[资料分享]
功耗优化型 77GHz 液位变送器参考设计 TIDEP-0091
1135|16
dirtwillfly|  楼主 | 2020-3-31 21:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
TI Design TIDEP-0091 highlights strategies for power optimization of IWR14xx 76- to 81-GHz mmWave sensors in tank level-probing applications, displacement sensors, 4- to 20-mA sensors, and other low-power applications for detecting range with high accuracy in a minimal power envelope. In these applications, the system often operates on a low-voltage data line that provides less power than the operational power consumption. Duty cycling is critical to reducing the average power to meet the power input restrictions. Power optimization is achieved through MSP432 external duty cycling the IWR14xx device for periodic sensing. Additionally, this TI Design provides a sample configuration for single-dimensional range detection.
Read more about fluid-level sensing using 77-GHz millimeter wave (SPYY004).
Watch the introduction to level sensing (video).
特性
  • Uses IWR1443 mmWave and SimpleLink MSP432 software development kits (SDKs)
  • Serial communication between IWR1443 and MSP432
  • Provides an optimized processing chain for single-dimension range detection
  • Applicable to any application requiring low-power duty cycling
dirtwillfly|  楼主 | 2020-3-31 21:28 | 只看该作者
功耗优化型 IWR1443 77GHz 液位变送器参考设计 (Rev. B).pdf (4.25 MB)
wiba| | 2020-4-2 13:23 | 只看该作者
非常感谢楼主分享
zljiu| | 2020-4-2 13:24 | 只看该作者
非常感谢楼主分享
coshi| | 2020-4-2 13:24 | 只看该作者
非常感谢楼主分享
aoyi| | 2020-4-2 13:24 | 只看该作者
非常感谢楼主分享
drer| | 2020-4-2 13:24 | 只看该作者
非常感谢楼主分享
dirtwillfly|  楼主 | 2020-6-22 17:25 | 只看该作者
Fluid-Level Sensing using 77GHz millimeter wave.pdf (818.52 KB)
dirtwillfly|  楼主 | 2020-6-22 17:27 | 只看该作者
Chirp Budget Calc_09_25_18.zip (53.98 KB)
Chirp Budget Calc_09_10_18.zip (52.97 KB)
dirtwillfly|  楼主 | 2020-6-22 17:29 | 只看该作者
Power Optimization for 77GHz Level Transmitter BOM.pdf (73.22 KB)
dirtwillfly|  楼主 | 2020-6-22 17:30 | 只看该作者
Power Optimization for 77GHz Level Transmitter Schematic and Block Diagram.pdf (575.19 KB)
dirtwillfly|  楼主 | 2020-6-22 17:31 | 只看该作者
Power Optimization for 77GHz Level Transmitter Altium.zip (513.53 KB)
dirtwillfly|  楼主 | 2020-6-22 17:32 | 只看该作者
Power Optimization for 77GHz Level Transmitter Gerber.zip (2.2 MB)
Power Optimization for 77GHz Level Transmitter Layer Plots.zip (4.08 MB)
dirtwillfly|  楼主 | 2020-6-22 17:33 | 只看该作者
Power Optimization for 77GHz Level Transmitter Assembly Files.zip (352.51 KB)
dirtwillfly|  楼主 | 2020-6-22 17:35 | 只看该作者
Power Optimized Level Sensing Demo Software.zip (12.18 MB)
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1184
