[MCU] MSP432评测6-----KEIL+MAX7219
1860|25
 楼主| Cjy_JDxy 发表于 2020-4-16 19:08 | 显示全部楼层 |阅读模式
前几天搞得CCS,今天开搞KEIL。
MSP432驱动MAX7219。
DIN:P4.0;LOAD:P4.2;CLK:P4.4
代码:
#include "msp.h"
#define uchar unsigned char
#define uint unsigned int
#define CLK_0           P4->OUT &= ~BIT4
#define CLK_1           P4->OUT |= BIT4
#define LOAD_0          P4->OUT &= ~BIT2
#define LOAD_1          P4->OUT |= BIT2
#define DIN_0           P4->OUT &= ~BIT0
#define DIN_1           P4->OUT |= BIT0
#define NoOp   0x00           //??????
#define Digit0 0x01           // ???1???
#define Digit1 0x02           // ???2???
#define Digit2 0x03           // ???3???
#define Digit3 0x04           // ???4???
#define Digit4 0x05           // ???5???
#define Digit5 0x06           // ???6???
#define Digit6 0x07           // ???7???
#define Digit7 0x08           // ???8???
#define DecodeMode 0x09       // ???????
#define Intensity 0x0a        // ?????
#define ScanLimit 0x0b        // ???????
#define ShutDown 0x0c         // ????????
#define DisplayTest 0x0f      // ???????
#define ShutdownMode 0x00     // ?????
#define NormalOperation 0x01  // ??????
#define ScanDigit 0x07        // ??????,??8????
#define DecodeDigit 0xff      // ????,8???BCD?
#define IntensityGrade 0x0a   // ??????
#define TestMode 0x01         // ??????
#define TextEnd 0x00          // ??????,????????
* Function implementation - global ('extern') and local ('static')
uchar DisBuffer[8]={0,0,0,0,0,0,0,0};    // ?????
//******************??t??**************************************
void delay(uint t)
       uint i;
       while(t--)
              /* ??12M??,???1ms */
              for (i=0;i<125;i++)
//*************?MAX7219????(8?)********************
void SendChar (uchar ch)
    uchar i,temp;
    delay(1);
    for (i=0;i<8;i++)
         temp=ch&0x80;
         ch=ch<<1;
         if(temp)
            DIN_1;
            CLK_0;
            CLK_1;
         else
            DIN_0;
            CLK_0;
            CLK_1;
//**************?MAX7219???(16?)*****************************
void WriteWord (uchar addr,uchar num)
    LOAD_0;
    delay(1);
    SendChar(addr);
    delay(1);
    SendChar(num);
    delay(1);
    LOAD_1;                            // ????????
//*********************** MAX7219??? ******************
void InitDisplay (void)
    WriteWord (ScanLimit,ScanDigit);         // ??????
    WriteWord (DecodeMode,DecodeDigit);      // ??????
    WriteWord (Intensity,IntensityGrade);    // ????
    WriteWord (ShutDown,NormalOperation);    // ?????????
int main(void)
    volatile uint32_t i;
    WDT_A->CTL = WDT_A_CTL_PW | WDT_A_CTL_HOLD;  // Stop watchdog timer
    // The following code toggles P1.0 port
    P4->DIR |= BIT0 | BIT2 | BIT4;                             // Configure P4.0 as output
                InitDisplay (); // MAX7219???
    WriteWord(DisplayTest,TestMode);  // ??????,????LED
    delay(1500);                      // ???1.5s
    WriteWord (DisplayTest,TextEnd);  // ????????
    WriteWord (Digit0,0);
    WriteWord (Digit1,1);
    WriteWord (Digit2,2);
    WriteWord (Digit3,3);
    while(1)
        P1->OUT ^= BIT0;                         // Toggle P1.0
        for(i=100000; i>0; i--);                  // Delay
效果图:
keil设置,仿真器选择:
烧写算法:
MAX7219模块是我自己做的,原理图,PCB如下:
工程:
zhangmangui 发表于 2020-4-16 22:58 | 显示全部楼层
不错不错   进展很快
10299823 发表于 2020-4-20 22:37 | 显示全部楼层
sanfuzi 发表于 2020-4-20 22:37 | 显示全部楼层
楼主的资料不错。
fengm 发表于 2020-4-20 22:37 | 显示全部楼层
工程文件呢
sdCAD 发表于 2020-4-20 22:37 | 显示全部楼层
MSP432怎么样
backlugin 发表于 2020-4-20 22:38 | 显示全部楼层
MAX7219效率很高吗
sanxingnote7 发表于 2020-4-20 22:38 | 显示全部楼层
这个还能用keil吗?
dzfansman 发表于 2020-4-20 22:38 | 显示全部楼层
iamaiqiyi 发表于 2020-4-20 22:38 | 显示全部楼层
驱动MAX7219不难吧
jstgotodo 发表于 2020-4-20 22:39 | 显示全部楼层
为什么不用串口芯片呢
quickman 发表于 2020-4-20 22:39 | 显示全部楼层
这个很给力呢。
 楼主| Cjy_JDxy 发表于 2020-4-21 07:52 | 显示全部楼层
你没看见吗
 楼主| Cjy_JDxy 发表于 2020-4-21 07:59 | 显示全部楼层
 楼主| Cjy_JDxy 发表于 2020-4-21 08:00 | 显示全部楼层
 楼主| Cjy_JDxy 发表于 2020-4-21 08:02 | 显示全部楼层
这个还能用keil吗?
可以呀
 楼主| Cjy_JDxy 发表于 2020-4-21 08:06 | 显示全部楼层
 楼主| Cjy_JDxy 发表于 2020-4-21 08:13 | 显示全部楼层
为什么不用串口芯片呢
什么串口芯片
zhangmangui 发表于 2020-4-27 23:50 | 显示全部楼层
希望能持续分享哈
磨砂 发表于 2020-5-9 16:08 | 显示全部楼层
非常感谢楼主分享
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
