IDR_Addr,n)  //输入
#define PBout(n)   BIT_ADDR(GPIOB_ODR_Addr,n)  //输出
#define PBin(n)    BIT_ADDR(GPIOB_IDR_Addr,n)  //输入
#define PCout(n)   BIT_ADDR(GPIOC_ODR_Addr,n)  //输出
#define PCin(n)    BIT_ADDR(GPIOC_IDR_Addr,n)  //输入
#define PDout(n)   BIT_ADDR(GPIOD_ODR_Addr,n)  //输出
#define PDin(n)    BIT_ADDR(GPIOD_IDR_Addr,n)  //输入
#define PEout(n)   BIT_ADDR(GPIOE_ODR_Addr,n)  //输出
#define PEin(n)    BIT_ADDR(GPIOE_IDR_Addr,n)  //输入
#define PFout(n)   BIT_ADDR(GPIOF_ODR_Addr,n)  //输出
#define PFin(n)    BIT_ADDR(GPIOF_IDR_Addr,n)  //输入
#define PGout(n)   BIT_ADDR(GPIOG_ODR_Addr,n)  //输出
#define PGin(n)    BIT_ADDR(GPIOG_IDR_Addr,n)  //输入
//Ex_NVIC_Config专用定义
#define GPIO_A 0
#define GPIO_B 1
#define GPIO_C 2
#define GPIO_D 3
#define GPIO_E 4
#define GPIO_F 5
#define GPIO_G 6
/////////这是STM32F103 位带操作的定义方式,看懂了就可以进行位定义了,出自 正点原子资料
位带操作是有地址范围限制的,并不是所有的外设都能使用位带操作  发表于 2020-3-4 15:26
dengdc 发表于 2020-2-15 11:19 | 显示全部楼层
通过位的逻辑操作实现。
heweibig 发表于 2020-2-15 11:22 | 显示全部楼层
精简指令集好像是不能直接对位操作的,需要通过逻辑操作实现。
wuhany 发表于 2020-2-15 11:24 | 显示全部楼层
貌似不是一两句说的请的
楼主可以百度一下,网上资料挺多的
chuxh 发表于 2020-2-15 11:27 | 显示全部楼层
bit就可以啊
 楼主| jlyuan 发表于 2020-2-15 11:34 | 显示全部楼层
嗯,我再好好缕一缕吧,有了好消息及时通知大家,结贴喽
wowu 发表于 2020-3-4 14:03 | 显示全部楼层
三楼给的资料很详细
xiaoqizi 发表于 2020-3-4 14:21 | 显示全部楼层
用bit不可以直接赋值吗
磨砂 发表于 2020-3-4 14:26 | 显示全部楼层
我记得好像有相关现成的语句啊
晓伍 发表于 2020-3-4 14:35 | 显示全部楼层
用cube生成的代码  然后看里边人家是怎么写的就知道了
